Question about Compaq Computers & Internet
The computer turns on with both AC power and battery pack, windows boots up, but there is nothing on the screen, only vertical lines. There has never been any physical abuse to the computer ie. dropped.
    Scholar:
  • 99 Answers
Check the Video Cable and make sure it isn't somehow dislodged from the monitor or the Video Card. You can also make sure the video card is seated well in the motherboard. Sometimes when a cord is bumped it can move the video card just enough to keep it from getting a good signal.
If you see the boot process on the screen then the problem isn't the monitor or the video card ... its in windows!
If that is the case try booting to safe mode as it only uses the VGA settings and not all the windows drivers. If you get a good picture there, then run the system restore or an antiviruse program in safe mode!
Posted on Jul 19, 2008
My g60 -235dx laptop on startup error message say communication problem with I/O deveice, HD, flash drave , CD-ROM
G60-235dx. (2011 model, is my guess)
ok tell the full story please.
PC boots sequentially.
progress in that matters. so it seem windows unstated runs?
XP?
so you power on and what happens ?,
errors before windows logs in or after.?
my guess #1 is the main laptop battery is bad, remove it.
this pC runs on AC power pack endlessly, (AC power good)
dim screens. can be bad CCFL lamps or low power in the PC.
so again take out the battery
what flash drive, remove that, test the pC with no usb devices at all plugged in.
just an A.C power pack and no main big battery.
this PC has old CCFL lamp tubes that all go dim, fast.
turn yellow then dim the flicker and then DIE for ever.
all do. some in 2 years time never turned off. they do.
it the screen goes black use a flashlight if data is good on the screen the back lamp is croaking. (***** of CCFL tubes)
there are many cause of black screens, I can list 30. (will not)
but dim screens are only
1; main battery bad and shorted.
2: AC power pack near dead. (weak happens)
3: shorts in the main board, modules.overloading power buses.
4: CCFL dim as every one this old does, all do.
see flash light test.
http://www.pcdied.com/monitors.html#flashlighttest
Oct 18, 2017 | HP G60-235DX Notebook
Left computer running with charger connected. Screen went blank and light showing power connected was no longer lit. New charger did not solve it. New battery (with some charge) worked. Still no charge so...
If your charger is working properly and the laptop is as well, then the laptop should work without a battery in it at all. If your new battery worked and laptop worked with it until the battery died, then the charger or charge port is damaged.
If it does not work with charger plugged in without a battery, then your charger(s) or the laptop charge port itself may be damage or broken. Or worse, the laptop may be dead.
If the laptop does nothing even with a good battery with charge (no fans, no boot, nothing on-screen, no noises) you're laptop could be dead; likely a burned motherboard or processor. It may have overheated or something along those lines.
Jun 13, 2017 | HP Compaq 6730s Notebook
Computer was on AC power. Left unattended it shut down. Would not wakeup. Shut down fully, it would not come back up. Get a 2 short beep code. Invites an F1 to go to setup. Won't go to setup. Screen then...
Can you tell if your AC power cord is working? (Is there a light on the computer that comes on when it's charging?) If the power pack went dead, your battery could've died and now you get no power to the PC which is why it won't boot up.
To test, take out the battery and plug the AC cord in and try to boot up. If nothing at all happens without the battery, then your power cord or power pack is dead, and you just need to replace it.
May 29, 2010 | IBM ThinkPad T21 Notebook
My sony vgn-tx17p won't boot. Te power light turns on and nothing shows up on te screen. Please help
  1. turn off the computer
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM/memory.
  4. without the battery or ac adapter, press and hold down the power button for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
Feb 26, 2010 | Sony VAIO PCG-TR3AP1 Notebook
Nothing but multi colered lines verticly on the screen
Try this:
Turn it off.
Disconnect power cord and any other device attached to it.
Take battery out.
Without anything attached. Hold down the power button for 10-15 seconds.
Connect the power cord only.
Hold down F2 (while it's off)
Turn it on while holding down F2.
Let go of F2 when something comes out of the screen.
If multi colored lines still appears.
You have either defective LCD(screen) or video card.
Jan 30, 2010 | Toshiba Tecra M2 Notebook
Laptop wont boot up
Stay away from Emachines in the future. Pay another $100 and get a real computer.
1. check that nothing is in the CD-Rom drive and restart the computer.
2.Shut down the computer. Unplug the AC power. Remove the battery pack. Wait 2 minutes or until machine cools.
try powering on comp on battery alone, then try with AC power alone.
Dec 26, 2009 | eMachines eMD620-5133 Notebook
Blue Screen
please remove battery and ac-power for a couple of minutes and then try to reboot the computer.
if it still doesnt work, shut it down, remove battery and ac.
remove ram
connect ac-power
try to boot without ram
remove ac power
insert ram
insert battery
connect ac and try to boot again.
when the blue screen appear, please write down the top line that looks something similar to this:
IRQL_LESS_OR_NOT_EQUAL_ETC_ETC
and the line close to the bottom that says
STOP: 0x000021 (0x000+++alot of not needed numbers)
when you have done that please come back to me.
May 29, 2009 | Acer Aspire 4520-5141 Notebook
My toshiba 2455-s305 wont boot up
If you are familiar with your laptop, i.e. the locations of hard drive, try to take it out of the its bay and put it back again. Also, if you can have someone check your battery packs, because from my experience with this laptop, when the battery packs is not charging well, i got some booting up problems.
Mar 19, 2009 | Toshiba Satellite 2455-S305 Notebook
Toshiba Satellite L25-S1216 - blank screen
Try to shutdown, remove battery, remove AC plug, Press and Hold Power button for 30 seconds, replace battery and AC adapter and test.
do you hear windows booting ( the startup sound) after a few minutes, if so there may be a monitor hardware problem
Feb 27, 2009 | Toshiba Satellite L25-S119 Notebook
Gateway 400SD4 Power Problem
Faulty Battery.
Get a new one.
If that is not the problem check the ram.
Jul 01, 2008 | Gateway 400SD4 Notebook
Computers & Internet Logo
24 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
