Question about Dishwashers
Dishwasher tablet doesn't dissolve - Dishwashers
  • Anonymous Aug 28, 2008
    The tablet compartment does open to release the tablet but I find it undissolved on the bottom. Dishes are not clean
Need more information. What kind of tablet? What kind of dishwasher?
Posted on Jul 20, 2008
  • 55 Answers
  1. check if water is hot- you should see hot vapor when you open during wash cycle. Try another type of tablet. try powder.-- put powder in the bottom of unit instead of the cage.
Posted on Aug 28, 2008
rylee_smith
  • 8619 Answers
SOURCE: Neff S5433 Dishwasher - Detergent tablet not dissolving
Hi!
Please run the machine without detergent for 2-3 washes. Also try using a little hot water. Also, don't used cleaner and softener together but add softener on the last rinse.
Posted on Feb 22, 2009
here2helpBSH
  • 27 Answers
SOURCE: dishwasher tablet doesn't dissolve
yes a heater problem can definitely be your issue. i dont have access to euroart information to help you properly diagnose whats wrong but you should have water in the dishwasher so hot it steams. if it doesnt steam then you might have a bad (element, heat assy, or control board.) sometimes its even a broken wire
Posted on Mar 19, 2009
VtToolMan
  • 704 Answers
SOURCE: Dishwasher 3 in 1 detergent tablet not dissolving.
I believe that the instructions for using these 3-in-1 tablets is to place it in the open dish detergent cup, rather than in the closable compartment, since the tablet needs to get doused by a lot of water in oder to fully dissolve and be effective in getting the dishes clean.
Since the tablets are designed to dissolve more slowly, they are able to be used for the entire range of washing cycles. If it's a constant problem and you don's have an open detergent cup below or next to your closed detergent dispenser, just toss it into the bottom of the dishwasher instead.
The reason that the tablet isn't getting dissolved fully is because the door is preventing the tablet from dropping all the way out and the door is shielding the tablet from quite a bit of water spray.
Another option is to take a look at your owners manual for the dishwasher and see if they recommend these all-in-one tablets versus regular powered detergent and liquid rinse aid.
Hope that helps and best regards!
Posted on Jul 31, 2009
SOURCE: tablet is not dissolving from my dishwasher drawer
If it drops to the bottom when you open the dishwasher door - your soap dispenser is blocked by the rack or an utencil protruding from the rack. Make sure both racks slide in all the way to the back. (hint: check the middle spray arm inlet, make sure it aligns with the tube on back.
Good luck)
Posted on Oct 22, 2009
Testimonial: "thats great thanks i'll check it"
SOURCE: I have a Neff Dishwasher S5443X2 and the
Either:
  1. the water does not get into the dishwasher open the dishwasher 3-4 times during cycle, you should see some water at least once, if not - check water valve, water level float and water pressure.
  2. the pump is clogged - there is water, the motor will run but no water is circulated. Check pump filters, check chopper and impeller.
  3. motor in main pump is not working - could be caused by something stuck on the impeller or chopper or could be a problem with the motor itself or control board. Check if line voltage is coming to the motor during wash/rinse cycle.
Good luck,
Vlad
First Choice Appliance
Posted on Sep 11, 2010
Seriel PAA41010 dishwasher does not dissolve tablets
Tablets dissolve in the water, normally by the drawer opening and the tablet falling out into the wash. Is the door sticking (tablet door not loading door) or is the wash arm not spinning freely or blocked? These can interfere with the cycle
Nov 02, 2017 | Dishwashers
Think the element or thermastate has gone as it's not disolving the tablets can I fix it myself
One of the first things to check if the dishwasher detergent is not dissolving is the water temperature that is in the dishwasher. If the water temperature is too cold, it may not be able to dissolve the tablet effectively. . If it is below 130 degrees Fahrenheit the setting needs to be increased or contact a plumber for assistance.
Read more : http://www.ehow.com/info_8597080_dishwasher-tablet-not-dissolving.html The Dishwasher Tablet Is Not Dissolving eHow
Nov 18, 2015 | Dishwashers
Hotpoint FDW60 DishwasherTablet does not dissolve
our HOTPOINT FDW60 is not working right?
the tablet is not disolving inside right how will i fix it?
Feb 07, 2013 | Hotpoint 24 in. FDW60 Free-standing...
The soap dispenser opens & the soap tablet (power ball) drops to the bottom but doesn't dissolve
1. Water temp is wrong should be 140-145
2. spray arms clogged with food
3. water valve is not letter the correct amount of water in
after it fill's check to see water amount in bottom , dose it sound like it is starving for water ? it would sound like it was surging
Dec 01, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Tablet not dissolving, and dishes dirty
Hi,Nicole, try this:
Run the water nearest the dishwasher (usually the sink), getting the water as hot as possible immediately before starting the dishwasher. This will help getting the tablet to dissolve.
--Best regards, --W/D--
Apr 05, 2011 | Bosch Dishwashers
My tablet will not dissolve ?
The usual cause for dishwasher tablets failing to fully dissolve is a failed dishwasher heating element.
Sep 21, 2010 | Beko Dishwashers
Jul 31, 2009 | Electrolux Dishwashers
Hi!
Feb 22, 2009 | Neff 24 in. S5456 Built-in Dishwasher
Tablets not dissolving
either there is not enough water (check water valve) or the pump filters are clogged (check and clean as necessary)
Jul 06, 2008 | Maytag 24 in. MDB8600AW Jetclean II...
Dishwashers Logo
513 people viewed this question
Top Dishwashers Experts
