Question about Maytag Refrigerators
Refridger doesent work - Maytag Refrigerators
    Master:
  • 848 Answers
Provide more details about your problem ...........
Posted on Jul 19, 2008
    Sergeant:
  • 260 Answers
Without more specifics it is hard to answer your problem.
You can try unplugging the refrigerator and then plugging it back in after a few minutes. You can try defrosting the fridge if you have a lot of ice built up. You will probably need to contact a repair service if you are having a problem with the fridge cooling.
It helps to have more information about what specifically the fridge is not doing for you.
Ken
My E123CS55GS Electrolux Side by Side Refridge is not working on the refridge side. The "High Temp" light came on, so I 1) checked the door to ensure it was closed tight, 2)Checked Fridge setting- Set at...
when temperture is droping its a good indication it fuctioning properlt but when the refrigerator doesent go down to the desired temt of 37 you may have to clean the coils in back of the refrigerator this can be done easily as it worked for me you can use a aircompresor to blow any heavy dust the unit has acummilated or you can use a soft brisle brush even a tooth brush is good in hard to reach areas.
Sep 09, 2013 | Electrolux EI26SS55GS Stainless Steel ...
Hp dv6-6120us problem with finger print reader after formating doesent work any more
try and download the exact drivers from ho official site,and run these set of hardware drivers you are having problems with....i hope this will be of help to you,,...bye ya
Feb 09, 2013 | Dell F3534 Touchpad
Frigidaire refrigerator - Model #FRT21BHscW2 manfuactured in 2004 has stopped cooling - freezer unit works - icemaker works - fan is running and compressor is warm - unit is clear of dust and particles. ...
Hello
There is a plastic duct work leading from the freezer to the refridge.Check that there is nothing blocking this ductwork.Also check fan in freezer for operation.
Have a look a refridge door seal also make sure it has no cracks or is not coming off.
Jun 13, 2011 | Frigidaire Refrigerators
The freezer works but the refridge doesnt
the freezer back wall need to be open and check the heat element
and the thermostat , also make sure the fan is working in the freezer.
if the frost on the coils are not even then it is sealsystem that is bad news,
but if it is just frozen defrost
it with hair dryer and check the elements i told you to check
Dec 31, 2009 | Refrigerators
I connected our Dometic 2620 to propane line, no problem, but when I plugged it into power - nothing. No lights, no gas activity, nothing. Any hints?
Check your AC breakers, mine was on the same circuit with a GFI outlet that had tripped, took a bit of looking to find it, Good luck.
Jun 13, 2009 | Dometic RM2620 Refrigerator
How old could it be? I bought a house with this refridge already there.
Go here to find out how old it is. need serial # though.
http://www.applianceaid.com/appliance_age.html
Good luck and please rate Fixya!
Apr 12, 2009 | Refrigerators
Lost of sound card
When you say your sound card is lost. do you mean it doesent show up in device manager?
if it doesent show up in device manager, remove the sound card (taking all neccessary prcautions) then clean the contacts and try reinstalling it. if that still doesent work try a different PCI Slott.
Ian
Mar 12, 2009 | Compaq Creative Sound Blaster PCI 128...
Ice maker not working now refridge seals are hot, but still cooi
okay....i used to be an employee at Vinothque and these piece of **** units are always and I mean always running low on refrigerant, due to a slow leak in the system. You will have to get tech to come out and recharge the unit
Dec 29, 2008 | Refrigerators
Refrigerators Logo
48 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
