Question about Cingular Wireless 8125 Smartphone
"my info" screen is stuck....
Hi there - After taking out battery to get out of a phone call accidentally put on hold, now the phone is stuck on the "my info" screen --- no buttons work -- phone not work either.
  • 66 Answers
You can try to do a hard reset by holding the 2 top side buttons while powering on the phone. this will delete the phone moemory also.
Posted on Nov 16, 2008
Stuck on reset screen
Yes all u have to do is take the plug out take the battery & back out then
reset the phone u should be fine
May 23, 2014 | ZTE Warp
Kyocera cell phone
Hi @Julie, please turn off the phone and remove the battery. Put the battery back in a couple of minutes then power on the phone.
Oct 29, 2017 | Cell Phones
HI. PLEASE HELP I accidentally released the
Try removing the battery and putting it back in
Sep 29, 2013 | Cell Phones
LG chocolate touch screen is stuck on
when u take out the battery hold down the end button for 30seconds then put battery back in and start it up.
Jul 14, 2012 | LG VX8575 Cell Phone
I accidentally put ON the phone code and i forgot the code
try hard reset..that will be remove all and that phone password
Hard reset is better for solved that problem..
First swith off you phone,after swith off,click *,3 and green key(call key)---->hold,
After to hold that key,now click power key to swith on --->*,3 and call key must hold...
Try it :)
Jun 02, 2010 | Nokia N95 Cellular Phone
The display will not show anything when the camera is turned on. All the options are on the screen but nothing else. It is black.
First off you didn't say if the pictures it is taking are OK, or if they are also black. If the pictures are turning out fine, then it's likely that you just accidentally pressed the DISP or DISPLAY button on the back of your camera, accidentally turning the screen off to save batteries. Press the button one more time to turn it back on.
But if the pictures take are also black, then a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Apr 04, 2010 | Canon PowerShot A540 Digital Camera
Lcd screen is black
First of all, make sure that you didn't just accidentally turn the screen off. Press the DISP or DISPLAY button on the back of your camera with the camera turned on. This button manually turns the screen on and off to save batteries.
OK, you already knew about that button. Don't get offended, a lot of people don't. Take a picture with the screen black, and download it to your computer. Is the picture also black? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Mar 28, 2010 | Canon PowerShot A630 Digital Camera
While taking a photo snap, don't see the picture on the screen. Screen is black. Can see the old picture on preview mode without any problem
Sounds like you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batterie (you would then use the optical viewfinder in its place). Press this button once to see if it corrects the problem.
If the above didn't help, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Nov 07, 2009 | Canon PowerShot SD1000 Digital Camera
Power shot a620. screen is not showing pictures, all icons are there but screen is black? Help please!!
Sounds like you might have accidentally pressed the DISPLAY button on the back of your camera. It turns the screen on and off to save batteries. Turn on your camera, and press this button once again to turn the screen back on.
But if your camera is also taking black pictures,
Jul 30, 2009 | Canon PowerShot A620 Digital Camera
Screen stuck on hellomoto
Hi try pulling out the battery for a few min and later when you put back the battery , keep your phone for charging. Then try switching off and off when the charging is taking place. Hopefully it should solve the problem.
Oct 20, 2007 | Motorola Mobility MING A1200
Cingular Wireless 8125 Smartphone Logo
67 people viewed this question
Top Cingular Wireless Computers & Internet Experts
Jim Goldsmith
Jim Goldsmith
fordexpert
Erik Walters
Are you a Cingular Wireless Computer and Internet Expert? Answer questions, earn points and help others
