Question about Gateway Computers & Internet
I need to know if i have a built-in wireless networking
    Scholar:
  • 99 Answers
Go to Control Panel and then SYSTEM. When that opens go to the HARDWARE tab and select DEVICE MANAGER, from there you can select NETWORK ADAPTERS. You will see all the installed network adapters there.
If you do have one, and MOST newer laptops do, then you can go to Control Panel again and set up the Wireless Network.
//D
Posted on Jul 19, 2008
So I just got a Dell Optiplex sx280 that runs windows xp and can't connect it to the wireless internet at my house. The built-in driver is a Broadcom NetXtreme 57xx Gigabit Controller, and I don't...
Desktop computers do not usually have a wireless card installed. They will have a built-in LAN card that uses a LAN cable.
If you want to connect your computer using a wireless connection then you will need to install a wireless card in your computer and configure it to communicate with your wireless router.
Otherwise you can connect to your wireless router using a LAN cable.
Your wireless router may have built-in LAN ports and you can connect your computer to the wireless router using a network cable.
Jun 09, 2011 | Dell OptiPlex SX280 PC Desktop
I Installed the software for the Zonet ZEW2508 on my laptop with windows xp home.. Now what? (I have an operating wireless router already)
Ignore the software and use the built-in wireless utility that comes with Windows to configure your network. There should be a small icon by the clock that looks like a radio antenna with waves, right-click it and select to 'View Available Wireless Networks'. The rest is self-explanatory.
If the Windows utility states that it is not managing your wireless networks, you'll need to disable the Zonet utility first. If you need help with that, let me know.
Good Luck!
-Kevin
Jan 04, 2011 | Zonet ZEW2508 54Mbps WirelessG Usb Adapter
How can i setup a wireless connection on my laptop
Depending on the model etc of your laptop, some have built in wireless adapters others don't so you need to buy a wireless adapter card so that you are able to connect to the internet.
Also you will need a network which has wireless built in if at home for you to connect to the internet, through the wireless adapter on your laptop.
Hope this helps, let me know if you need more information.
Thanks
Jason
Oct 19, 2010 | Computers & Internet
Dell axim x51 will connect to to wifi hotspot i need detailed instructions to get it to work
Hi, follow the steps found in your owners manual. That can be downloaded at this link.
http://support.dell.com/support/edocs/systems/aximx51/en/om/om_en.pdf
Using Wi-Fi (802.11b)
Wi-Fi provides your device access to WLAN (Wireless Local Area Network.)
Short for wireless fidelity, Wi-Fi refers to any type of 802.11 network,
whether 802.11b, 802.11a, or dual-band. Wi-Fi certified products from
different manufacturers are interoperable.
NOTE: Mid and High configurations of the Axim have Wi-Fi 802.11b built in and the
drivers factory installed. For a Low configuration device, you must purchase the
802.11b SD card, insert it in your device, and load the drivers.
NOTE: The default Wireless Networking Client utility for your device is the
Dell WLAN utility. The following configuration steps are for the Dell WLAN utility.
Configure wireless networking for your device in one of the following
scenarios:
• Network Card is set up
• Wireless Network is broadcasting SSID
• Wireless Network is not broadcasting SSID
If the Network Card is Set Up
Normally the internal wireless card is already set up. There are times when
you must choose the network card. On the Axim X51/X51v configurations
that have built-in wireless, the network card is associated with the enabled
wireless. If wireless is not enabled or you are using a socket card for
wireless connection, then choose the network card:
1 Tap Start → Settings → Connections.
2 Tap Network Cards.
3 Choose either Internet or Work from the menu.
4 Choose the network card to connect to the network. For the
Axim X51/X51v with built-in wireless, choose Dell Axim X51/X51v
WLAN Wireless Adapter.
5 Choose whether the network card assigns an IP address or receives an
IP address automatically.
6 Enter the Server IP addresses if required and tap OK.
If the Wireless Network is Broadcasting SSID
1 Press the wireless button to enable wireless capability. The green LED
in the right top corner of the device indicates that the wireless
is functional.
2 Tap Start → Settings → Connections.
3 To add, edit, or delete a profile, select the corresponding action and
tap Network Cards.
4 In the Configure Wireless Networks window, select one of the available
network names and tap OK.
If the Wireless Network is Not Broadcasting SSID
The Configure Wireless Networks window only shows wireless networks
that broadcast a Network Name (SSID) and those that have been added.
Add the network if it is not listed. Contact your network administrator for
the following information:
• SSID (network name)
• Authentication
• Data Encryption
• Keys (if the key is not provided automatically)
• Log in if necessary
To configure the wireless network:
1 From the Configure Wireless Networks window, tap Add New.
2 Provide the Network Name (SSID).
3 Select either Internet or Work in the Connects To box.
• Selecting Internet allows you to connect to your network but you
will have to manually start a VPN connection, if needed.
• Selecting Work automatically starts a VPN connection any time
you connect to the network.
• If you are having trouble connecting to your network, change the
Connects To box to Internet.
4 Tap the Network Key tab.
5 Enter the Authentication and Data Encryption information. If a key is
required, enter the network key.
6 Select the 802.1x tab.
7 The Authentication and Data Encryption chosen on the previous
screen determines whether this screen is available. If available choose
the EAP type used on the network.
8 Tap OK.
9 If more than one network is listed, tap and hold the stylus on the
network name you want to connect to. A pop-up menu appears.
Tap Connect. After a few seconds you should see Connected next to
the wireless network you selected.
Thank you,
lee
Mar 09, 2010 | Computers & Internet
How to connect to the Internet with the built-in
Do you mean a wireless network card? I am assuming you meant the wireless card. In windows donw in the bottom right there is a connection Icon. Right click on that Icon and select open network and sharing center. Then select your wireless network.
If you do not have a wireless network, yes you do need a wireless router.
If you do have a wireless network already set up, you will need to configure the settings so you can connect to it. Whatever the password is a so on.
Jan 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
Linksys wireless notebook adapter 2.4 GHz??
Since your Toshiba has a wireless card built in, you wont derive much benefit from using it.
It is basically there for people who don't have built in wireless cards.
Jan 19, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Windows xp no longer recognizes my wireless antenna/program
To change windows to the controlling program, click on Start, then head over to Control Panel. Under Control Panel, double click on the icon for Network Connections. There, find the Wireless Network Connection. Right mouse click on it and go to properties. After the Properties Window pops up, Click on the Wireless Networks Tab. There, check mark the box which says "Use Windows to configure my wireless network settings." This will activate windows control over the network card. Hopefully this helps.
Jan 03, 2009 | Dell Dimension 2400 PC Desktop
How do i use my built in wireless connection to connect to the internet,please.
funny what is virgin is it virginmobile ? cellphone ? you need usb cable to pc from cell. also its nto a router thats built in its a wireless card for 802.11g not for cellphone companies.
Oct 05, 2008 | Dell Inspiron 6000 Notebook
Wifi issue
Hi!
Check with your laptop's manual or specification sheet if it came with a built in wireless adapter. If it does, then you do not need to use a wireless adapter. All you have to do is to configure the wireless utility of your laptop to connect to your preferred wireless network.
You can also check Device Manager to check if there is a built in wireless adapter. Assuming you are using Windows XP - Go to Control Panel > System > Hardware > Device Manager. Look for Network Adapters. Check if there is anything under Network Adapters that says "wireless" or 802.11A/B or G. If there is, then again you do not need to install a wireless adapter.
Once you verified that there is a built in wireless adapter, just configure the wireless adapter utility to connect wirelessly to you preferred network.
Good luck and have a nice day!
Sep 30, 2008 | Compaq Presario 700 470024-192 Notebook
My wireless laptop is not connecting to the internet.
  1. is there a wireless network
  2. is the wireless network open or locked down and do you have the key
  3. in windows: have you run
    ipconfig /release
    ipconfig /renew
have you looked up the network troubleshooter in the help screens
what have you altered since it did connect
Sep 20, 2008 | Computers & Internet
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
