Question about Canon PIXMA MP830 All-In-One InkJet Printer
Not turning on
I had a power outage and the printer is not turning on, switched outlets, and tips?
  • wind woman Jul 23, 2008
    So where do you find the fuse? I have the same problem.
    Scholar:
  • 191 Answers
Well you need to check the fuse inside if you can open and if you are comfortable or else take help of a technician, it is quite possible that the powersupply has gone bad too, best of luck.
Posted on Jul 20, 2008
Viore tv won't power up after power outage.
I would first test the outlet. Unplug the TV and plug in your vacuum or other loud or bright object. Turn on test object - if there is no operation, then you have a tripped circuit breaker. Find the electrical panel ( Grey box mounted into a wall, usually in a closet). Find the tripped breaker ( typically the switch will be halfway between on and off, and many have a red indicator by the switch base). Turn switch to off fully, then back to on.
Retest outlet.
If still no power to outlet, unplug everything from that outlet and call an electrician - there may be a serious problem with the wiring!
Hope this helps!!
Dec 02, 2013 | Televison & Video
Olevia LT20s
Check power outlet. Connect TV to a different power outlet. Switch off TV manually, switch off power input, remove plug and cool it off for 48 hours and retry. If problem persists, it might need attention by a qualified service technician.
Jul 22, 2012 | Televison & Video
Cooktop burner switches do not ignite when turned onn
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 15, 2010 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
My power to the house went out. now my printer
That outlet may have been blown from the power outage. Try changing the fuse in your fuse box or reset the breaker
Nov 27, 2009 | Lexmark Z735 InkJet Printer
Printer offline after power outage. Restore?
Hi, Joy.
Give these a try:
1. Right-click on your printer icon and select "Offline" to uncheck and bring it back Online again.
2. Let your printer cool down for at least 5 minutes. Power it on again.
3. If you are connected to a power surge protector, flip the switch and power the printer on to see if the printer powers on again.
4. Connect your printer to a different outlet.
5. If not a power issue, remove and reinstall the printer driver.
Hope this helps.
Sep 22, 2009 | HP Office Equipment & Supplies
Canon PIXMA ip4500 will not turn on
Sounds like the power outage was a power surge and destroyed your printer, especially if your printer was not plugged into a power surge protector strip. Check with others in your apartment to see if they experienced the same. If so, your landlord may be responsible and can put in a claim. If your printer is still under warranty, contact Canon. Also, check to see if this item is covered by tenant insurance, if you have coverage. Hope this helps.
Jul 16, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Power outage now printer won't work
1. Have you tried turning your printer power button off.... unplugging your printer open all the door cover and close them back.. plug your printer into another wall outlet....then turn it back on.... if it turns back on...(GREAT) 2. If it does not(TURN BACK ON).durning a power outage it can damage the main board in your printer...and if so you will need to have it serviced.....
Jun 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Computer wont turn back on after power outage
Try unplugging the cord from the back of the computer for about 5 minutes and then try it again
Apr 14, 2009 | Compaq Computers & Internet
There was a power outage in the middle of the night. My computer was turned on during the outage (Presario 2200). Now it will not turn on ; it is plugged in (was in a surge protecting power strip during...
Please try to remove the battery and than try to switch on the laptop directly from mains power and if it works than its your battery problem or if it still not starts than there is possibility of some components of your laptop may fired due power fluctuation. So go and contact service station.
Jan 08, 2009 | HP Compaq Presario 2200 Notebook
Power outage=shut down
You do not say your location- so this may not be relevant to you. If in UK - check the power cord fuse. If it is a model that relies on an external power supply- try to find anther of the same specification. Other than that presume it has died
Jul 09, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon PIXMA MP830 All-In-One InkJet Printer Logo
old marine
old marine
