Washer Model No.: 110.44832200
When I try and start the washer nothing happens. No lights or error code or anything. I have checked the power.
Check a different power outlet.
IF the washer does not start at all then it is probably a fault in the power supply unit.
Posted on Jul 19, 2008
It can also be a problem with the inlet valve that locks up after pumping some water, in this case you fix it replacing it. Start testing the inlet valve and eventually replacing it.
Here is How to Test the Inlet Valve
If inlet valve is ok , usually is faulty control . replace panel
Good Morning friend, thank you for your post!
From my understanding your Electrolux washer is not starting no matter what buttons are pushed. This could be a possible problem with your keypad or control panel. I noticed that you have already performed a reset and that was done when you unplugged your washer for 15 minutes. I would now recommend having a technician out to perform a diagnosis. In order to do so you would need to disassemble your washer and test each component to make sure they are working properly. The technician would have the appropriate tools needed to do this accurately. If you need some assistance locating a technician you should be able to visit the manufacturer's website for additional assistance. I hope this information is helpful for you. -Matt
May 20, 2015 | Electrolux IQ-Touch Series EIFLS60LT 27"...
Oct 17, 2012 | Amana Washing Machines
Nov 22, 2017 | Whirlpool WTW4950XW Washer
Feb 03, 2018 | LG WM1814CW
Mar 22, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Aug 20, 2009 | Frigidaire ATF6000ES Front Load Washer
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Jul 13, 2008 | Samsung WF337AA Front Load Washer
Nov 19, 2015 | Kenmore Elite 45986 Front Load Washer
222 people viewed this question
When I first encountered the problem described above I did try another outlet. Nothing happened. As per your suggestion I tried yet another outlet. In this case the red panel lights came on; I started the machine; a small amount of water started; then the lights went blank again. All of this took about one minute.
Model No. RTW4640Y01. The green light comes on but the washer will not start.
