Question about Apple iPhone Smartphone
Mute button i was simply turning my iphone over in my hand when the mute button was hit, so in trying to turn mute off i pushed the button and the whole thing came off! how do i fix this?
  • mdavis969 Mar 11, 2009
    I have the same problem I always hit the mute button when I talk on the phone.
  • lexasso Apr 24, 2009
    The mute button and occasionally the hold button...is there a good way to hold the phone away from the face?....or to deactivate the touch during a call
Stuck on mute no callers hear me talking
Posted on Dec 12, 2009
My samsung tv say on mute and can't go to unmetered?
It could be a stuck button on the remote.
Try this:
Turn off TV.
Turn on at the TV, not the remote (push screen just above the Blue Light thing at the bottom if no Power button is displayed). If you have sound it was the remote.
Clean the remote of any sticky stuff with compressed air or very lightly with alcohol. Do not use WD-40, it will stick again.
Good luck. Please rate this answer 4 stars if helpful.
Sep 10, 2017 | Samsung Computers & Internet
How do i turn the ringer and microphone on in my iphone 6plus?
I can hear jingle bells in the background. You turn up volume with the the two larger buttons on the left hand side. Upper for louder and lower for lowering right down to mute. You need to be in the particular application when you adjust volume. In normal switched on and open mode, altering those buttons adjusts the ringer volume. Above those two buttons is the phones silent button. When you push it towards the back of the phone it turns off the ringer. When you are making calls, there is a mute button on the display. Also remember that the microphone is in the bottom edge of the phone next to the headphone socket. Don't cover it when you are making videos. Enjoy your new 6 Plus, they are amazing. I have the standard 6. It you have any other questions just ask.
Dec 27, 2014 | iPhone Apps
Where do i find the mute botton on sn iphone
The mute button/switch, is on the lefthand side of the phone.. It will toggle you iPhone to either vibrate mode or mute, depending on your preferred set settings!
Jul 03, 2014 | Apple iPhone Smartphone
Paring iphone 2013 huyndai elantra
I had no problem pairing my IPhone 5S. I was even able to pair my old IPhone 4. I tried the old IPhone 4 after seeing this post. what kind of problems are you having pairing the IPhone and what version is it? All I did was turn my Bluetooth on on my IPhone then i pushed the black hone button then hit the settings button on the phone screen then pressed the pairing button then pressed the add to button, once the phone is found it should show on IPhone as Elantra on the IPhone and put in the passkey that it shows on the Elantra screen ( factory default is 0000 ) then the screen in the Elantra will show pairing. then it's paired. then you can go through all the setting after the phone is connected. Just make sure before you get into the car your BLUETOOTH is turned on on your IPHONE or it won't connect till it is turned on and the phone won't connect while your foot is on the brake if you have push start.
Apr 21, 2013 | Hyundai 2013 Elantra Limited
Iphone is not responding
Hold the top off button and one of the left hand side buttons push them in together untill phone reads slide to power off slide arrow and wait for phone to turn off wait about 1 minute then turn phone back on by pushing button on top of phone apple simble will come up resetting phone
Apr 05, 2013 | Apple iPhone4 4G iPhone 4
My iphone is turned on mute how to solwe this problem
If your iphone is on mute, that means that you have slid the button at the top left of your phone down (you can check this by looking at the button and seeing if it is in the down position with a red bar above it). To unmute your iPhone simply slide that button back up. You can then control the volume using either the buttons on the left side of the phone or in the sound settings.
Feb 13, 2013 | Apple iPhone 3GS Black (16 GB)
Red Hue
Go into the service menu and turn down the red push and red cut a few notches. Write down every value in the service menu and be careful to make sure you don't change anything else. Also, turn down the brightness a couple of clicks and the red glow will be gone.
Or, try this - Press Mute on the remote control twice, press Mute a third time and keep holding at the same time, press the Menu button on the TV front panel. If you do it correctly, you will see a small S on the screen. Congrats, you are in service mode. Press Menu on the remote to get to the adjustable settings. Be careful not to change anything without writting the original value down first. Also be careful of hitting other buttons on the remote. To reduce red push, Use the channel up down button until it says RCUT. Adjust the value using the volume button on the remote. I recommend setting RCUT to 80H, which is the preset value according to the service manual. To exit Service Mode, simply power off the TV. Good luck.
Jul 04, 2010 | Toshiba 51H84 51" Rear Projection...
TV STUCK ON MUTE??????
You did not give a make and model for the TV so I can only offer a general solution. You may need to reset the sound board. This can be done simply by unplugging the TV for about 10 minutes.
Jun 22, 2009 | LG 42PX5D 42 in. Plasma HDTV
Do not disturb on phone is lit up
ON THE BASE, there is a button that says do not disturb on the lower right hand side on mine and I accidently hit it and turned it on!! I kept trying to fix it with the handset and the menu!! My husband suggested I look at the base and WAHLAH!!! I simply pushed the button and it worked!!!
I'm trilled ...cause I was so frustrated!!! So...there you go!!!
Jun 30, 2008 | GE 25932 Cordless Phone
Apple iPhone Smartphone Logo
530 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
