Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Whiny motor, less suction
The motor on my DC07 has become MUCH louder and whines, and the suction is much less. Do you have suggestions on troubleshooting?
Dave
  • stella4ever Jul 21, 2008
    had same problem - turned vacume over & the belt was not moving - too clogged with hair, string, etc. Cut that off, checked the easy places to check for a clog, turned machine on & it work perfectly.
  • gilkesonj Aug 06, 2008
    I have the same issue. I have removed the filter from under the bottom plate. the motor still seems loud and I did notice some dust coming out of the motor compartment.
    If I replace the filter will this make it less loud? I cannot imagine it would make it as quiet as before I had this issue.
    Could it be an accumulation of dust in the motor?
    Cheers!
    Jim
  • 328 Answers
Its not unheard of that the lifetime filtration filter may need replacing and dust can work itself into the main motor chamber even though Dyson claim their models have sealed motors. Whiny motors however can happen for a number of reasons such as:
  • Over-use
  • Motor bearings
  • Strain on the motor from another source i.e. the drive belt may need replacing or the caps on the brush roller at each end need to be checked.
Have a look at the drive belt / sole plate to see if there is any dirt clogging the system. Also check the inspection pipes on the Dyson and check that nothing is obstructing the air waves. Sometimes even a new filter (bottom of the bin) cures the problem and this can easily be checked by taking out the filter for a couple of seconds and using the Dyson to check if suction is indeed stronger.
Posted on Jul 29, 2008
How do I change boittom filter
Here is how to do it
https://www.youtube.com/watch?v=UtLEYpGqpWU
This is a good way to stop your motor burning out. I use the lighter white cloth filter rather than the purple hepa filter. It puts less stress on the motor and gives a little more suction at the expence of a tiny bit more dust making it through.
Jul 09, 2014 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have the DC07 model in the upright position suction is fine but when I drop the handle and go to vacuum it has no suction I've cleaned the filters and hoses for debri and still no suction and once I put...
Hi Chris,
I am very sorry to hear about this issue with your DC07 not picking up correctly. In most cases we may be able to resolve this issue by speaking with you directly and performing basic troubleshooting steps.
Please contact our US Dyson Helpline toll-free at 1(866) 693-9766 or our UK Support colleagues at 0800 298 0298.
Best wishes,
Jay
Dyson Customer Service
Oct 05, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Lack of suction
Do not think its motor .......Yoy need to see thats its not Cloged if so clean.......
Feb 21, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
Noisey DC07 Bagless Upright Cyclonic Vacuum; lack of suction...
Hi there it's SmartAlec from NelsonVacuums.com.au here. It is very likely you have a problem in the radix assembly or the filter is actually worn out. Basically to test either simply remove one then turn it on to test. If it runs better with out the filter (washable is most likely culprit) simply purchase a new one. If it is the radix assembly that is the problem it is possible to clean inside the little tubes by taking off the top and literally clearing dirt and fluff out with the help of a coat hanger. Alternatively a new one can be purchased. If you are in Australia or New Zealand I can help you with either part. Just put in a request via the email link n our website. Hope this helps regards Alec
Oct 26, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My dyson DC07 has no suction. motor runs, brush spins, just no suction.
hi..the reason to this problem may be the bottom pieces
might not have been fully seated.Take it apart and put it
carefully back together.This will solve the issue.
check it out..
thank u..
kindly rate my response..
Jun 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 animal bagless
You probably have a blockage somewhere in the hose or in the base where the hose goes in. Remove the plastic tube at the base of the hose by simply unclicking it and remove the obstruction.
Nov 07, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson dc07 suction when upright but no suction when tilted in operate position
Not sure if this will definitely fix the problem.......but here goes for anyone with the same problem....spoke to Dyson helpdesk today following some online research i did yesterday. The 'internet' view is that there is a design fault with the cyclone chamber of the DC07 and that older models need it replaced. Mine is a 2003 model and Dyson asked me if there was a Number 1 stamped on the back of the cyclone housing near where the air duct connects to the hoover body....there wasn't. They then said they would send out a new cyclone chamber free of charge (I bought my model as reconditioned in 2007 from an approved Dyson dealer, so no Dyson warranty) suggesting they are aware of a problem. Advice on another site by someone who was also sent a new cyclone is that the holes in the early cyclones were too small and got easily clogged. I'm now waiting for my new part and will see if that fixes it.
very strange though - my old DC01 was a far better model from what I have seen so far of the DC07 - they seem to have gone backwards in design & reliability.
Very impressed with the service from their helpdesk though - they put other companies to shame with their speed of answering the phone and the ability to actually talk to someone not just a series of automated menus - well done Dyson for that at least - I'll reserve judgement on the DC07!!!.
Dec 24, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
194 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
