hi there if you are having some problems with laptop starting up then i would look at the power cord that charges your battery and make shure your battery is locked in the slot as well . what type of laptop you have there ? is the power cord adapter still working ? it may not be charging your battery sometimes this will happen before you take laptop to surgury make shure that the power adapter cord is still charging battery ok to do this plug in power adapter and using a multi meter check to see the voltage that is comming from adapter plug ok on the adapter it will tell you the input voltage and the output voltage that you should be reading on your dc multimeter ok try that first ill wait on a fixya soon bye for now
I need to change the settings on the iomega prestige so that I can use it on pc. Changed settings...
(More)
I need to change the settings on the iomega prestige so that I can use it on pc. Changed settings for a mac and now need to use on pc
when i plug the drive into the computer the LED blinks three times and the unit shuts off...what...
(More)
when i plug the drive into the computer the LED blinks three times and the unit shuts off...what happened?
computer doesn't read it anymore. Light on top flashes once then has 6 fast flashes after that then...
(More)
computer doesn't read it anymore. Light on top flashes once then has 6 fast flashes after that then repeats. Smart Disk 160GB external Crossfire Hard Drive
I run a Ibook G4 with a 1TB external drive (Big Disk Extreme). The blue light keeps flashing and the...
(More)
I run a Ibook G4 with a 1TB external drive (Big Disk Extreme). The blue light keeps flashing and the drive won't appear on my desktop. Connections and everything else were checked and appear to be fine. Ideas???
