Question about Refrigerators
I have a norcold 323t rv fridge. is it normal for the insulated element to get super hot to touch?
Stupid me!!! I learned after reading online that it is normal for the back of the fridge to get very hot to touch. Didn't make sense, gets hot to get cold but what do I know!
Posted on Jul 20, 2008
My Norcold fridge isn't getting as cold as it should. Do I add freon?
No you don't just add freon and expect everything to be fine .if your system is low on freon then you have a leak so that needs to be fixed first .try cleaning you condenser coil and make sure both evaporator and condenser fan is running
Feb 08, 2018 | Refrigerators
Norcold 682 rv fridge on gas lights for 5 seconds then shuts off panel has red x
check for weak pilot check tube to ignitor if ok possible flame sensor dirty or bad
Sep 05, 2014 | Thetford Norcold RV Cooler/Freezer
Why does my Norcold fridge on Jayco 2014 come on but does not get cold?
if chimney cold check heater element and LP for flame if chimney hot unplug thermistor from control board let run if gets cold replace if not either bad board or cooling unit
May 16, 2014 | Thetford Norcold RV Cooler/Freezer
Norcold n811 120v heating element test
on board check 12 volt element and 120 volt element if voltage to it bad element if none bad board
Jan 22, 2013 | Thetford Norcold RV Cooler/Freezer
RV freezer cools, but fridge section doesn't
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Sep 09, 2009 | Thetford Norcold RV Cooler/Freezer
Freezer works ok but the fridge doesn't
are you running gas to oper the frig in the rv or electricty if only using the heating element for the frig RV STYLE ONLY maybe starting to make and break causing intermittent cooling or not enough cooling in frig but at all thing concerned try to increase you temp setting higher if you have that option
Aug 19, 2009 | Refrigerators
Rv fridge not working on electric
the element can be broken or the thermostat
Aug 11, 2009 | Refrigerators
My norcold frig(RV) freezes food in lower level
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
Dec 16, 2008 | Thetford Norcold RV Cooler/Freezer
Refrigerators Logo
163 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
