Question about Goodman CLQ36AR49 Air Conditioner
Goodman compressor cuts off when temp too high
We have a Goodman GSC13 - 13 SEER. Fan in attic, compressor outside.
It worked fine for the first 2 weeks. Then one afternoon we realized it was pumping out hot air and that the compressor wasn't running. We turned it off, tried an hour later, same problem.
AC guys came next day--turned it on--it worked fine. They checked everything, couldn't find a problem.
This afternoon it started blowing hot air again, compressor not running.
The temp outside was 91, heat index 97.
The 1st time this happened it was a very hot day too.
Problem seems to be that when the outside temp or heat index hits mid 90s or better the compressor stops. Any ideas? Thanks for any help.
  • 2 more comments
  • marber Jul 19, 2008
    Meant to mention AC is 3 weeks old.
  • marber Jul 21, 2008
    Thanks burzerko,
    This gives me something to ask the AC tech.
    Keeping in mind that this system is only 3 weeks old do you think this is a problem in the compressor from the factory or something done or not done during installation?
  • marber Jul 22, 2008
    Thanks for responding again.
    AC has done it again-- 3 times now. It worked fine the first 16 days, then it cut off on Thursday, Saturday, and Monday. All in the late afternoon - we try it again about an hour or so later and it doesn't work right. Start it up the next morning and it works fine. At first I thought it was cuttiing off on the hottest days, but it's also working on very hot days--todays temp 100, heat index 104 and it's working fine.
    I haven't had the time to have the AC guys come back again. When they do come back I hope they'll do more than what they did last time. To help with that is why I'm here--to get ideas on what to ask. How do you think the tech might have overcharged the system?
    thanks again
  • marber Jul 31, 2008
    UPDATE-- The AC has been working correctly for 7 days now. The AC guys realized that the drainage hose wasn't draining properly. Once they fixed that it's been okay.
    Problem Solver:
  • 5 Answers
When the condenser coil is dirty come high pressure and cut out the compressor, you can wash with the garden hose around the condenser coil before disconect the unit for prevent any electrocution or the sistem is overcharged
Posted on Aug 07, 2008
  • gabriel martinez
    gabriel martinez Aug 07, 2008
    I am not apprentice i come from the arizona refrigeration institute from phoenix any question if i can help i have 3 years experience not to much?
  • 254 Answers
I believe you have 1 of 2 problems going on here your system may be overcharged causing the compressor to cut out on a overload relay circuit internally, or it also could be tripping out a high pressure switch which could be from an overcharged system or a dirty condenser. I would have the tech come out on a 90 degree day and put the gauges on and check the pressures while it is operating under a full load.
Hope this helps you.
Please rate me
Posted on Jul 19, 2008
  • burzerko
    burzerko Jul 21, 2008
    I really think the tech overcharged your system. Since it has gotten warmer the pressure has increased causing the problem you stated. The theory of a dirty condenser is possible but at 3 weeks highly unlikly.
    Please comment back if you have any other qustions.
  • burzerko
    burzerko Jul 25, 2008
    What you saying makes sense that it is overcharged the longer it runs the hotter the compressor gets which after time will trip out the internal overload inside the compressor.
2002 4 ton Bryant air conditioner shuts off, fan still runs but not cooling is problem in the controls in the attic or in the AC unit or both?
With a non heat pump it is a simple 24 volt AC control circuit. In the attic there is a relay that is actuated via the fan control wire directly from the thermostat. On the thermostat there is an auto/man switch that controls the fan. Manual the fan runs all the time. Auto fan turns on and off with the outside compressor.
If the system is not calling for cool and the fan continues to run the fan relay is sticking. common problem. Sometimes after running for several days the relay will stop sticking if not, replace relay.
If the system is calling for cool and the compressor stops I would still expect the fan to run until thermostat tells the A/C to off. Some compressor units include a safety switch or high-pressure cut-out switch A blocked internal valve bad control board or external fan in outside unit defective no air flow in outside unit.
High pressure cut out not good,
Suggest turning temp max cool and observe. If acceptable cool and the compressor runs without interruption all is good, except for the blower in the attic. Safely check relay in attic blower circuit.
Hope this helps.
Jun 28, 2017 | Bryant Heating & Cooling
Goodman heatpump fan runs, condenser wont start
Either the condenser fan has bad bearings, or it has a defective fan capacitor.
Turn off the breaker to the outside unit.
Spin the fan blade by hand.
If the fan blade spins easily and will spin a few revolutions with no problem the fan bearings are good.
If not, replace the fan motor due to bad bearings.
I am pretty sure you fan motor is bad because with a bad capacitor the fan motor will not get up to speed and may just sit and overheat.
I'm leaning toward a bad fan motor.
Sep 27, 2012 | Goodman Manufacturing Goodman GSC130301...
I have a 16 SEER Goodman air conditioner and during the morning hours, temperature ranging 75 degrees outside, the compressor comes on but not the outside fan. It only runs for a minute and a half then...
The fan is shutting off in order to maintain head pressure when the outdoor temperature is low. This is common on 16 seer and above systems. It helps your system be more efficient.
Jun 06, 2011 | Goodman Heating & Cooling
I have two outside ac one for floor and other for upstairs and i button on heater auto and ac outside fan is running is that normal or not? and live on this new house for two years and cant find someone...
No the fan out side is for a condensing unit and compressor. The compressor should not run with the heat. I am almost positive that if this is not a heat pump that the compressor unit should not be running.
Dec 20, 2010 | Goodman GMS90703BXA Heater
Air condition jsut 10 month old ... not keeping up whith cooling
If it's only 92° outside and the unit won't cool the house, then the unit is either to small or it's low on refrigerant. They are designed to cool a house with outdoor temperatures up to 115° to 120°.Usually you need one ton a/c for every 400 square feet of house, but, you have to take into account for average outdoor temperature and humidity, windows, doors, especially sliding glass or patio doors and which side of the house they are on, insulation in walls and attic.
The air leaving your duct work going into the rooms should be about 20° lower than the room temperature, if you have a 80° room then the air leaving the duct should be around 60°. if it is then the unit is probably to small if, everything is working properly.
Jun 07, 2010 | Goodman CLQ36AR49 Air Conditioner
AC not cooling
first off you should have a four ton unit. what is your super heat? is it pulling attic or outside air?
May 27, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman 2.5 ton 14 seer with txv. low compressor amps
no it's good,man. LOL. The RLA is a max not a target. What is the RLA for the compressor?
Aug 12, 2009 | Heating & Cooling
Air conditioner constantly running, not cooling house
Check and see if it is froze up. Check big line at outside unit for ice. check filter and replace as needed. Check outside fan to see if it is running. Wash out outside coil If fan and compressor are running and has hot small line at outside unit. If not froze up and coil is clean you will need to call in a pro. If compress over heated you may need to wait for it to restart if coil was dirty. Again make sure out door fan and or unit is running and clean.
Jun 29, 2009 | Goodman CKL49AR49 Air Conditioner
My low side is 90psig and high side 250 psig what is going on
If it is very hot in the house the suction will be high but not that high. If you have a 13 seer inside and a 10 seer outside your suction can be that high if you don't lower fan speed. Does your unit coll ok. Another reason if it is not cooling well is bad valve in compressor but the compressor would going out on internal overload because of getting to hot. If you have TXV metering device it could be stuck open. Check sub cooling. Put a thermometer on the 3/8 line and measure the difference between that temp and the guage temp. Look at your pressure and the temp reading is nest to the pressure. The difference should be between 12 and 16 degrees. Measure Large line temp for superheat difference should be between. 12 and 16 degrees. Feed back please
Jun 13, 2009 | Ruud UAKA042 Air Conditioner
Goodman CLQ36AR49 Air Conditioner Logo
449 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
