Dishwashers Logo
Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
There is a white residue remaining on dishes after every washing/drying. If I add 1/4 cup lime-a-way, it helps. I have changed detergents, from Cascade to Finish, no difference. And, I have actually used Cascade in this machine since it was new. I keep the cups filled with Jet Dry. Dishes are rinsed clean before putting in washer. I have tried all settings from light on up. We totally clean all dishes before putting in washer. I have checked to make sure all holes are open in the water "arms." This has been going on for about the last 3 months I don't know what else to try. I am wondering if there is a problem with the timer and they aren't rinsing long enough or not enough water is getting in. We have not changed anything since machine was installed. I have used vinegar, too. Please let me know what I need to do, including a service call.
Kelly
Level 3:
  • Maytag Master 3,740 Answers
  • Posted on Jan 30, 2011
Kelly
Maytag Master
Level 3:
Answers
3740
Questions
Helped
2161869
Points
12091
Hi and welcome to FixYa, I am Kelly.
First question is the unit under warranty? If it is DO NOT do anything other than the wash arm inspection that you already did on the inside of the unit. You will void the warranty.
Now outside the unit here is what you should do. Check the drain ports from the sink / garbage disposal connection all the ay back to where it connects to the bottom of the dishwasher for obstructions. The garbage disposal port is the source of many dishwasher drain / dirty post cycle dishes problems. This MUST also include taking the Air-Gap apart but lifting off the cover... unscrewing the inner cap nut and inspecting for food particles. The Air-Gaps are notorious for catching food particles just under the upper U cap that reverses the water flow direction. As you take the Air-Gap nut off and lift the inner cap.. NOTE the installed position. It only fits in ONE WAY and can give you fits! Just make sure you align the inner U cap in the original position.
Residual water in the bottom of the dishwasher post cycle is a sure sign of a drain problem.
One other thing you can also use to rid yourself of spotted post cycle dishes is a product called "Jet Dry" Rinse Agent. (assuming there are no drain problems) It comes in bottles for units with internal rinse dispensers and hanging baskets for those units without rinse dispensers.
If you unit is not under warranty there is more that can be done. I do however think that if you perform the above checks that you will resolve the issue.
Thanks for choosing FixYa,
Kelly
5 Related Answers
Anonymous
  • 108 Answers
  • Posted on Jul 28, 2009
SOURCE: the detergent dispenser opens but the cascade
Maybe that is a bit much... I thought of something else you might check... there is a screen at the bottom of the dishwasher... make sure it is clean so that water can keep recirculating.
The thing about adding water is that if you add the water at the beginning, it is going to circulate for 3 minutes or so and then dump out the water and attempt to refill. Most machines do a couple "rinse off" cycles before the soap dispenser opens and the machine washes the dishes for a long time. So you have to put the water in after you hear the dispenser "pop" open.
I'm not completely sure about the Kitchen Aid, but their might be a way to adjust the time that the water inlet valve stays open at the beginning of the cycle... you'll have to check your manual.
Mike
  • 677 Answers
  • Posted on Mar 18, 2010
SOURCE: White Filmy residue
The problem is hard water. Go to www.dishwasherfilter.com and get their new product. It filters the water and takes out the hard minerals that cause spots and clog dishwashers. It is very affordable and has a money back guarantee.
Anonymous
  • 43501 Answers
  • Posted on Sep 30, 2010
SOURCE: Kenmore Dishwasher 363.165 model not rinsing right
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
ewe
Anonymous
  • 43501 Answers
  • Posted on Feb 27, 2011
SOURCE: I've had my dishwasher (GU2455XTSB3) for almost 2
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Anonymous
  • 43501 Answers
  • Posted on Mar 29, 2011
SOURCE: #1 Dishes and glasses are not clean. Glasses come
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
DishwasherResidue and Film on Dishes
heatman101
My dishwasher is left quite wet inside after washing dishes. Is this unusual, especially for an expensive Viking dishwasher that is brand new?
make sure you have selected the heated dry option. for the smell, add a 1/2 cup of white vinegar to wash cycle.
Built-in dishwasher. dishes not clean, plus nasty white residue on everything...
Hi
The white residue is from the new environmentally safe soap. Check your soap and see if it is phosphate free soap and that will be your issue. Also either you have hard water or you're seeing either calcium or lime deposits. You should use the jet dry for every load. There should never be any suds in a dishwasher. Do not use liquid dish detergent for the dishwasher.Try running a load without dishes, using vinegar, or a bottle of Dishwasher Magic. Another possibility could be you're not getting enough water. The level should be close to the heater(check your tech sheet to be sure). The water temp should be at least 140 deg.F (no matter what the box says) Also, use a good brand of detergent (Cascade) and be sure your wetting Agent dispenser is full. (jet dry)You should not have to pre-wash your dishes..just scrape them well.The detergent actually needs some dirty dishes to work properly..fats, protien, etc. to make up 1 more chemical for the detergent.Another important step is to run the hot water faucet before running your d/w to "purge" the cold water out of the line.
Also check this links for some helpful information:-
http://www.appliance-repair-it.com/dishwasher-leaves-white-film-on-dishes.html
http://askville.amazon.com/dishwasher-washes-dishes-clean-white-residue-problem/AnswerViewer.do?requestId=6117170
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=6192
Please get back to us if you have further query else please accept this particular suggestion.
Thanks for contacting fixya.com
1helpful
White powdery film is on dishes at end of cycle.
Too much detergent. the amount of detergent should vary with the amound of soil left on the dishes. Most users will pre wash their dishes in the sink, but still use the full recommended amount of detergent. There is no soil for the detergent to bind with, so it builds up in the pipework of your dishwasher. when the water evaporates during the drying cycle, the detergent residue is left behind on your dishes. Run a cycle or two with your dishwasher empty. add a cup of white vinegar to each cycle, but dont add any more detergent. After that, cut your detergent amount by half, and see if your issues go away. if not, please post the model and manufacturer of your dishwasher.
Nov 18, 2010 • Dishwashers
1helpful
White powder residue left on dishes after washing. I run hot water before running dishwasher, use Cascade powder (fill dispenser less than 1/2 full per installer and do not use prewash detergent...
heatman101
Both dish drawers are leaving a chalky dried on residue on the dishes. I ran a cleaning detergent in both drawers, made sure salt in water softener was filled, checked filters, and they are still leaving...
heatman101
I've had my dishwasher (GU2455XTSB3) for almost 2 years. The first year and half were great. I always use the same cycle (with options) and it took approximately 1.5 hours to complete. Now it takes over 3...
heatman101
3helpful
2answers
Even after a wash-a white detergent residue is left.
I have a Whirlpool Gold dishwasher and had the same trouble. I found the solution. Fill the detergent dispenser to the top with Cascade Complete liquid gel - it is in a green bottle, then put a half a cup of white vinegar in the bottom of the tub before you start the dishwasher. I have tried them all and Cascade Complete Gel works best. Don't use powder. It really builds-up on my dishes and only the gel keeps the film off my dishes.
I also add Jet Dry in the rinse-aid dispenser but I have a friend who use vinegar in that too. The dishes come out sparkling clean with no film or white build-up. If they still are filmy after three washes using this method, then you may have some build-up in the dishwasher and you can put a cup or two of white vinegar in the bottom - with no detergent or dishes and wash and rinse well. That helps get rid of build-up.
1helpful
2answers
We bought a used Roper dishwasher not too long
I was having the same problem with a Roper dishwasher and the Palmolive Eco gel. After doing a little research, I found that the detergent I was using doesn't work well with hard water. I emptied the machine, then poured in 2 cups of white vinegar and ran it on a complete cycle. This cleaned out any hard water residue build up inside. I then begin using electrasol with jet dry tablets for detergent and filling the rinse agent reservoir with white vinegar. I have had no problems since.
As for the heated dry, is it really heating or are you just feeling the heat left over from the very hot water used in the washing and rinsing?
Jun 12, 2009 • Dishwashers
1helpful
Where can I find a mnaual that can tell me how to de-lime a Hobart CRS66A Dishwasher?
I doubt that the user manual covers de-liming the Hobart Dishwasher.   If I owned this (fine, expensive) dishwasher, this is what I would do.
1.) Discard any generic, ultra-cheap detergent.  Stop using gels or tablets and only use powders.  Buy a box of brand name powder (like Electrosol or Cascade)  You will be amazed how much difference that will make because the newest generics have mineral bulk added that build up faster then hard water does on both the stainless steel enclosure plus the silverware and even plates.  White patches.  I LOVE generic products and saving money, but low end dishwasher powder is one place I no longer choose a generic product.
2.) Add two cups of white vinegar to the empty dishwasher and leave it there until the morning.  Run a quick cycle with no detergent added.  The vinegar will be pumped out immediately after you begin this quick cycle.
3.) As soon as the dishwasher fills with water during that quick cycle and begins a wash cycle, add two cups of white vinegar and close the door and allow to run the full wash cycle.
4.) When the dishwasher finishes the drain cycle and begins to fill again, open the dishwasher and check the enclosure for remaining "lime" deposits.  If they remain, keep adding 2 cups white vinegar each time the dishwasher refills and begins to wash/rinse again.
You should be delighted with the results. Long term, you should consider adding a whole house water softener and then reduce the amount of dishwasher (and laundry) detergent by one half.  Amazing increase in quality of life by adding a water softener.  You will be delighted.
Please post back with you results, OK?  Good Luck!
Apr 17, 2009 • Dishwashers
1helpful
My washing machine is leaving little residue on all my clothes after a complete wash, What are they? and how do you get rid of it, the washing machine is not yet a year old
Describe the residue. If it's oily (black, dk green) then the seal is out of the tranny and oil is getting into the tub. Dry cleaning is best for oil based stains. Liquid dish detergent is good also. On white it is tough to remove. Your washer will need a new transmission or replacing.
If it is powdery I'd guess a soap buildup, especially if you've recently changed detergents. The new detergent is breaking up the old soap scum in the outer drum and it is redepositing onto your clothes. This should wash out/off.
Tip: If it's a soap residue, fill washer full without clothes with hot water. Add 1 gallon white vinegar and more hot water until the unit if as full as possible. Agitate 15 minutes and drain. Rinse with a full level and drain.
Top Maytag Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
