The fuel pump shut-off switch is Use the following procedure to reset the fuel pump shut-off switch. 1. Turn the ignition to the OFF position. 2. Check the fuel system for leaks. 3. If no fuel leak is apparent, reset the fuel pump shut-off switch by pushing in on the reset button. 4. Turn the ignition to the ON position. Pause for a few seconds and return the key to the OFF position.
located in the passenger's foot well,
by the kick panel.
5. Make a further check for leaks in the fuel system.
It should be in your owners manual. I hope this helped and good luck.
The fuel pump shut-off switch is located in the passenger's foot well behind the kick panel. Depress the button to reset, you will hear a click if it is the problem as it resets. it is only triggered by a collision exceeding 3 G's.
