Question about HP Compaq nc6120 Notebook
My nc6120 broke?
My laptop only starts up when i hold it in a 45-degree angle. later it will work better horizontally. mechanical failure? I also get 'power peak hub...' port a lot, even with no devices connected?
Well known fault caused by faulty motherboard,you can disable your usb ports which will stop the annoying fault reports and you can use your latop as normal but obviously you cannot use your usb ports as you have disabled them
Posted on Jul 24, 2008
If an angle of a parallelogram is one- third of its adjacent angle, find the angle of the parallelogram
Since the two adjacent angles of a parallelogram must add to 180 degrees, the two angles have to be 45 and 135 degrees respectively.
Nov 02, 2012 | Office Equipment & Supplies
Doesn't stay flush to bottom, good suction, if I hold front portion down it works great!
It's most likely a piece of debris in your flapper of your automatic pool cleaner. Debris may prevent flapper movement or restrict flow. You might also want to check for proper hose balance. The hose should stay at a 45 degree angle to the pool floor. If it is greater than a fourty five degree angle, the hose is too light. Move the weights closer to cleaner, or move the first two weights closer to each other. If it is less than a 45 degree angle, move the weights away from cleaner, or separate the first
two weights away from each other.
Feb 12, 2011 | Universal Kreepy Krauly In-Ground Pool...
Astromaster 76 image 45 degrees off horizontal, although eyepiece set at same angle for comfort of viewing .how can i keep eye peice set and see image correctly i.e 90 degrees from horizontal
All astronomical telescopes show upside down images. It's normal.
However, you can buy and erecting diagonal like the one below for terrestrial viewing.
http://www.amazon.com/Orion-45-deg-Correct-Telescope-Diagonal/dp/B0000XMYEW
Jan 30, 2011 | Optics
I can't get my 95 gmc tailgate to come off. I know that you usually open it alittle and it will come off. But mine will not. So I would like to know if there is a trick to taking a 95 sonoma tailgate off.
  1. Lower the tailgate to the horizontal position.
  2. Disengage the cable on the right and left sides from the striker bolts. To accomplish this, pull up on the middle of the cable assembly while raising the gate to a 45 degree angle, but be careful not to pinch the cable between the gate and bed.
  3. Remove the tailgate from the vehicle by lifting upward on the left side to separate the left hinge assembly, then disengage the right hinge.
To install:
  1. Install the gate to the vehicle by lowering the right hinge assembly into position first, then holding the gate at a 45 degree angle and seating the left hinge assembly.
  2. Engage the left and right cables to the striker bolts.
  3. Verify proper tailgate latching and operation.
Aug 07, 2010 | GMC Sonoma Cars & Trucks
A rock climber throws a small first aid kit to another climber who is higher up the mountain. The initial velocity of the kit is 18 m/s at an angle of 74° above the horizontal. At the instant when the...
Depends on how long it has been travelling. If it is horizontal when it's been caught then ot must have reached zero velocity. No matter the angle gravity works at 1m/s/s. Do the math.
Sep 18, 2009 | NorStar Operational Software Category E...
I want to hang the fan on a cathedral ceiling with a steep slope. Two questions, is the angle of the slope measured from vertical or horizontal,and does anyone make a kit for my fan to hang because the the...
The slope is measured off the horizontal plane. A 45 degree slope would rise 12 inches for every 12 inches of horizontal travel in this example. If the slope is too great try checking kits made by Fanimation. The Fanimation SCK52 - 52 Degree Ceiling Slope Ceiling Fan Kit will go up to a 52 degree angle ceiling and will fit most downrods. The hampton bay fans are very popular and should work just fine with this kit.
-Mark
May 14, 2009 | Hampton Bay 52 In. White Huntington III...
Finding the length of a triangle
might try
(54tan)/45
I don't have a calc that will do it or I would try it and see.
Jul 31, 2008 | Office Equipment & Supplies
HP Compaq nc6120 Notebook Logo
183 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
