Question about Cameras
Polaroid i834 lens bent and lens protecter popped off wont turn on for more then two seconds
  • 797 Answers
How did this occur?
If the lens was hit or dropped while the lens was out, that can cause a lot of damage.
First, Look at the lens as it is extended. You may be able to gently push the lens in the opposite direction after starting the camera. This has worked for me on some.
If the lens protector on the end of the lens has popped off, look at the problem. If the shutters have also popped out.... oh boy, that may not be able to be fixed.
You may want to sell this camera on Ebay as a broken or AS IS, PARTS, FOR REPAIR. These lenses are not the easiest to repair, and the small parts inside may be broken.
Posted on Jul 19, 2008
I dropped my Polaroid i532 and now the lens wont
hi,
You must get your cam serviced... due to **** your motor (which operates lens movement has stop working. or the lens has bent and therefore stucking..... taping lightly near the lens may help you... The common reason for motor not working is loss of power connection....
Hope this has helped you..
Please rate the answer...
Thanks....
Jul 07, 2010 | Polaroid i532 Digital Camera
Looking for a user manual for model i834. Is
Here is a link to your manual. It is on the right side of the webpage where you see two men (cartoon characters) standing
http://safemanuals.com/user-guide-instructions-owner-manual/POLAROID/I834-_E
I hope this helps and good luck. Please vote and leave a message.
Oct 30, 2009 | Polaroid i834 Digital Camera
I click the on button on polaroid i834 digital camera, then stops
Sounds like the battery is too low. Replace/recharge batteries.
Oct 03, 2009 | Polaroid i834 Digital Camera
I have a polaroid i834 and the lens won't go in or out
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jul 05, 2009 | Polaroid i834 Digital Camera
Lens shutter does not open while lens pops out using new batteries
What you are seeing is not the shutter but a lens protector. I think the camear has dirt in that area and it needs to be cleaned out. Do this with compressed air.
May 02, 2009 | Cameras
My camera turns on,beeps 3x and then my camera shuts off.
Get some new rechargeable batteries, charge them over night, then put them in the camera. Take many pictures of family!
Mar 20, 2009 | Polaroid i834 Digital Camera
I have a polaroid i634 can you help?
how do I empty a full memory on a polaroid i634
Dec 12, 2008 | Polaroid i634 Digital Camera
Installing polaroid i834 software
ughhh same here,if you find anything out where to install it let me know,imma look more if i find it i will post it here for you =]
Nov 15, 2008 | Polaroid i834 Digital Camera
Polaroid i834 the camera beeps three times and turns off,then the lens got stuck out
There could be something obstructing the lens. Camera turns off if it can't extend and retract the lens. Turn it downward, try helping the lens in as you turn it on, try blowing compressed air around the lens itself, or if all else fails spraying around the base with a light dusting of CRT cleaner (90% isopropal alcohol spray)
Jul 28, 2008 | Cameras
Polaroid i834 turns off imediately after turning turning on.
I had the same problem until just a while ago, when I realized that the lens was tweaked. It was stuck. So I turned the camera on and gave the inside part a yank before it turned off again. It took me a couple of tries but eventually the lens corrected itself and now my camera works fine. If you do it a couple of times and then start to hear three rapid beeps (sounds like 'be-du-dum') before the other three beeps (beep... beep... beep) then your getting somewhere. Hope this helps.
Mar 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Cameras Logo
207 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
