Question about Philips GOGEAR SA6045 MP3 Player
Problem solving can't copy or delete files how do i delet songs and files
  • 2 more comments
  • Anonymous Nov 28, 2008
    i can not get things to download, can't get anywhere to delete pic's and songs? Help please
  • Anonymous Nov 29, 2008
    i cant get any thing to delete not even songs!!! and it wont downlad songs either!!!
  • liz0507 Dec 01, 2008
    i need to know how to delete songs on the mp3 player?
  • Anonymous Jan 11, 2009
    I cannot delete any songs, don't know how. My mum lost the phillips CD that could maybe have said. And I do not know how to download songs. I am 10. My mp3 player is a Phillips Go Gear. all I know
MOST MP3 PLAYERS ARE RECONIZED AS A USB MASS STORAGE DEVICE. PLUG IT INTO YOUR COMPUTER. GO TO MY COMPUTER AND IT SHOULD BE THERE AS REMOVABLE STORAGE. DOUBLE CLICK THEN YOU CAN ADD OR DELETE FILES AS YOU PLEASE
Posted on Jan 12, 2009
You can't delete directly from the mp3 player buy you have to connect it to your pc and delete the items you no longer need from windows media. That's how I figured it all out.
Posted on Dec 22, 2008
I CAN NOT DELETE FILES FROM MY PHILIPS GOGEAR 4GB!!!
Posted on Dec 19, 2008
This gogear sa6045 down loaded from my computer vides, documents pictures and my songs.
i only wanted songs
how do i remove videos and pictures
Posted on Jul 25, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: i can't delete the doubles
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
http://www.sandisk.com/DriverDownload/driverList.asp
-Tha Mp3 Doctor
Posted on May 23, 2008
  • 37 Answers
SOURCE: i can not add or delete files/songs on my mp3 rca5200
FIRST OF ALL CHANGE YOUR FILE ATTIBUTES. IT MIGHT BE READ-ONLY. YOU CAN CHECK THE ATTRIBUTES BY RGHT CLICKING ON A PARTICULAR FILE AND GO TO PROPERTIES. NOW UN-TICK THE READ-ONLY ATTRIBUTES AND CLICK OK.
NOW YOUR PROBLEM MUST SOLVED. IF THE PROBLEM STILL EXIST JUST PUT YOUR MEMORY CARD INTO A CARD READER AND THEN YOU CAN ADD OR DELETE SONGS EASILY.
MOST OF PEOPLE USESIS A CARD READER FOR A SPEEDY FILE TRANSFER BETWEEN YOUR MEMORY CARD AND A LAPTOP.
HOPE THIS SOLUTIONS HELPS U.
PLS. RATE MY SOLUTION.
NICE DAY.
KETAN.
Posted on Feb 17, 2009
  • 52 Answers
SOURCE: Multiple copies of songs on sansa e250. Unable to delete them.
this will be bery hard for you you need a pc and erase all the files one-one My suggestion format the sansa and clic your pc ONLY ONCE DUD {RATE ME}
Posted on May 16, 2009
hunter19_46m
  • 7482 Answers
SOURCE: cannot delete files
Try this solution to your proplem
Hook up your mp3 player to your computer Go to your desktop and double left click on "My Computer" When it opens you will see listing that says "Devices with Removal Storage" your mp3 player should be listed there. Right click on your mp3 player, and a window will open, right click on "Open" and now your files/songs should be visible. Hold the left click down and drag it across all the files/songs that you do not want this will highlight the files/songs you do not want, release, right click and then click on "Delete" Now you mp3 player should be clear of the files/songs you do not want. Be careful and do not delete files needed to operate your MP3 player. Good Luck, I hope this helps Please rate me, Thank You
Posted on Dec 12, 2009
  • 201 Answers
SOURCE: How do I delete songs or bad files? Is there any
The easiest way to delete songs or files on your Sansa is to connect it to your computer, open up "My Computer", double-click on the Sansa, then find the files inside the Sansa and delete them using Windows Explorer. Note that if these files are also on your computer's hard drive, and you're using a syncing tool (such as Windows Media Player) to sync songs from your computer to your Sansa, they may be copied back on your Sansa next time you sync, so you'll need to either delete or move the songs on your computer's hard drive, as well.
Whether you can repair a bad file depends on the contents of the file and the nature of the damage. If you believe that you have MP3s that are corrupted, there are utilities out there which will attempt to fix them. Google for "repair corrupted mp3" (or substitute "mp3" with whatever file type you're trying to repair) to find these utilities.
Posted on Feb 11, 2010
My memory card wont let me delete songs what can i do? the song i want to delete worked for two days ,then when i came to delete it , it said that the file is "corrupted" so everytime i try to delete , it...
SAVE YOUR CURRENT SONGS TO YOUR COMPUTER.THEN FORMAT YOUR MEMORY CARD.THEN COPY THE SONGS WHICH YOU WANT BACK TO THE PLAYER.DONT PUT THE CORRUPTED FILE BACK THIS TIME.HOPE THIS HELPS
Mar 06, 2010 | Coby MPC-848 MP3 Player
How do i delete multiply copies of the same song?
Did you try to go from the Main Menu into the EXPLORER ?
Explorer Controls
When you choose EXPLORER mode from the Main
menu, you will see the File Explorer screen. You can
find and delete files or folders from the player.
Function Key Action
To browse through the list of
files & folders
Press <UP> or
<DOWN>
To select a folder Press <ENTER>
To return to the previous screen Press <LEFT>
To delete a selected item Press <MENU>
To return to the Main menu Hold <MENU>
Aug 13, 2009 | Coby MP-610 MP3 Player
May 13, 2009 | SanDisk Sansa e250 MP3 Player
I can not add or delete files/songs on my mp3 rca5200
NICE DAY.
KETAN.
Feb 17, 2009 | RCA M5002 MP3 Player
Deletsongs
Use Windows Media Player:
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Dec 12, 2008 | SanDisk Sansa e250 MP3 Player
Can't delete songs from coby mp-c827 player
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
My Directions:
Jul 24, 2008 | Coby MP-C827 MP3 Player
Songs
Use Windows Media Player to delete them:
My Directions:
Apr 25, 2008 | iLO MP3 Player
Deleting song
My Directions:
Apr 19, 2008 | iLO MP3 Player
How to delete songs from my mp3 player
My Directions:
Feb 23, 2008 | Memorex MMP8565 MP3 Player
Problem solving
i can't open up drivers
Sep 24, 2007 | Audio Players & Recorders
Philips GOGEAR SA6045 MP3 Player Logo
154 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
