ViewSonic VG1930WM LCD Monitor Logo
Posted on Jan 30, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
On start up monitor only works for about 4 seconds. I have been using this monitor for about a year.
santosh.m santosh.m
Level 2:
  • Expert 75 Answers
  • Posted on Jan 30, 2011
santosh.m santosh.m
Expert
Level 2:
Answers
75
Questions
0
Helped
18227
Points
125
That will be power board problem ,u can reolace the pi board
This is the strangest thing I've ever seen. I have a Gateway FPD1975W TFT Monitor and its always worked great. The other day it went into a sleep mode via windows, and now it wont boot up the input...
Your monitor problem is causes by the power supply. What is happening is the power supply voltages are not stable, just enough to power the unit up. When you connect it to a video signal the power demands slightly increase and the power supply can't handle it. This is a very common problem with LCD after a few years of use. The issue with the power supply is the capacitors have started to fail. These parts are used to filter the output voltage and when they start to fail the outputs start rippling hence the problem you are having. Here is a link to a repair article that shows how to repair the Gateway FPD1975W monitor.
http://www.ccl-la.com/blog/index.php/gateway-fpd1975w-monitor-repair/
I hope this helps you get back going.
BuddyMc
Hello, I have 7 no. of Philips 105G7 CRT monitors purchased in 2006. 4 of them are working fine but three of them started failing one by one since a year. First was in July last year and the recent one was...
The cracking problem is probably high voltage arcing inside the monitor due to insulation breakdown or components breaking down or dust and moisture causing arcing. I suggest you dispose of these monitors, they could pose a fire risk. Instead of trying to repair them. Do not try to repair the monitors yourself, there are dangerous high voltages inside these crt monitors.
I suggest you put your money towards a LCD monitor, these are fairly cheap and very energy efficient.
Hp w2007 blank screen
we have here , like 1000s of black screens posted here now.
all the same all with CCFL lamps. that die. same solution.
older monitors have a power saver mode inside it,
push the front button called menu, then see OSD menu
then find and turn off power saver.
if the OSD fails to show up; the CCFL are dead.
this monitor was made in 2007, and 2010 is the starting year
for ending the usage of CCFL (starting on large screens working to small)
im reading your manual for you now, free.
page 4 tells you it has CCFT (T mean Tube, L means lamp)
same same.
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=4#manual
now lets look at the page on saver. power
page 7, (its on by default ) oops !
https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=7#manual
turn saver OFF
see next page 8 and turn DDC ON.
see sleep timer and turn that all off.
if you push factory reset, it the problem begins again.
bad. for you.
https://www.manualslib.com/manual/1110533/Hp-https://www.manualslib.com/manual/1110533/Hp-W2007.html?page=8#manual
you can in fact download the whole manual.
for free. here. the site on the internet in this regard.
all old HP monitors are made for old PC 2000 year.
your PC is not 17 years old i bet.
so all this old saver stuff is now WRONG.
(all this is old school Energy Star , malarkey, )
3helpful
2answers
HP monitor vs17 goes black with power light flashing
I have repaired an HP 1702 monitor that had similar symptoms by replacing the capacitors on the power supply board but you have to have some electronic knowledge and do some soldering if you can buy the replacement capacitors($10+/-) from a supply store. They (at least 1) will be swollen up on the ends and may have a tar-like substance leaking from them. It is best to replace them all (may be 4 depending on the model).
2helpful
2answers
No Display on my Samsung 204B monitor
If you know how to open it up and get to the power supply you will find three capacitors 2-820uf and 1-330 @ 25vdc 105o.they will have puffed up tops replace them. FYI the monitor has a 3 year warranty.
Screen picture & LED green light keep flashing on and off
no it is a few bad capacitors on the vga board internal thes need tobe replaced or you can return the monitor if it is less than a year old
3answers
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
5answers
X2gen MW19R picture only stays on for one to fifteen seconds...
Dear Chris,
Visually check the component :
Try checking on the power board , may be ESR of capacitor is faulty and power resistor shorted and burnt.
1helpful
17" LCD Monitor - only works for a few seconds when turned on.
It seems to be an Inverter related problem in which backlight seems to be shiutting down.Is this monitor 3-4 years old???If so backlight of the panel could be an issue.
Monitor goes blank less than a second after turning on.
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
