Question about Xerox 5305 Copier
I keep getting a display message of L and a 3
My copier displays an L and a 3 when you try to make a copy. no one can help me can you tell me what the L and 3 means.
  • reneewray Jul 24, 2008
    tried that and it did not fix it . we took it apart and everything . any ideas. thanks
    we tried that and it still won't work . The little gear that slides the glass back and forth is slipping as well. how can we fix both ?
    Problem Solver:
  • 8 Answers
That little gear in the back is called the bushing and may be damaged. there used to be a customer repair kit that was sold for out of warranty customers. since that product is no longer supported, I'm not sure you can still get one. take a look at the gear to see if it is missing teeth or is cracked.
Posted on Aug 26, 2008
  • 667 Answers
Hi renee - L3 error code indicates a platen problem. The platen did not move within 15 seconds after the main motor turned on.
Check if any items are blocking the movement of the platen. The platten is the glass that moves across the top of the copier when copies are made. It must have free movement.
1) Remove the obstacle if there is a blockage.
2) If there's no blockage ,power the copier off for 30 seconds, power back on and try another copy.
If this fixes your problem PLEASE rate this as fixed. Let me know what happens. If you need more help just add a comment and I'll be happy to assist you further. Thanks.
Jeff
Posted on Jul 19, 2008
Strange error messages and won't print
did u try for a reset??
for any kind of error do a reset first
Jun 24, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Not making copying and show error code no c-0098
Try reset the error code.
Turn OFF the copier,press and keep pressed the Utility key turn ON the copier wait to display appaire the Trouble reset message.Release the Utility key,touch the message and turn OFF the copier.Wait 1 minutes and turn ON.
Mar 26, 2013 | Minolta C350 Printer
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea...
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Oct 03, 2010 | HP Office Equipment & Supplies
Message CHECK SPF/RSPF and will stick on scan often.
In the Jaguar series, (ar-168d) you will need to get into the simulations; press in rapid succession: # * C * You will know when you did it fast enough when all the display lights go out except the number display, press 41 start/copy. then 6 start/copy. Let the copier do what it needs to.
The scanner will move, keep the lid down, it will let you know when it is done when it goes silent. Then press CA key to clear out and try copies again.
Dec 15, 2009 | Sharp Office Equipment & Supplies
Copier not coping due to teo messages on the display, 020 and C-6
Hello sir; your machine temperatur too high need to reset the procedur as follow;
1, press "stop/clear" key, "start" key", and left copy density key.
2, press "stop/clear" key again.
3, enter U163 press "start".
4, when screen display "CLE" then press "start" again to reset.
May 29, 2009 | Kyocera Office Equipment & Supplies
Trying to scan, but keep getting error code 2,162,0 My scanner printer - my Canon 4370 won't scan. Printing and copying is working fine.
I finally got a solution to my problem, which is the same as this one. When trying to scan via USB, you have to make sure the unit is set to USB. On the top panel just above the LCD display, is 3 buttons, Copy, Fax, Scan. Hit the SCAN button, till the display says USB SCANNING. Then try to scan again. Good luck!!
Apr 23, 2009 | Canon ImageCLASS MF4370dn Laser All-in-One...
Image runner 5020 will not print or copy
Hello Ernest T,
If the main thermistor which monitors the temperature of the fusing unit (that hot as hell area) is out of postion this problem can occur. The thermistor determines when the fusing area is hot enough to allow the copier to display"READY". If it is backed away from the fuser roller it cannot reliably read the temperature and it may cause the copier to display suspended because it reacting as if because of a long copy run it could not keep up the temp and so it "suspends" as it tries to ramp the temperature back up. Make sure the thermistor is touching the fuser roller.
Apr 16, 2008 | Canon imageRUNNER 5020 Copier
Hp psc 2175 all in one SCANNER PROBLEM
This is only a software issue. Reinstall the software or try installing on other system
Mar 19, 2008 | HP PSC 2175 All-In-One InkJet Printer
Cant get rid of blinking error message, nothing works
H4-00 is a fuser related service code. you need to get into the simulation programs and run sim 14 to reset the code. Make sure there is no paper jammed in the fuser. (The hot part on the right side inside the door)
Dec 02, 2007 | Sharp AL-1655CS Copier
Xerox 5305 Copier Logo
109 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
