Question about Pentax Optio M20 Digital Camera
Camera won't turn on
I'm having the same problem you discribed but I have heald the buttons and turned it on at least 20 times and it still won't stay on. Is your's still working ok? Any other ideas?
  • 5 more comments
  • darkanonymou Jul 30, 2008
    the camera it's turnning on but for a little bit then shut's down
  • stalbond Aug 01, 2008
    i have the Pentax option M20 Digital Camera which just won't turn on. it was performing perfectly well but now it just won't start. I've done all kinds of things : re-formatted the card; waited hours before re-starting; pressed various buttons on the camera when starting...
    here's another strange thing - if i keep the playback mode button pressed before i hit the power button and then keeping the play button pressed, i turn on the camera, it does go into playback mode. but it just won't switch into camera mode.
    there's probably a software solution...
    thanks, sanjay
    stalreja@primus.ca
  • Anonymous Aug 28, 2008
    My Pentax optio M20 won't turn on.
    I pressed various buttons on the camera, the camera is dead!!!
    the camera not connect to the PC
    the bat and mem are OK
    thanks,
  • sambosam Sep 23, 2008
    My Optio M20 has the same problem when turning on - playback mode works but not the camera. also when holding down the menu button when turning on the camera displays the software verion 1.0 and the lens marginally extends then retracts continuously and only stops when the batteries are taken ouy
  • Fakecharles Oct 03, 2008
    I can get it to playback by holding down play/power but when I try to go to camera mode it beeps a lot and then shuts down. With the lens sticking out.
  • giannamarie2 Oct 13, 2008
    my camera will turn on and then turn back off with the lens sticking out
  • dagner Oct 22, 2008
    I have the same problem. Anyone find a solution?
I am having same problem.
send the solution
Posted on Sep 22, 2008
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Won't stay on
i could be that the rechargeable batter is weak. try replaceing the battery for a new one. also check that the connections for the battery are clearn.
I hope this was useful.
Feb 15, 2013 | Sony Cyber-Shot DSC-P52 Digital Camera
Kodak easyshare c1530 won't turn on after slighty dropped
Hello Doris, You can "GENTLY" try to push the lens slowly back into the camera with the palm of your hand, note I said gently and slowly, do not use force !!! Then turn on camera and see if this helped, if not it is repair time.
Jan 26, 2013 | Kodak C1530 Digital Camera
Date and time won't stay set
Had the same problem. The problem is a small button cell that needs to be replaced. From Canon's support page:
http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a510?CMD=MIXED_SEARCH&mName=PowerShot+A510&mType=PowerShot+A+Series&pageKeyCode=ekbresults&searchString=date+and+time+wont+stay&BASIC_SEARCH_CURRENT_TOPIC_ID=1236&BASIC_SEARCH_CURRENT_TOPIC_TYPE=0&RESULTS=RELEVANCE&RELEVANCE_START=1&RELEVANCE_COUNT=25&CONFIGURATION=1011&PARTITION_ID=1&TIMEZONE_OFFSET=null&USERTYPE=1&isSecure=false
Jul 13, 2012 | Canon PowerShot A510 Digital Camera
Panasonic 42 inch plasma wont turn on. red light blinks 10 times
I unpluged mine and the light was still blinking when it was unpluged. I thought that was weird. So I pluged it back in and just heald the power button in untill the light went out. It went out within ten seconds. I pushed the power button again and the tv went on. WOOHOO!!! Just needed reset, I guess.
Dec 10, 2011 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
My camera wont stay on it bleeps once then turns off
That sounds like your battery could be dead/not hold a charge. If you've charged your battery already and your camera still won't stay off and turns off right away, it's time to purchase a new battery for your Samsung TL105.
You can purchase replacement batteries quite cheap here:
http://www.amazon.com/Samsung-Digital-Camera-BP70A-Battery/dp/B003OEDQBE
May 07, 2011 | Samsung TL 105 Digital Camera
Easyshare Z1285. Lens stayed out. Camera won't stay on. Tried 3 new sets of batteries. Camera only 14 months old.
hello, you just not discribe proper your problem,if your camera turns on and whithin seconds its offf with beep on lcd then you need to cheak lense assembly,just clean it properly and fix it carefully,ihope you find what you want
Aug 25, 2009 | Kodak EasyShare One Digital Camera
Pentax Optio M20 Digital Camera Logo
100 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
