Question about Pentax Optio M20 Digital Camera
Optio M20 The camera will not turn on. It tries to but it shuts right back off. The batteries are fine. I tried turning it on holding the menu and on button at the same time. Must have done this 20 or more times got the same results. Any ideas.
  • darveaux Jan 03, 2009
    Tell me what to do.
  • Anonymous Jan 27, 2009
    My optio m20 will not turn on.I loaded my pictures into the computer and noticed the warning that the batteries were depleted,when I changed the batteries the camera would not turn on.I,ve checked the batteries but no luck.
  • 797 Answers
Something is stopping the camera from starting. Possible lens damage. Also could be a connection inside the camera.
This may be a camera you would want to sell as a repair item or AS IS on Ebay or a site like that.
Posted on Jul 19, 2008
Pentax Optio M20 in Green Mode switches off after turning on
Try to press & hold down the Green button (the trash can button on the bottom right corner) & see if it gets u out of green mode.
Jul 27, 2009 | Pentax Optio M20 Digital Camera
My pentax m20 optio wont turn on.. it says battery deplete..
Hi there - these are older posts, but I just experienced this problem (it appears to be pretty common). The fix I discovered (that works), is to insert your batteries (make sure they're fresh), and then press and hold the "on" button plus "Menu" button, together at the same time. Hold until the firmware resets (a message will pop up on screen and the camera will reset). Voila! It works again for as long as the batteries are in and operational. Also note that in my case, if the batteries are taken out, I have to go thru the reset process again, but at least I have the camera back up and running. Hope this helps others!!
Apr 21, 2009 | Pentax Optio M20 Digital Camera
My Pentax Optio M20 will not turn on.
Make sure the batteries are good. If the batteries are brand new, then it must be something with the camera, and you should take it in and have it looked at. Good luck.
Jan 27, 2009 | Pentax Optio M20 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Pentax optio m20 .. on-off immdly
Mar 25, 2008 | Pentax Optio M20 Digital Camera
Camera problem
Feb 10, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M20: won't work.
ok have same problem press the power button and and the play> button at the same time. your screen will come on but not lens. then hold the play button down untill lens come out. this will work for you , you may have to do it a couple of times but it will work
Jan 20, 2008 | Pentax Optio M20 Digital Camera
Optio m20 beeping?
Dec 08, 2007 | Pentax Optio M20 Digital Camera
Optio M20 Beeping
You certainly need to use high capacity Ni-Mah or lithium batteries. Using alkaline would have caused overheating and may therefore have damaged the board. You are right to ask is a repair worth it? Almost certainly the answer is no even if possible. There are usually no spare parts available. Go back to tech support and this time simply report the bare facts -'It wont stay on'. Say nothing about the battery situation. Depending on the age of the device you may be offered a reasonable swap out price.
Jul 14, 2007 | Pentax Optio M20 Digital Camera
Pentax Optio M20 Digital Camera Logo
102 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
