Question about EuroCave Comfort 260 - Black Solid Door
Eurocave 260 the eurocave 260 hass ice inside
  • Kroegs Nov 27, 2008
    ice on the back panel. Three frozen bottles, I think I caught it in time. I shut it off and am waiting for defrost.
    Anybody know a better solution ?
3 Suggested Answers
SOURCE: Eurocave comfort 264: Problem, ice formation
It's likely that you need to change the filter. Have a look at this post:
Posted on Oct 15, 2010
  • 11800 Answers
SOURCE: my eurocave 283 keeps icing
The icing is caused by the abnormally low temperature - the humidity in the air freezes on the cooling element. I suppose that you have tried to raise the temperature setting and it didn't helped.
That shouldn't happen: not only the temperature inside it shouldn't go below 4C - if that would occur the temperature alarm should ring, the warning temperature icon would be displayed and the compressor would be cut off - but if it would (for some unknown reason) go below 0C a heating element should kick in to prevent the formation of frost.
Since that happens it's clearly a fault in the temperature controller and its sensor. This isn't something that you can fix yourself: the unit will have to be opened, the control board tested and the fault identified and fixed: if the compressor is almost continuously active the power relay is stuck , if it runs normally then the temperature sensor is defective.
Posted on Jun 17, 2011
Why is our EuroCave DUO wine cooler model D264 freezing 1/4 inch of ice on back wall inside cooler?
Most cases of ice build up can be traced to seals that leak humid air into the cooler. Check the door seal carefully using a fresh $1 bill. The bill should not pull out easily when the door is closed. If the unit has a self defrost feature it it is not coming on. Ice buildup inside a wine cooler is very rare. The cooler box should not reach 32deg in normal operation. Does the unit seem to run continuously?
Sep 10, 2014 | Furniture
Ice in the unit. Whould shoud I do? Who should I contact to get the service...What kind of filter does it take and where can I purchase it?
I also have problems with ice in my unit. How can this problem be solved? Do it need a repair technician to come out?
Sep 02, 2011 | EuroCave Comfort 260 Collector's Package...
Eurocave comfort 264: Problem, ice formation inside the unite , half the way the middle section of the unit ( Racks 8-10)
Sep 30, 2010 | EuroCave Comfort 260 Collector's Package...
Thermostats are not working; unit is freezing up inside;
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
defrost timer is not working..
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Sep 10, 2010 | EuroCave Comfort 260 2-Temperature Wine...
Moving a Eurocave wine cooler laying flat
the reason you should not lay a fridge/freezer on its side is that you will get air bubbles in the cooling pipes,which you may not be able to get rid of when you turn it back upright.I have moved loads of f/f, in the past and have had no problems,as long as you give the unit at least 24 hours to right itself.....and keep the door(s) closed while it is "resting"
Apr 17, 2010 | EuroCave Comfort 260 Collector's Package...
Problem with compressor
it is entailed process and you would need axcess to torch oxy-acc w #2 tip and silver solder, a evac pump, deep vac pump and container to capture the old freon usually compressors come with a new filter and the electrical parts per normal without sweep charge this process can take up to 4hrs to perform not for the unskilled if you do not remove the moistier from the system the new will fail shortly.....sorry for the news its be done by a professional...
Aug 19, 2009 | EuroCave Comfort 260 - Black Solid Door
No light, no fans running, nothing. temp gauge still working
It is possible that the unit has a switch somewhere which may have been accidentally switched off? On some units you can switch the complete unit off by turning the thermostat counterclockwise.
Mar 09, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave digital thermometer
The digital temperature display on the EuroCave has a small lithium battery that can be replaced by removing the bezel around the display. This was all that was needed to solve the problem.
Jan 22, 2009 | EuroCave Comfort 260 Collector's Package...
Eurocave Repair
can you tell if if it's running by putting your hand on the compressor,then we can go from there
Dec 17, 2008 | EuroCave Comfort 260 Collector's Package...
Top indicator light is on (orange)
Get info here:
Jan 03, 2008 | EuroCave Comfort 260 - Black Solid Door
EuroCave Comfort 260 - Black Solid Door Logo
73 people viewed this question
Top EuroCave Refrigerators Experts
Jim London
Jim London
Tom Chichester
Are you an EuroCave Refrigerator Expert? Answer questions, earn points and help others
