Elevating loud noise and pop
Got this new about one year ago and recently it will start this hissing noise-floor type of sound through the speaker that eleveates in volume until it pops real loud (and then it's done). I unplugged the pedal switch and the speaker input, but it still does it. It happens randomly, and will repeat, making it unreliable for gigs. thanks for the help!
  • 1,512 Answers
Hi melissa961
Not sure what make and model your rig is but the symptoms you have are classic for a failing transistor or capacitor. There is not a lot you can do about this except trace down the faulty part and replace it. We do this in the workshop by cyclic heating with a heat gun, and cooling of individual components with freeze spray until we locate the offending part. If it is a year old, I am hoping that it had a 1 year warranty, and that you are close enough to the end of it that you can claim the repairs as warranty. Sorry that this does not actually fix the problem for you, but now you know what you have to do next. Get the amp back to the retailer you purchased it from. Hope it all works out for you. If my advice has helped to resolve the problem for you, a FixYa rating from you would be great. Cheers
regards
robotek
Posted on Jul 21, 2008
I have a Magic Chef refrigerator in my apartment that is approximately 11 years old. It has worked fine until apprx a year or so ago when it became louder and was emmiting more heat. We cleaned the coils...
this problem is creating by compressor bec u said that this unit is about 11 year s maybe the wear and tearing of mechanical parts thats cause of vibration and humming sounds, of ref. heat is only normal try to replace new compressor or replace new unit of ref.
Feb 05, 2011 | Refrigerators
Loud hiss in bose multimedia speakers
The speakers are to close either to a printer or the monitor this due tio the model of the multimedia speaker system.
Mar 12, 2009 | Audio Players & Recorders
Speakers have hissing noise coming out of them
Hook a graphic equalizer between the piano and speakers, and turn down all sliders above 8 kHz. Since the highest note of a piano is 4186 Hz (4.186 kHz), you'll still hear all the notes but cut the hiss. If the hiss is coming from the speaker's power amplifier (in which case the equalizer won't help), turn down the speaker volume and turn up the piano volume. Live instruments generally need some doctoring to sound good through high-quality stereo equipment, as they only produce a limited range of frequencies whereas good speakers reproduce a lot more - including hiss.
Dec 25, 2008 | Onkyo GX-D90 Main / Stereo Speaker
Static noise from car stereo
change youre speakers they are blown if they are making staticy sounds i have recently chnged my speaker cuz of the static and it was kuz they were blown
thats all i can think about
hope it works
Oct 28, 2008 | iLO XM-MP3-CD Car Stereo
Guitar amp make large crescendo-like noise, loud pop at end.
Same loudness, no speaker? This sounds (no pun intended) like a filter capacitor shorting out. Open it up and VERY CAUTIOUSLY look for what is making the noise. Filter capacitors can eject hot stuff. Very dangerous.
Jul 22, 2008 | Audio Players & Recorders
Intermittent, random, loud popping noises.
you have a problem with your amp. most likley the finals are passing dcv intermitently to the load.
May 28, 2008 | Audio Players & Recorders
Logitech x530 hissing noise
I had the same problem for the longest time with my set of Logitech 540 5.1 speakers. Turns out the solution was pretty simple. All I did was open the Master Volume controller and mute the Microphone. Hissing went to zero. Sound is great now.
May 15, 2008 | Logitech X-530 Computer Speakers
Overloading
hi mate, ive had the same problem before with this amp. i bought it new aout 6 years ago and bought another new one about 1 year ago, new, for £70!
on the first amp there was a problem with the surround sound aspect, it kept overloading when turned up even a fraction, it would tick 4 times and power off. Eventually the surround sound stopped working all together and whenever selected made a VERY VERY loud hissing/crashing noise through all my speakers, blowing one of them, SO BE VERY CAREFULL.
when that happened i assumed was broken so bought another one, and had same overload trouble when i got a new speaker package.
Im pretty dam sure it was the ohmage ratings being different on 2 of the surround sound speakers that srewed the 1st one, so id suggest you check theyre all ok, as well as the speaker watt-age.
what are the specs on all your speakers (ohms and watts RMS)??
do you listen to LOUD music through the 5.1 option??
hope this helps, if all else fails buy a new one mate, theyre so cheap. go into panasonic shops and see if they have any left.
Apr 23, 2008 | Panasonic SA-HE7 Receiver
Distortion/noise and buzz in front left speaker
Try to see if the reciever will make the buzzing/noise without anything connected to it except power, and speakers. Tune into a local radio station and see if the noise continues. If the noise has stopped, then you know there is an issue with the player or cable.
Dec 28, 2007 | Onkyo TX-SR503 Receiver
95 people viewed this question
 Grubhead
Grubhead
