Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Mac book 2.1 gHz software
If i buy a mac book from you but a program from apple, will the geek squad help me install it?
Thanks!!
Yes, they will install it for a small fee of 39.99
Posted on Jul 21, 2008
Can not get into tinychat with mac pro
Go to best buy or something. Have the geek squad check it out.
Feb 17, 2013 | Apple Customized 15" MacBook Pro Laptop...
How can I boost up mac mini 2007
Your best bet beyond maxing out memory will be upgrading to an SSD. Depending on your operating system and versions of installed software, try using a program like XSlimmer to remove any powerpc files included in universal bundles.
Oct 09, 2012 | Apple MAC MINI 266GHz Intel Core 2 Duo 8...
How do you reset an apple macbook laptop
Don't worry just follow the below steps and you will be able to fix your problem
Back up your information to an external medium such as an external hard drive or a flash drive. The install process allows you to transfer current files to a fresh operating system (OS) install, but it is always best to be prepared with a backup of your files in case something goes wrong.
Insert the first install CD or DVD of the operating system software.
Restart your Mac Book or Mac Book Pro. Immediately hold down the "C" key as the computer reboots. This will cause your Mac Book to boot from the CD or DVD you inserted.
See the "Welcome" dialog that asks you to pick a language. It may also ask you to agree to the terms and conditions of the software install. Depending upon which OS version you are using, you might see the software perform several checks on your system. If you do not see this, do not worry.
5
Choose where to install the OS. You're most likely going to select your primary hard drive. If you have one or more partitions on your hard drive, you can select any of them as long as they are large enough.
6
Choose your install. You'll be presented with three options: "Upgrade," "Archive and Install," and "Erase and Install."
Choose "Update" to simply update the current OS install on your Mac Book. All your data, files and programs will remain intact.
Choose "Archive and Install" if you need to back up all the data on your system and import it into a fresh install of the software. You will need to reinstall much of your non-Apple software if you choose this option.
Pick "Erase and Install" if you want to erase everything on your hard drive and install a fresh version of the OS. None of your data will remain if you pick this option. This is effectively a factory reset of your Mac Book, as none of your personal settings or data will remain.
7
Choose the right setting. If you choose "Archive and Install," be sure to check the box to preserve your user and network settings. This will ensure your previous profile data is installed in the new software installation. Once you've chosen an option, select it. Click "OK."
8
Relax. The Apple OS install will take care of everything from this point. You may be prompted along the way with a few questions, but the install should be mostly automatic. When the install is complete, your Mac Book will restart.
9
Restore your data. If you chose "Upgrade" or "Archive and Install," the software will prompt you to migrate your old data to the new system. Follow the instructions to ensure your old settings and programs are transferred to the fresh install of the software.
Thanks.
Have a great day
Sep 17, 2010 | Computers & Internet
Battery will not charge. Best buy and IT dept
The issue could also be with the MagSafe adapter because if that power cord is not working, your Macbook's battery will fail to charge as well.
If you are able to get your MagSafe Power adapter tested and it works, then yes, the Best Buy Geek Squad you communicated would, be correct in assessing that the issue is more than likely the main logic board due to the connectivity from the MagSafe port to the main logic board.
So my suggestion, before allowing any tech support service to conclude that the main logic board is the reason your battery will not charge, have that MagSafe power adapter checked and actually, now that I think about it, have your battery checked as well, because it may be defective.
It is not uncommon for a Macbook battery to become defective early in its use.
To bring this answer full circle for you, have these components checked first, before accepting that the main logic board is the issue.
If you need to visit an Apple retail store Genius bar, I would recommend you do, because they have all the tools needed to check your Macbook and provide you the full diagnostics to isolate the reason for the battery not charging.
To find the nearest Apple retail store near you, just click this link:
http://www.apple.com/retail
Working to provide options to save you money here!
Thanks for using FixYa Support.
Best Regards,
-Terry
Mar 16, 2010 | Apple MacBook Mac Notebook
Forgot my password and master password and I'm locked out my mac book
Customer forgot password
If the customer forgot the password for the computer:
1. Insert the Software Install and Restore DVD.
2. Restart the computer while holding down the C key on the keyboard.
3. When the installer appears, chose Reset Password from the Installer menu
4. Follow the on-screen instructions.
Here is the link to the user manual and below that is the factory service manual...
http://manuals.info.apple.com/en_US/PowerBookG4_15inch1GHz-867MHzGettingStarted.PDF
http://tim.id.au/laptops/apple/PowerBook%20G4%20(15-inch%20FW800).pdf
Oct 05, 2009 | Apple 15" PowerBook G4 Aluminum 1.67 GHz...
Every time i put a cd in the cd holder it ejects - different cd's and the same problem
the cd drive on your model has a safety feature, where if the drive lens is too dirty or scratched it will refuse any cd inserted. an apple repair store or a trip to geek squad 1-800-geek-squad may be necessary. thank you for using fixya!
May 03, 2009 | Apple MacBook PC Notebook
Need to re boot G4 apple note book, have lost my disks
You cannot download the software. Best Buys or your local Apple store carries the software.
You would have to purchase the Mac OS X cd set.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Dec 07, 2008 | Apple iBook Mac Notebook
Password Issues
What you are going to have to do is re-install all software. If they preset the passwords on your computer, and mispelt anything it has effected it. Take it back to them and get them to fix it for you is the best way. If you computer is password protected from start up, you will have to do it the way i suggested. But I would suggest taking it back to them to do the re-install.
Jun 08, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
HELP
If warranty, no body better then Apple. I've heard of good and bad stories from Geek Squad, so I guess it depends what you need.
Apr 24, 2008 | Apple MacBook Pro Notebook
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
82 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
