Question about Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15
IW811 eco intuitive 8kg
Washer runs even though powered off at machine. Cycles not working properly. water running out at beginning of cycle. it's crazy!!
  • teraa Jul 20, 2008
    water running out at start of cycle and error fault 49. washing stacking up
  • teraa Sep 02, 2008
    Hi ngfam1,
    I actually didn't give a rating at all unbeknowing to me..... and may I say that the information you gave was excellent and has assisted me to seeking remedy. Thanx teraa
  • 639 Answers
Peace Friend,
ngfam1 At your service!
With an error code the only way to find and to repair this is,
First unplug the washer and wait a few minutes then restart it like rebooting your computer when its acting strange!
If it corrects the problem GREAT!!! WE WIN!
How old is the washer?
If the appliance is 10 years old or more you it may not be advisable to put good money into bad!
New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
Water,Electric and detergent! And put money back in your pocket!
The new appliance will pay for itself in only a few years!
If not only a trained laundry tech can make the electronic diagnoses.
Like we used to be able to fix my own cars, but not today they need diagnostic equipment!
Below I referred you to a great service nation wide!
If none of these tasks remedy the problem then here is a good company that's found nation wide.
A&E Factory Service
A&E has schedulers available to take appointments 24/7
And they do warranty work too, for most manufactures!
1(800) 905-9505
You will be fine
Bless You ngafm1
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OF
Posted on Aug 31, 2008
  • Neil
    Neil Sep 02, 2008
    Teraa,
    ngfam1 here,
    Why have you rated me inappropriate?
    Your problem could not be solved without a hands on
    repair and I can not come through the computer.
    As I recommended a few things to try to save you the service call first and told you the TRUTH!
    That you need service if these things i suggested fail!
    The truth like I tell my customers too! Even though some people don't want to hear truths!
    I was very cordial to you????????
    My family has been in the business of selling appliances for over 65 years!
    What was inappropriate????????
    Bless you,
    ngfam1
  • Peter1717 Feb 12, 2011
    ngfam1, dont put your advestisment after your solution this isnt the yellow pages!
    I also see your solutions are the same, call a technican! if we wanted to know this we would of called the manufacturer.
    Please only respond with real advise like the other experts.
WI815 Intuitive Eco - no cold water
IW Intuitive Eco.
Water valves have a rubber diaphragm that wares out
after some time,
So yes you are right water valves need replacing.
Apr 21, 2014 | Fisher and Paykel Washing Machines
Fisher & paykel IWL12 Fault code 12
Your water inlet valve is likely defective. The supply hoses behind the machine lead to the watervalve.
Jan 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machine Intuitive Eco model number IW811 won't power on?
Possible Cause Solution The power switch is not turned on at the wall. Unplug the machine from the wall. Wait 60 seconds, plug back in and turn the power back on again. The household power supply is at fault. Try plugging another electrical appliance into the power slot.
Aug 06, 2012 | Fisher and Paykel Washing Machines
Hello -Just looking for help on fixing a service code 66 which comes up when you turn the power on. Unknown age on machine. Fisher and paykel intuitive eco model IW811
HI error code 66 means you have a pressure transducer out of range error.This means that the control module is faulty and needs replacing.please confirm that the error code is numbered 66.Please reply for further help and clarification of this fault code.Hope this helps.
Jun 02, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel intuitive code 37
My machine is actually an IW811. But what happened was I checked motor see if it was spinning & confirm it was. But realised instead of pumping water out, it was going back into bowl, went straight to diverter valve, found control solenoid was burnt, was very hot to touch, even though hasn't been operating, only with main power point on. Suspect motor control board faulty as well. Replaced both parts & was fine after that. New contrl board has been upgraded & came with listings of all codes, explaining every code in detail. Specs to test switch, motor & solenoid resistances. But thanks to you guys for pointing me in the right direction, with what code 37 means in the begining.
Nov 23, 2008 | Fisher and Paykel Fisher Paykel Intuitive...
Intuitive eco Iw811 Rinse 1 no water coming thru!
the 1st rinse light is normally set to "spray rinse", this means the machine will pump out the water, spin at medium speed then pulse cold water into the machine, this occurs for about 2 mins, then the machine will spin out, and advance for the final rinse which is a deep rinse.
Nov 15, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
F&P Intuitive eco (IW811)
Even though the resistance of the valve is normal, doesn't mean that it cannot be faulty. Try swapping the valves around and see if you still get cold water coming in through that valve. If not, then the valve is faulty. Don't forget to put the cold valve back where it belongs. There is a difference between the hot and cold valves( cold valve is a proportional valve) but for testing purposes they can be swapped around. To set the size you have to switch the machine off at the wall. Switch it back on again. Wait for all led's to go out. Press & hold the start/pause button while you push the power button. Switch off again and it should be o.k.
Apr 01, 2007 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
135 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
