Model RGM41101 Microwave 1000w when the door is closed you can hear a deep hum like the megnetron is still running even thou the microwave is turned off is this a problem if door is opened no noise at all thanks bruce.
When its not working with the door open the turntable turns slowly,the light is dim & the fan is turnning.If i tap on it in different places & the turn table stops turnning & light brightens up than it will work.?????When its not working with the door open the turntable turns slowly,the light is dim & the fan is turnning.If i tap on it in different places & the turn table stops turnning & light brightens up than it will work.?????
You can't post conmments that contain an email address.
We are very sorry to hear this and we apologize for the inconvenience this has caused you. We would be glad to look into this if you could email us at [email protected] with your name, address, phone number and the model & serial numbers of the Microwave.
Possibly a shorted relay on the main timer board?? hum coming from transformer being powered with no fan running. With No fan you can hear it hum. shorted power relay on main board.
Well your gonna have to take it down a take apart the microwave more than likely. Probably have a shorted HV diode,magnetron, shorted winding in HV transformer.burnt or frayed HV wire insulation
During operation, most of the built-in models have a panel that tilts out while the exhaust fan is on. When cooking is done, the exhaust fan shuts off and the panel retracts to its normal position. With the fan & microwave motor off, the hum is easier to hear.
Look closely at the top panel the next time you hear the hum, and you'll probably see that it's retracting.
