Question about Refrigerators
Ge refridgerator model gsl25jfpe bs
The water dispenser is not dispensing. I did change the filter. Disconnected the coupling from underneath the freezer and the water does come out from the refridgerator side. I unplugged the fridge for 30 seconds. I turned up the water pressure. I even held a hair dryer next to the top dispensing hose, thinking the line that goes up the freezer door might be frozen. I also held in the dispenser for 3 min. to possibly end any air in the line. We recently turned off our water, which is a well. Maybe that has something to do with it. please help.
thank you
  • 5 more comments
  • rogersc99 Oct 22, 2008
    I have GSL251GRB BS Stainless side by side. Ice is fine but not dispense water? How to fix it?
  • biesterv Dec 17, 2008
    Same problem, I get ice but no water. Just stopped working...
  • skorteks Dec 18, 2008
    I have the same issue. Have checked the hose at the base of the door, the switch at the back of the fridge and water pressure. All are good.
  • dchance Dec 30, 2008
    I have the same issue. The water seems to be clogged near the filter. When i pull the filter, water spills out. I changed the filter but nothing.
  • geecue22 Jan 06, 2009
  • tom451 Jan 12, 2009
    I have no water and plenty of ice. The solution posted mentions that another symptom is frozen food on the refrig side - I do NOT have this symptom. Has anyone resolved this as yet? Can you share the solution?
  • Anonymous Apr 27, 2009
    ice is being made but the water is not dispensing. This has happened before and has always fixed itself with time. This has been going on for more than 24 hours now. Going to try to look into the baffle fan but I don't see any plastic cover or door near the top on the back.
I have a gsl25jfpe bs ge regrigerator and the baffle motor that controls air flow from the freezer to the refrigerator is out. This had been causing everthing in the fridge to freeze and cause the water to stop working due to water freezing in the storage tank. The baffle is in the back top of the fridge covered with a plastic cover. Remove plastic cover to check baffle function.
Posted on Nov 08, 2008
GSL25JFPE-BS Side by Side refrigerator compressor and condensor fan isn't coming on
GE refridgerators have what they call a main dome control board. This is located on the back of the machine, usually closer to one side or the other and about halfway up the machine. This board really controls everything, even as far as the dispenser in the door. I personally think this is a poor design, even though they look awesome cosmetically. Locate your model number, usually in the refridgerator side somewhere, and go to to order the part. This is becuase they have a return policy that no one can beat. If you install the part and it doesn't work they will take it back and refund you, where as any other part distributor have a no return policy on electronic parts. Good Luck, but you won't need it. This is an easy repair.
May 29, 2012 | GE Refrigerators
GE GSL25IGRE BS slow water dispenser
Sounds like your water valve may need changing, and has filled up with sediment, slowing the water flow.
Mar 29, 2010 | GE Profile Arctica Stainless Steel Top...
My water dispenser will not dispense water. I
you just need to defrost turn off fridg. over night it is frozen in the frezzer door
Feb 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
Refridgerator Not Dispensing Water
did the water work before you changed the filter . water when chilled may have frozen in line. . i would before major work adjust tempt of both freezer and frig . if too cold / forzen line .. are you freezing any thing in crispers. this is a good clue.. hope this might help .. mm
Dec 07, 2009 | Kitchen Ranges
I have a GE model GSL22JFPH BS refridgerater and
Then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . There is a heater for the water dispensor tube , pt # WR49X10173 , which should keep this from happening again .
Nov 18, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Water not dispensing ,side by side gsh25sgpa
make sure the water line is not kinked behind the refridgerator.
Jul 04, 2009 | GE GSH25JFR Side by Side Refrigerator
No water from door dispenser
you have a frozen wtr line inside door turn it off for a day or 2 then try it again but this time palce a thermometer in frezeer and keep temps at 0 to 4 degrees if it drops below 0 then the line will freeze again
Oct 30, 2008 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
1,127 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
