Question about Kenmore 22422 Top Load Washer
Kenmore 70 series washer
Our Kenmore 70 series washer does not aggitate correctly, It barely moves while washing not getting the clothes completly clean. The other cycles seem to work just fine. What is the problem?
  • 2 more comments
  • 4HImonly Jul 20, 2008
    :-) Thanks - I will give it a try!
  • sastone75 Sep 18, 2008
    I have a kenmore 70 series top loader washing machine, it doesn't agitate like it use to. The lower half at the bottom moves fine but the top part doesn't unless you put pressure on the top of it. So basically it doesn't agitate like it should but it does drain and spin. Help and instructions on how to fix it would be great. I'm a single mom but pretty handy with tools so I'm not worried about it just need the know how.
  • Anonymous Jan 18, 2009
    water leaking from the bottom of the washer
  • Anonymous Jan 28, 2009
    HOW DO U GET TO THE DOGS . I CANT GET MY AGITATOR OFF TO GET TO THEM
    Genius:
  • 1,028 Answers
The agitator dogs are problably remove agitator cap remove bolt holding agitator in ..dogs are part #80040
Posted on Jul 20, 2008
Agitator on my washer is loose
Replace the agitator dogs in the top part of the agitator. Parts are about $7.00.
Jul 17, 2009 | Kenmore Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore 90 series noise after spin
You need to replace the drive block and basket drive. You can download a tutorial to get you started at www.shop.washermd.com. The gearcase replacement tutorial will put you in the right direction. Dave
Mar 01, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore series 70 washer won't stop agitating when lid Is lifted.
I have a Series 80 and when I lift the lid it does not stop aggitating when in wash mode. When I lift the lid it does stop spinning when in rinse mode. As designed.
To stop wash-mode aggitation at lid-lift, using the existing lid switch and other electrical components, is not easy and not recommended. I can think of a way to do it (triple-pole lid switch) but I will not detail the idea .. for safety concerns.
To stop aggitation, simply use the main settings dial control. You'll save money and possibly prevent a fire hazard!
Jan 23, 2009 | Kenmore 22422 Top Load Washer
All setting are only washing via 1 cycle
be sure both faucets are full on and hooked correctly most washers have only cold rinses
Nov 29, 2008 | Kenmore Washing Machines
How to work my washer?
the timer change by itself. You don't have to change anything.
But cold rinse only works if you have the cold water connect to the washer
May 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
First thing is to remove the 2 screws from the console, they may be hidden in the front or bacl of console. After removing screws, lightly push the base of the console towards the front of the washer and pick up. This will expose your lid switch connection. Using a jumper wire, jump out the black and white wires then try advancing your washer into spin/drain. The culprit will usually be the lid switch assy.
Apr 04, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 series
Mrquest
If it is draining the water then the motor is running. ou most likely have a broken motor coupler between the motor and gearcase.
Remove the two screws that hold the console to the cabinet and flip the console back.
Remove the two clips that hold the cabinet to the rear panel of the washer and unplug the lid switch harness. The cabinet will tilt forward and slide off.
Remove the clips holding the water pump and move it to the side.
Unplug the wires from the motor and remove the clips holding it.
You will see the motor coupler.
Make sure you can turn the gearcase shaft with a pair of pliers so it is not locked up.
Post back with the complete model number from the washer if you need further help.
Thanks, Mike
Apr 02, 2008 | Kenmore 22422 Top Load Washer
Series 70 kenmore elite washing machine
If it goes through the complete cycle o.k. except for the slow spin then the motor itself needs to be checked.
Mar 20, 2008 | Kenmore 24622 Top Load Washer
Kenmore 22422 Top Load Washer Logo
1,461 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
