First, I'm not a Facebook representative.
* Contact your laptop MFR for service and support.
*** The following is for information only ***
* I'm guessing you could play FB vids before and have not upgraded any apps (FaceBook) recently..
* I've found my vids on You Tube; the audio would not sync up. (Plays audio but the vid lags behind like watching Kung Fu English dub movies).
* The recommended fix was to clear the "cache" storage.
* Download latest version of the app (or program)
* Upgrade to the next (premium?) level.
* Perform a "Hard Reset" (on cell phones)
* For laptops/desk tops; perform a complete shut down to allow windows to clean up temp files and archive.
* Check your storage; "free space" as it may be too low to function correctly with high volume data files.
* Move or delete older programs and archive old data to free up "working space" in memory. This is the internal RAM of the CPU and not the Hard Disk Drive HDD (some newer CPU's use Flash drives now)
* Basic idea is to perform maintenance on your computer to free up memory and clean up useless files and data.
* Chrome FB Vids; https://www.youtube.com/watch?v=SG-7tnb07S4
* Blurry vids; https://www.youtube.com/watch?v=BNS4nTWtIN4
* Slow internet; https://www.youtube.com/watch?v=7zD_qWgibaw
* Automatic play; https://www.youtube.com/watch?v=sAPxE5u1wBM
* Android Phone; https://www.youtube.com/watch?v=rvN5H_0qYTo
First, I'm not a Miele technician, but I've worked on similar table top espresso machines. But I suggest you contact your vendor for service. Check your warranty.
*** Following is just for information***
FYI; There are quite a few you tube videos on this machine.
* These smaller units have individual heaters and mini-boilers instead of one big boiler used in commercial machines.
* I suspect the steamer is a mini-boiler that are common on small brewers. It's about 3" x 4" and 1" thick made of aluminum. There is a heat limit fuse and thermo disk. One or both may be blown.
* If your getting sputtering cold water from the steam wand then it's definitely the boiler other wise it's the vibration pump. Quite a few vids on you tube about the ULKA water pump (suggest alexis c vid)
* I don't think there is any solenoid steam valve on this unit as it's only used on larger boiler systems where the boiler is under pressure all the time. The slow steam start is a good indication of the mini-boiler reheating.
* Final; This is a very compact machine with a lot of wires. Please review the vids on you tube by searching "Miele CVA 4070" Suggest getting help from your vendor as you will need those parts as mentioned.
Aloha, ukeboy57
PS there is a lock out feature on this brand. Check this link for more info:
https://www.bing.com/videos/search?q=Miele+4070&&view=detail&mid=87B4106BEC0DAF1D524587B4106BEC0DAF1D5245&rvsmid=9D76B03F2F848C9C94B59D76B03F2F848C9C94B5&FORM=VDQVAP
The drain tube that runs down the back of the fridge into the tray that sits on top of the compressor is blocked, you need to clear this, you can either use compressed air and blow back up into the fridge of find a soft but stiff wire to carefully slide up the tube.
try to upgrade the firmware of the phone and also try with exclusive youtube facebook apps for android to play those vids..if your internet connection is slow this might happen as well
They make a damper kit for the produce compartment to slow down air flow, if you want to go cheap, remove the drawers and look on the back wall, if there is a vent on the BACK wall, cover it with tape, never cover the vent on the lower left, that is your cold air return
Hi gerry the wipers are eletric what year is it this sound like a wiper spindle seezing up spray oil down behind the wiper arm, try that might just be freeezeing up D
This is not your system problem. Your connection speed is slow then system. After playing about 5 seconds video the remaining video is in progress for download from server, this process is technically called buffering. If you can not wait for buffering then you will need a fast connection. This will solve your problem.
