Error code dc or UC is an unbalance code for FAV6800A or FAV9800A. Is that the error code to the LED display if the machine model is the FAV6800A?
If so do you want to DIY the fix or call in a repair service.
In most cases the repair service may not have a clue and you end up throwing $60 or so down the drain on a usless service call.
See this post it helped someone recently
http://www.fixya.com/support/t8054642-machine_flashes_dc_twelve_minutes_go
Follow the links if you want to save your $1K machine.
Hello & Welcome to FixYa
Error code 5d/Sd means suds have been detected. To solve this
problem you have to take the bottom front panel apart and then clean the drain
filter pump assembly completely, make sure the washer is unplugged before
working on it. Please get back to me if you have any other questions.
Kevin
