Rolling bars from top to bottom - Televison & Video
  • 593 Answers
Ground problem on TV or attached device. Check outlet with receptacle tester. Then check ground bond solder joints for a dry (dull looking) solder joint, resolder all dry ground solders.
Posted on Jul 19, 2008
Problem rolling bars
It should be a main power regulator baord fault. Contact any service technician.
May 22, 2013 | Panasonic TCP50U2 50 in. TV
HOW TO CHANGE A BELT
Hi there...You will need a Phillips screwdriver to get the bottom cover off.Remove the screws and then remove the bottom cover.Clean out any excess dirt in the general area of the roller bar and motor assembly area.Place one end of the belt over the steel shaft of the motor and then roll the other end of the belt on to the end of the roller bar.placing the belt on the top of the roller bar and roll the bar slowly and feed the belt onto the roller bar until it is completely in place.Replace the bottom cover and put all the screw back in.
Plug your vacuum in and turn it on with the roller bar off the floor, in other words let it run for 10 seconds until you put it on the carpet allowing the belt to position itself properly on the roller bar.
Jul 03, 2012 | Kenmore 31913 Progressive Direct Drive...
Can you tell me how to thread a Graphic III laminator?
5-2 THREADING the LAMINATOR
1. Remove the supply roll mandrels and the feed tray. The supply roll mandrels are now ready to accept
loading of the film rolls, wound with the polyester (shiny) side out. When viewed from the front of the
machine, the core grippers on both the top and bottom supply roll mandrels should point toward the
heat shoes (and toward each other). The tension control knobs should be positioned on the right. Notice the
knobs are labeled "Top Right" and "Bottom Right". If you have rolls of film on which the material is wound
in the opposite direction (adhesive or dull side out) exchange the top and bottom supply roll mandrels so
the core gripper positions are reversed.
2. Slide a roll of film onto the top supply roll mandrel, turning the roll slightly to slide the gripper inside the
core. Center the roll. Make sure the dull side of the film is facing up and the shiny side is facing the
heat shoes during the threading. Scored marks on the supply roll mandrels provide a guide for proper
alignment of the two rolls of film to each other.
NOTE: The pointed metal pieces protruding from the body of the supply roll mandrels grip the cardboard core of the film supply roll to prevent slippage. When placing a roll of film on the mandrel, twist the film supply roll to
accommodate easier film loading.
3. With the roll aligned with the scored line on the right side of the mandrel, place it in the top bracket.
Place the left side of the shaft in its slot first then place the right side of the shaft in its slot, turning it as
needed. FOLLOW THE RECOMMENDED LOADING PROCEDURES CAREFULLY WHEN THREADING
FILM IN THE LAMINATOR. ACCURATE ALIGNMENT OF ROLLS WILL MINIMIZE WASTE AND HELP KEEP
THE LAMINATOR CLEAN.
4. While the machine is still cold, review the threading diagram. With the bottom roll of film centered on
the mandrel and the shiny side facing down, run the film under the bottom idler bar and pull towards
you.
5. Load and thread the top roll of film in the same manner as the bottom roll. Refer to the threading diagram. The
film should run under the silver stabilizer bar and over the front of the top heat shoe. Remember, the shiny
side of the film must always go against the shoe. The dull (adhesive) side must face away from the shoe.
Make sure the two rolls are aligned with each other before going to the next step.
6. Turn machine on and heat to the desired temperature.
7. With both rolls threaded and installed in their respective brackets, unwind enough film from the top roll
to reach the bottom of the bottom heat shoe. Next, unwind enough film from the bottom roll to reach the
top of the top heat shoe.
8. Now drape the film from the bottom roll against the film from the top roll on the top shoe. If the laminator is
hot, the exposed adhesive on the top web will hold the bottom web and make it easy to stick the two rolls
together. If you are threading the machine while it is cold, use tape to stick the bottom web against the top
web.
9. Tip the safety shield down into the laminating position. With the film draped over the two heat shoes, push
one edge of the threading card between the heat shoes so that the film is firmly positioned against the
laminating rollers. If a threading card is not available, any piece of card stock or poster board will work.
10. Make sure there is still enough slack in the web. Turn the drive switch to FORWARD, permitting the film and
feed board to pass through both sets of rubber rollers. Carefully monitor initial threading to be sure the web
reaches and passes through the pull (back) rollers. When the threading card has cleared the back of the
machine, move the drive switch to the center position (off). Whenever you want to remove the film and/or
laminated material from the back of the machine, use the zippy cutting tool provided with the laminator.
11. Slide the feed tray into position.
12. If the machine has the slitter option, make sure the slitters are disengaged (blades in the raise
position) and moved all the way to either side of the machine.
CAUTION: The laminator is designed to be run with the operator directly facing the
control panel and feed tray, not at an angle or from the side of the machine. For
operator safety, the safety shield must be in position over the upper heat shoe
when the machine is ON, or when the drive switch is in the forward position.
Dec 21, 2010 | Office Equipment & Supplies
My roll bars (back seat head rests) are stuck in the UP position and I can't close the top while they are up. How do I get them down mechanically, the guide shows plenty of info for the top but nothing...
just push the roll bar button in the up position like you raising the roll bar. hold it for about ten seconds or til you hear a click sound. basically your just going to reengage the mechanism again since the roll bar got deployed while driving. If thats not the case then you might have a separate problem but I would start there.
Sep 28, 2010 | 2000 Mercedes-Benz CLK
Faint black bar rolling from the bottom
if the bar is black or purple you can try to use a ground lift plug and see if your having a grounding issue.
Jan 15, 2010 | InFocus ScreenPlay 4805 Multimedia...
Rolling green horizontal bar from top to bottom,then bottom to top and so on. sometimes rolling fast,sometimes slow and sometimes the green bar stops in the middle of the screen.every once in a while the...
This TV needs a service adjustment done. Looks like a vertical or horizontal IC is failing. I'd go ahead, and shut off until services adjustment is made. Have you unplugged for a few minutes and plugged back in? However, I'd have a service tech look at it.
Oct 25, 2009 | Mitsubishi WS-48513 48" Rear Projection...
Hhow to save a pattern in fl studio and reuse the same in another
Open up the piano roll window for the sample you have selected. Use the highlight tool, which looks of a dashed square, to select the entire pattern by dragging your cursor from the top right corner of the piano roll diagonally to the left bottom corner of the piano roll. If you can't see all of the bars used, then try sizing the track in the piano roll closer together by placing your cursor on the square directly to the right of the horizontol scroll bar. Hold down the left click and move your mouse down to track the piano roll closer or move the mouse upwards to span it more. Select all of the bars used in the piano roll and click the down arrow in the very upright corner. Select Edit > Copy. This will copy all of the bars in the current piano roll. To paste the pattern simply click the down arrow again in the upright corner and select Edit > Paste in any piano roll.
Jan 20, 2009 | Image Line FL Studio 5 Producer Edition
Knocking from front right wheel
LOWER WISHBONE OR TIE ROD GO FOR THEM FRIST,THEN BUSHES (ANTI-ROLL)
Jun 06, 2008 | 2003 Audi A4 Cabriolet
Rolling lines
had a few with bad (go here) capacitors
good luck
please mark the post with a fixya
Feb 06, 2008 | Mitsubishi WS48511 48" Rear Projection...
Change Belt
Turn the vac. over, remove the bottom plate covering the brush roll, then on the bottom of the top cover, on each side there should be 2 slots when you can put a flat blade scredriver, pry up to release the tabs holding the cover on. The know will come off also when you do this, just put it back on when the put the cover back on. Put the belt on the brush roll and feed it thru the opening and stretch to put over the motor shaft. The top cover, push down to lock it.
Dec 23, 2007 | Vacuums
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
