Question about Motorola Mobility RAZR V3
How do you clean the pins?
My motorola razor says Insert SIM card when the card is already in. The card works because it works in my other phone. I see you suggested cleaning the reader pins. How do you do that? And how do you clean the pins that are under the metal piece?
    Problem Solver:
  • 7 Answers
I faced the same problem... & i believe it's the SIM's fault. I'll tell you what i did:
just forget the cleaning part, and insert a small piece of folded paper(to push the SIM down) between the SIM and the metal that holds it in place, so that the SIM is pushed down hard.
this worked for me...
Posted on Jul 22, 2008
    Brigadier General:
  • 7,752 Answers
The pins are not the problem it is the board so you may need to have the phone main-board replaced but to be on the safe side take the phone and have it checked first at a mobile service shop.
Posted on Jul 21, 2008
Sudsidy password for t mobile motorola razar
WARNING: If one of theses messages appear :
- "Contact Service Provider"
- "Tampert Alter"
- "Wait before enter special Code"
- "Contact Service'
It's because you or somebody already entered too many wrong codes, you just have to leave the Motorola Razor ON with the errors message and after 40 minutes to 2 hours the message "Enter Code Special" will appear again!
You can get the Correct the subsidy password at Theunlockarena.com/motorola-razor/rs13wp9/ and Unlock it easily.Follow the instructions below and unlock it step by step...
Motorola Razor Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Motorola Razor mobile phones. If you enter over a certain amount of wrong unlock codes on your Motorola Razor mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch ON your Motorola Razor with a NOT ACCEPTED SIM Card,
2 - Phone will display "Enter Special Code",
3 - You can now enter the Unlock Code.
NOT ACCEPTED: We mean, to use a sim card from a network other than the network your Motorola Razor is locked to.
May 15, 2012 | Motorola SLVR Cell Phones
I have a motorola razor with an old cingular sim card in it. It was used only for 1 week. I want to unlock the phone and replace the sim card with another one
You do not need to unlock the phone in order to use another sim card with the phone. Just insert the card and as long as the card has been setup with your number, it will work fine. If the card asks for a pin code, you need to contact AT&T or T-Mobile for that code, otherwise you should be good to go. Let me know if you have any problems, or is I did not understand your needs properly, and I will walk you through the process.
Jun 19, 2011 | Motorola Mobility RAZR V3i Cellular Phone
Motorola razor phone. screem says insert sim card only emergency calls only
if you have a SIM card in the phone, it is not valid, you will need to contact your local service provider. Best option is to go in person to a store.
Dec 28, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
I have a motorola clutch my phone was sitting on the able when it lit up! when i grabbed it and looked at it, it restarted itself then the screen said insert sim but the sim card is already in it!
Your problem could be with the sim card, with the sim interface on the phone and or sim ic on the circuit board.
1. First, let's check the sim card, switch off the phone > remove the sim card > clean it properly using a small ball of cotton dipped in alcohol or acetone, > let it dry > Now put the same sim card on another mobile > if it's working then go to next step, if it's not, then the problem is with your sim card. You need another replacement.
2. Now clean the sim interface/connector on the mobile using cotton dipped in alcohol or acetone, After they are dried, insert the sim card and power on the phone. How is it? Is it working now? Let's hope................ go.. yes it's working.
Oops, it's not, then next step..
3. Open it apart and clean whatever is possible, [use a soft brush with alcohol or acetone to clean the components]. When everything's dried, assemble it an insert the sim card again. If it's not successful. Your last option is to get it done from a mobile repairing shop or from a servicing center. They will check the phone on the computer using the specific software and hardware, then they will handle with your mobile's hardware, possibly sim ic and sim connector.
Good luck.
Thanks for using FixYa.
Jul 06, 2010 | Motorola Mobility Clutch i465 Cell Phone
Sim card
Sounds like phone is locked or firmware is bad
Mar 15, 2009 | Motorola Mobility RAZR V3
Getting rid of phone #'s and text on motorola razor v3
All of your texts and numbers should all be on the SIM card itself and not the phone.
So you can give the phone itself to a friend but keep the sim.
Hope this helped.
Dec 17, 2008 | Motorola Mobility RAZR V3
Insert sim
Try rigorously cleaning the sim card and phone connections (also battery connections - after reading forums the batteries on V3's are often to blame for their problems) with a cotton bud then leave the phone off without the sim card in it and charge it overnight. Then put in the sim card and turn the phone on. This might help. My V3 often says Insert SIM and it is very annoying so i'm getting rid of it but those methods have worked for me.
Hope this helps
Mowcius
May 12, 2008 | Motorola Mobility RAZR V3
Motorola V3 Razor
Guest - you need to take the phone and have the keypad replaced.
nende - you need to replaced the main-board or buy a new phone.
Apr 07, 2008 | Motorola Mobility RAZR V3
Water in phone
Alright so if you got a new sim it's more than probable that the connection is the problem. Remove your sim and take an eraser and clean it gently. Make sure you have the sim connector properly connected to the sim card, so leave the back off and turn it on I had to slide my sim card around a few times for it to work so try that till the message disapears. hope that helps.
Dec 13, 2006 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
70 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
