Question about Planar Computers & Internet
Monitor shows a image uo until sign on screen then goes blank
    Scholar:
  • 99 Answers
Does it go blank before you signon, or when you sign on? If before boot to SAFE MODE and check the video display settings.. you man have settings your monitor can't understand.
If that doesn't work and you get to input your signon and then it goes blank you most likly have a virus or malware.
Log into safe mode, and use SYSTEM RESTORE to a time before you stated having the problem.
Start - All Programs - Accessories - System Tools - System Restore
Posted on Jul 19, 2008
Monitor keeps showing "Check signal cable"
Well, at least you got it sorted out and everything is working fine now.
Apr 21, 2012 | Samsung SyncMaster 2493HM Monitor
The screen goes blank soon afte 2 seconds but put a flash light on the frount you can see it is this the blacklight
image with no blacklight could be sign that the backlight (fluorescent tube) is faulty, may need to have that serviced
Mar 02, 2011 | HP Pavilion F1703 17" LCD Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Hp flat panel monitor comes on shows logon and then blank screen
Ok, another words, monitor powers up for few seconds and shuts down by itself. If green LED on the front panel turns off as well or stays on?
If stays on, then inverter turns into protection mode because of old backlight lamps.
If it turns off in same time with an image on the screen, then there are some bad electrolytic capacitors in the power supply.
Sep 11, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
L17LCD2 goes blank
pls check your chip board heated up or u kept your LCD near by heat radiating objects
Jul 03, 2009 | Computers & Internet
Screen goes blank.
PETTY SOON YOU WILL NEED A NEW MONITOR, IT PROBLY IS NOT WORTH FIXING,
TAKE IT TO A TV SHOP AND LET THEM LOOK AT IT, THEY CAN TELL YOU IF IT IS WORTH FIXING
CANDYMANGANDY
Jan 29, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
The screen went blank while the computer was on, we restarted it, the screen shows the Dell sign & the white bar then it goes blank, it won't go into safe mode, the light is green on the monitor, what...
If there is a faint image in the background it is the coils on the planar if no image it is either the invertor or the backlight
If you have a faint image resolder the coils or replace them
Dec 15, 2008 | Dell Dimension B110 PC Desktop
My screen goes blank immediately after initial DELL startup image
You can either try to reset the BIOS, or have the restore cd fix it for you. By the way, what does the message say?
Nov 27, 2008 | Dell Dimension B110 PC Desktop
Monitor displays breifly then goes to blank screen
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After going blank, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken and it is easily replaced. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Feb 23, 2008 | Gateway FPD2275W LCD Monitor
Bank Monitor problems
Unplug the cable from your PC, if the monitor shows a test image, the monitor is fine and the problem is with your graphic card. If you dont see nothing on-screen after unpluging the cable from the PC, then the monitor in damaged. Send it to repair.
Jul 09, 2007 | Dell E193FP 19" LCD Monitor
Open Questions:
Computers & Internet Logo
203 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Joe Goldman
Joe Goldman
Jay Plesset
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
