Question about Cameras
My sharp vl-e650 video camera displays e007 on the screen
SOURCE: Sharp VL-Z1 Mini DV
yah im another 1 of those dumbstuck users with the fatel "E007!!!!" problom and i found my camcorder on the street (it might have fell out of a suit case) no damage but i dont have the manuel hat the heck does E007 mean?
tnx
gster
Posted on May 09, 2008
melnavz
  • 1226 Answers
SOURCE: Sharp VL A10 audio video cable
Is the both ends of the cable color red, yellow and white.
You can buy it in any electronics center or store. just tell RCA Cable.
melnavz
Posted on Aug 26, 2008
SOURCE: Drivers for Sharp Viewcam VL-Z3E
USB driver for Sharp VL-Z800
Posted on Oct 07, 2008
SOURCE: SHARP Viewcam z vl-Z500H-S Camcorder
To transfer video you need to use firewire, not usb. If you use firewire to connect, set the camera to the 'play' icon and then open up a capture program (ie, movie maker) you should be able to just record/capture from there. Good luck!
Posted on Nov 19, 2008
  • 9 Answers
SOURCE: "Dew" sitting on my Video Camera
Dew Formation
What is “dew formation”?
When cold water is poured into a glass,
dew drops form on the glass. This clinging
of water drops is called dew formation.
When dew forms in your camcorder.
Dew will gradually form on the head drum
of your camcorder and make the video
tape stick to the head. This causes
damage both to the head and the tape.
When dew forms, recording and playback
may not function properly.
Dew is likely to form in the following
circumstances:
—When moving the camcorder from a
cold place to a warm place.
—When placing the camcorder in a cold
room which is then heated rapidly.
—When moving the camcorder outdoors
from an air conditioned room or car.
—When placing the camcorder in the
direct path of air
blowing from an air
conditioner.
—When placing the
camcorder in a
humid room.
How to prevent trouble.
When using the camcorder in a place
where dew is likely to form, allow the
camcorder and the video tape to
acclimate to the surroundings for about
one hour.
For example, when bringing the
camcorder indoors after skiing, place it in
a plastic bag.
1Be sure to tightly seal the plastic bag
containing the camcorder.
2Remove the bag when the air temperature
inside it reaches the temperature
of the room.
“Dew” warning feature
If dew forms, the word “DEW” flashes on
the screen, and the power will automatically
turn off in approximately 10 seconds.
Plastic bag
1If “DEW” flashes, remove the cassette,
leave the cassette compartment open,
and wait for a few hours to allow the
camcorder to acclimate to the
surrounding temperature.
2To use the camcorder again, turn on the
power after waiting for a few hours. Be
sure that “DEW” has disappeared.
3Do not insert a cassette while “DEW” is
flashing; this may result in damage to
the tape.
4Since dew forms gradually, it may take
10 to 15 minutes before the dew
warning feature engages.
Posted on Apr 20, 2009
I have a sharp vl-z300 camcorder which is displaying an e007 error can you help
The 007 error is associated with dew sense and is a fairly routine repair.
PC board traces open at System Control IC, and will need to be hard-wired. I would suspect that any reputable electronics service facility should be able to perform this repair.
To find a Sharp authorized center in your area, contact Sharp support at sharpusa.com/CustomerSupport.
Hope this helps (remember to rate this free answer and leave a testimonial).
Sep 27, 2011 | Sharp VL-Z300U Mini DV Digital Camcorder
I have a sharp vl z300 displaying an E007 FAULT .CAN YOU HELP WITH WHAT IT IS AND IS IT WORTH FIXING
Cancorder not wrking-e007 error message
moisture in the cassette holder. Take out the cassette, leave the holder door open for a couple of hours in a dry, warm location, and it should work again.
Sep 12, 2009 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp viewcam
my sharp viewcam model no VL-E650U CAN NOT PLAYBACK IN COLOUR AND SOUND
Apr 18, 2008 | Sharp Viewcam VL-Z3U Mini DV Digital...
E007 and DEW indicator
Few restarts fixed this for me but I know this is going to come back again soon.
Mar 30, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Sharp VL-Z1 Mini DV
posted on Aug 20, 2007 Hello and please any body shed some light as to why would the cassete holder door will not close. It was ok, and suddenly I got the ?ject tape"warning. I took the cassete out but I saw there was some loose tape. After that it does not close. Thanks everyone.c
Jan 18, 2007 | Sharp Viewcam VL-Z1 Mini DV Digital...
Camcorder Error
for a quick fix I usually override it by slightly opening the tape when its being loaded, i think its a sensor issue. my cams been rendered useless because of this stupid error, I cant even sell it now because it only works 10% of the time and that's usually when im just checking out the cam, only when I need it the most does it screw up on me
Jun 06, 2006 | Sharp Viewcam VL-A10U Camcorder
I keep getting alarm with E007
hi the device is dameged dont take the tape out call help http://www.sharp.co.uk/Contact.aspx good luck
Mar 27, 2006 | Sharp VL-Z500H Mini DV Digital Camcorder
Cameras Logo
106 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
