Question about Samsung RB1955VQ Bottom Freezer Refrigerator
FAN NOT TURNING IN FRIGE COMPARTMENT AND TEMPERATURE READING ON DISPLAY IS WRONG.
I'm not an expert, but I did notice on other posts that the fan sometimes freezes up causing problems like this. Other people fixed it by defrosted their fridge for 24-48 hours, and this allowed the ice to melt and allowed the fan to start turning again, and all was fine . . . until it happened again in a year's time.
Supposedly, set the temp at 4-6C to stop this.
Posted on Jul 28, 2008
My frige & freezer do not cool,light & freezer fan run,compressor & coil fan do not run,air is blowing out of air vent in freezer,no cooling at all
If the compressor isn't running, the refrigerator or freezer won't cool - period. Hopefully, by now, you've had a repair technician come and troubleshoot the problem.
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
My amana arb224rcw freezer is working frige quit what is wrong?
In most cases it will be the defrost control or 67001036 Defrost Timer
Because I don't have your freezer temperature I must include the=> 67003410 Air Damper Assembly
Look inside the fresh food section and behind the control panel where you adjust temperature. I want you to find the 67001036 Defrost Timer
and with a flathead screwdriver turn the defrost timer slowly clockwise untill the compressor and fans stop. Leave like that for thirty minutes. If the timer does not restart the fans and compressor simply replace the defrost timer if you need to turn to restart fan and compressor. I have more to explain of other cause for this so let me know how turning defrost timer like explained above turns out. This is forcing defrost but it will explain with other parts that may have failed also..I am here to help Thanks Sea Breeze
Apr 20, 2013 | Refrigerators
My ge profile refrigerator evaporator fan motor stops while the compressor is running
this is normal as if one compartment is cold enough but not the other compartment the sealed system has a valve in the refrigerant circulation system to channel the refrigerant flow to the compartment that is calling for cooling so that fan will cease operation in the compartment thats cool enough
Dec 14, 2012 | GE Profile Stainless Bottom-Freezer...
Hi i have turbochef speed oven in subway and on display show F6 ec Temp . what is problem
F6 faults occured when temperature reached to 150 degree faharanite in the electrical compartment.
Solutions
1. Clean the dust in the electrical compartment.
2. There is an temperature sensor on the controle board which gets dirty and throw wrong values.Clean it and then try.
3. Check the exaust fan in the top rear location is working properly.
4.Check for proper air ventillation.
Apr 15, 2011 | TurboChef TORNADO Electric Oven
We just started our new Sharp refrigerator (type: SJ-PT690R) yesterday evening after five hours of delivery. We set the temperature of the freezer & refrigerator at (-18 & 5) respectively. It is...
The fresh food compartment should be set to approx. 35 -37 degrees. Setting the fresh food compartment to a temperature below freezing does not compute and will not display an illogical reading. Adjust your settings according to your users manual and wait 24 hrs. before making any other adjustments
Oct 10, 2017 | Refrigerators
Light on no fan
it sounds as though the thermostat is faulty not bringing the compressor on and the defrost timer is turning the fan off and on as it should do
May 02, 2009 | GALAXY Microsystems 63702 Top Freezer...
Not keeping cold temperature and can smell plastic from heat
Sounds like the condenser fan motor is either jammed or has failed. if you wil pull the refrig from the wall and remove the lower compartment cover you will see the fan I'm reffering to as well as the condenser coil and compressor. if the fan has failed you can put a house fan blowing into this compartment to keep the unit operational until you can get it repaired. thanks for using FixYa Peyton
Feb 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
95 grand am radiator fan only runs with AC on
Cooling Fan Temp Sensor is the First thing You Check (with what you have described) Cooling Fan Should ALways come On When The A/C is turned On as A/C Adds A Load to Engine, If Temp Sensor is Faulty it Will Not Give GROUND Signal to ECM >For COOLING FAN >RELAY to Give ground and turn ON The Fan.
There ARE 2 temp Sensors that Serve Different Purposes 1 is for Dash READING GAGE & Or TEMP LIGHT the Other is For ECM or Fan Relay (SAME Thing) you Said>""can disconnect the sensor and fan continues to run" < This Leads me to think you Changed the Wrong One. Not Questioning your Skills Just Here to Help.
TEMP SENSOR FOR 3.1L V6 is Located upper RH rear of engine compartment, near exhaust system. Temp SENSOR for 2.3L Engine is Located in LH rear of engine compartment.
I Hope this Helps Lead you to a NON-OVERHEATING Pontiac.
Good Luck and Have A Great Evening. rejakwilson
Feb 04, 2009 | 1995 Pontiac Grand Am
Samsung SRS615DP Refrigerator
The temperature indicated is wrong because the thermostat sensor is faulty.
The faulty sensor (thermistor) send wrong info to display, and as it is also a thermic switch it turns off the compressor before it reaches temperature.
Insert model number here and get replacement part. On the website you also find info on replacement.
Jul 10, 2008 | Ovens
LG BOTTOM FREEZER FRIGE
It's all in the controls. There is a "flapper" or door between the freezer compartment and the fresh food compartment. Other than the fan not operating, there is nothing else that would affect the temperature. The higher you set your freezer, the warmer the fresh food compartment will be. As long as your freezer is working, and you can hear the fan turn on, it's a control issue.
Oct 26, 2007 | LG LRBN20510WW Bottom Freezer Refrigerator
Samsung RB1955VQ Bottom Freezer Refrigerator Logo
121 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
