Our Ruud RCBA (split unit) AC is Leanking ...
Our Ruud RCBA (split unit) Air Conditioner is leanking inside the house and ouside is dry. All the carpet is wet. How we can solve this problem?
  • kparedesm Jul 21, 2008
    Thanks a Lot!!!!!
    Now work Nice
Make sure there is a 'p' trap comming out of the unit in the attic on the drain line.
Posted on Jul 20, 2008
Unit not cooling inside below 72 degrees lines sweating
how hot is it outside??? 20 degree split is usually the norm ,,,,,outside 95 then inside will be 75,,,,,where is the line sweating ,,, it should sweat near outdoor unit
Jun 02, 2014 | Ruud Central System Air Conditioner
Ruud rcba frosting
If you can't find the filters, maybe they were never installed. If that is the case you probably have a dirty/blocked coil.
Apr 28, 2014 | Ruud UAPA024 Air Conditioner
Cannot find a filter location for RCBA 4882GG21.
it is either in the bottom of the indoor unit itself, in the door below the inside unit (if equipped), or in the grill on the wall or ceiling
Sep 30, 2012 | Ruud Matching Split Air Conditioner
My ac unit is not cooling my house. it is blowing cool air but not as much as it used to. i have replaced the thermostat and the air filter, and it still has the same problem. what can it be? and how can i...
What is the temp of the air at the nearest vent when it comes out. then what is the temp of the air when it goes back into the return air? check your ouside fan and be certain it is clean as well and that the fan and compressor are running .
Jul 31, 2011 | Ruud UBHC Air Conditioner
Air conditioner works fine but heat won't kick on
Check RV is working. And also keep thermostat setting +29 and heat mode.
Dec 09, 2010 | Ruud Matching Split Air Conditioner
House has power but AC and thermostat seem to be off. Thermostat doesn't even show a temperature reading.
I would check the inside unit on the main board and make sure the fuse is not blown. Hope this helps Tim
Aug 26, 2010 | Ruud Matching Split Air Conditioner
How can I validate the tonage of my Ruud air conditioner? The model number is M0696. The serical number is RCBA-3/65AS17
you must have very old equipment are you sure of the model and serial number it might be a 69 if the serial number is the m0696. Tom double check those numbers.
Jun 28, 2009 | Ruud Matching Split Air Conditioner
Ouside unit not coming on
You are not getting the 24 volt control circuit to coil need to make sure your 2 wire is in good shape and connected to the coil connections. If you have a ohm meter you can ohm out the coil and see if it is good. Be carefull cause the is 240 volts at the same spot on the contactor. So just pull the fuses out of the disconnect box and will be okay. Or turn off the breaker inside the house to the unit. If coil is bad just replace the contactor.
Apr 05, 2009 | Ruud UBHC Air Conditioner
I'm COLD!
Any will work provided you have it is a Heat Pump thermostat. I recommend honeywell or totaline.
Dec 05, 2008 | Ruud UBHC Air Conditioner
Heating & Cooling Logo
443 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
