Question about Mitsubishi WD62627 62" HDTV
Using a higher voltage cap
Would it damage the tv set to replace caps in my ws-65513 with 35v instead of 16v?
thanks Do you have any diagrams of the board to be repaired so we can locate caps
  • 2,334 Answers
The 35v will be better to use instead of 16v as long as the diameter it does not affect the spacing between components.
Could gives us more info about the kind of repair you're trying to do?
Posted on Jul 19, 2008
  • Jaime Hernandez Jul 19, 2008
    The capacitance has to be the same but the voltage anything bigger then 16v will do just fine.
  • 6,487 Answers
It will be unstabvle if you will be using the 35v so I recommend you to get a 16v instead to make everything work.
Hope that helps.......
  • Mitsubishi Master
  • 19,396 Answers
Need to know where capacitors are on mitsubishi ws 55511 tv are located at have back of tv off and cant locate them please help thanx
they are located inside the DM modules case( Metal Case on far left side ) open the metal case and you will see 7 caps on the DM power board. I am posting a pic of the board with the 7 caps that need replacement use 1000UF 25V caps to replace the 1000UF 16V caps that are currently installed.
Aug 08, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi ws 65513
Yes, 1000UF 25v would be fine. just replace all capacitors in DM Board.
Need further help, let me know.
Regards,
Sep 14, 2008 | Mitsubishi WS-65513 65" Rear Projection...
PLTV3250 have a blue screen. It won't power on
Hello
Probably a power supply - if you open the back of the tv (if you have electronic experience) find the power supply look for bulged capacitors and replace them.
power supply unit problem you have bad caps (capacitors) change all the caps or at least the ones that are leaking how do you see if they bad usually they are bold on the top instead of flat. change it with a higher voltage but the same UF. if it shows 10V-1000uf you change to 16V-1000uf or if it fits a 25V-1000uf.
THANK YOU FOR VISITING FIXYA
Mar 03, 2011 | Protron PLTV3250 32 in. LCD Television
Tv wont turn on power light just blink and nothing happen , no picture or sound
power supply unit problem you have bad caps (capacitors) change all the caps or atleast the onces they leaking how do you see if they bad usually they are bold on the top instead of flat. change it with a higher voltage but the same UF. if it shows 10V-1000uf you change to 16V-1000uf or if it fits a 25V-1000uf.
Feb 08, 2011 | Insignia NS-LTDVD19-09 LCD TV
TV will turn on but no picture or sound
Feb 08, 2011 | Televison & Video
1 Solution for ''can i use a 50 volts 2000uf instead of 35 volts 1500 uf on my plasma tv''
No you can't. The farad rating of the capacitor is extremely important. It is used to control things like frequencies, charge storage, etc. the best is always to use the exact part.
You can in emergencies go one voltage rating higher, but you got to find out what caused the blow cap in the first place.
If it was just say dried electrolyte replacing the cap will fix it. you can say replace a 10V cap with a 16V of the same uF rating. But always try to get the exact same uF and Voltage rating. having the temp match too is perfect.
Feb 27, 2010 | Samsung DLP HL-P5663W 56" TV
Replacement Caps green blinking light
Someone gave you the wrong information. The caps on the WS65513 C9B01, C9B02, C9B10 and C9B11 should be replaced with 1000uf 16V 105 degree radial capacitors.
Jul 25, 2008 | Mitsubishi WS-65513 65" Rear Projection...
You can use 16v or greater = I ordered 25v to keep the size down, 35v is ok,if you must,you can lean them over 90 degrees.
there is plenty of room............................T.
Dec 12, 2007 | Televison & Video
DM Power on problem - Can I use 35V Caps instead/ (Techman??)
If they fit, sure but If I'm not mistaking, they are too tall. And they really should be the high temp caps, as if you do not use hi temp caps you will be in the same boat down the road. Good Luck
Jul 02, 2007 | Mitsubishi WS-55513 55" Rear Projection...
Mitsubishi WD62627 62" HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
