Question about Zanussi Dishwashers
Blows main house breaker
Machine blows main house breaker as water level is reached in machine
all systems ok until this point
  • 640 Answers
I would disconnect the heater element.When you turn the unit back on and all is ok the element is bad if not the pump motor is your problem.
Posted on Jul 19, 2008
Any suggestions to washing machine which works with irregular water supply?
all models have a water level sensor in them that you set according to the wash load you have
when you turn them on the water flows until the level set switches off the inlet tap and proceeds to wash
regardless of the water pressures and delivery, the wash will not proceed until the water level setting is reached
the problem that you face is that during the rinse cycle , there may not be enough water available to rinse within the rinse/ spin cycle
Aug 14, 2016 | Indesit Washing Machines
Why does fuse blow when turn shower t warm hot ???
Probably your unspecified device has a heater incorporated and your breaker's amperage is too low for device working for hot water..
Check your electric installation.
If it's ok, your device might have a circuit problem. Check it using proper electronic testers.
Aug 09, 2015 | Washing Machines
I have been using my Bosch Xcel PBH 600 watt when suddenly it made a loud bang and stopped working.it also was smoking and blew the house mains switch...
If it blew the "house main" and the circuit breaker did not blow, it indicates the breaker for the unit and the associated circuit wiring has major problems and you need to get them checked asap by a licensed electrician. Don't use it again until the circuits are chceked.
Aug 20, 2014 | Washing Machines
My Kenmore 300 model # 11028332700 washing machine filled with water and stopped working. It won't agitate, spin or drain. I've replaced with lid switch and checked the coupling and it's fine. What's...
Possible fault with the water level sensor , it must send signals to the program controller main board to switch on the motor for the wash cycle only when the water level set is reached. Remove the water level controller unit , check the diaphragm with a blow test , it must switch with vacuum , if not replace.
Aug 22, 2013 | Kenmore Washing Machines
Is there a fuse or circuit breaker i can reset if 220v was put to my washing machine? i was rewiring the breaker panel and got two circuits reversed, the washing machine circuit and the water heater...
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse
Jan 10, 2010 | Washing Machines
Maching stopped mid cycle & now has no power, it will not turn on, all fuses are ok
It doesn't work at all If your washer doesn't seem to work at all, check these: No power Lid switch No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped? Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it. Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
Jan 02, 2010 | Hoover Washing Machines
Washer runs but the water does not turn off, THe waterm hot and cold just run until I cut it off manually.
while machine is filling turn of power if the water is still entering machine you have a mechanical fault water valve hot or cold needs replacing if water stops when power turned of you ave an electrical or control problem check water level hose from tub to level switch for damage or perishing if ok check water level switch blow into it see if it clicks if not replace also while blowing hold pressure to see if the diaphragm in the pressure switch is not perished keep me informed
Nov 05, 2009 | Washing Machines
The washing machine doesn't come on when switched on at power point. No lights or sound at all. The fuse to the power point is all good. Machine was working fine the last wash load. Tashina
No power
Lid switch
check out this.
Jul 14, 2009 | Fisher Paykel EcoSmart GWL15
My krups 9000 keeps on setting off the saftey switch at the main powerboard off my home
you mean house breaker i guest you tried the machine somewhere else and if still blowing breaker check the power cord open it maybe with vibration power wire are toughing themself inside machine cheers
Jan 26, 2008 | DeLonghi EC140 Espresso Machine
Kenmore 60 series washer
Dec 07, 2007 | Kenmore 24032\24036 Top Load Washer
Dishwashers Logo
94 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
