Question about Black & Decker String Trimmer Cordless 12" 18V
Black and decker grasshog trimmer line feed problem
Automatic trimmer line is fed out so it uses up 6 ft in less than 1 minute?
  • Anonymous Jul 22, 2008
    Same problem!!!!! ANY solutions?
  • butch47 Jul 23, 2008
    I've had the cordless trimmer less than 2 months and the line ran out, now I'm trying to figure out how to replace the line. does black and decker have a video showing how to do it?
    New Friend:
    Problem Solver:
  • 6 Answers
As for respooling I said to heck with it and bought a new pre-lined spool at lowes for around 8 bucks. simply remove any remaining line, pop the old spool out and put the new one in.
As to the feeding issue I had the same thing going initially when i installed such spool. I didnt really get a chance to look at the problem in detail but here is what i think the problem is. The little rocker arm that engages the auto feel seems to me to have way to much play in it. I noticed if i constantly engaged and released the trigger, essentially revving it, thats when it would start eating line like crazy. I think doing this is allowing that arm to engage and feed line because of the constant shifts in rpm. It kinda seems like it allows the arm to slip in place. I also noticed that If I engaged the trimmer, and held the trigger at the same steady pace, then slowly let off that it wouldnt eat up my line. Im not to sure about all of this though. Its my grandmas and today was my first and prolly last day using it.
Posted on Apr 01, 2014
  • 313 Answers
Email or see look for the find it now icon & enter the model #
Posted on Jul 28, 2008
Black decker troubleshooting
Aug 03, 2014 | Black and Decker USA BLACK&DECKER GH710...
When I had this problem I replaced that ratchet toggle part that the string drum sits over. Do you use replacement refills or do you refill them yourself. If you wind the string in the wrong direction it all affect the auto feed.
Jul 15, 2014 | Black and Decker USA BLACK & DECKER...
Need to replace the wirefeed? Purchased 8" orange
Hi gramcherry1...
1 Press the lock and rotate the spool counter-clockwise or some will remove the center knob.
2 Remove the locking ring if your weed eater has one.
3 Take off the automatic feed button.
4 Wipe away any dirt and debris.
5 Push down on the spool to release the locking tabs.
6 Remove the spool from the chamber.
Restringing the Weed Eater
1 Feed one end of the line into one of the holes of the spool, and secure the end that was inserted
2 Wrap the line in the direction of the arrows. Do this until until you fill the spool up with line.
3 Secure each of the lines into its own upper and lower grooves.
4 Re-install the spool into the chamber from which it was removed.
5 Pass the lines into the left and right holes and snap the spool into place.
6 Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
7 Reinstall the locking ring if necessary, reinstall the center knob.
Please take time to rate me
Jul 03, 2011 | Black & Decker Grasshog 12 Inch 18 Volt...
I properly replaced the line spool but it won't feed automatically.
After you replaced your string in the trimmer and fed it through the hole in the plastic casing in which the spool fits into, did you pull the string until you hear a click? The click locks the string in, then you can bump and feed as usual. Otherwise it won't feed normally.
Aug 13, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
The string on my duel fed grasshog is wrapped hopelessly underneath the spinner. How do I get the thing apart?
Hi There,
Hey, it happens. But line is cheap compared to the time it may take to dismantle and then reassemble the unit. Especially if you're at a clients.
I use wire cutters and needle nose pliers to clear that birds nest quickly.
If the unit has a habit of tangling, just use less line when loading.
Call this an alternative solution.
Best regards,
Jul 13, 2010 | Black & Decker 14" Grass Hog Xp...
The automatic line feeder dosen't work
You can have mine. It wastes line by feeding automatically way too often. Black & Decker sells Junk!
Dec 14, 2009 | Black & Decker 14" Grass Hog Xp...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
I have bleck and decker grass hog auto feed and it does not work
There is a smalll white part below the spool called a "lever". This is likely in need of replacement. Call Black and Decker at 800-544-6986 with your Model No, and Date Code (stamped on the trimmer itself near where the extension cord plugs in). If it is still under warranty they will send you the replacement part - if not, I loooked it up and it's less than $3 for the part itself.
May 25, 2009 | Black & Decker 5.2 AMP 14-Inch Grass Hog...
check the white plastic lever location at the back of the spool. replace if broken. less than $3 part
Jun 13, 2008 | Black & Decker String Trimmer Cordless 12"...
Black & Decker String Trimmer Cordless 12" 18V Logo
1,251 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
