Question about GE Dishwashers
The housing for the spray arm in the bottom of my dishwasher is cracked.
  • 640 Answers
You need to replace it because it holds the pressure of the water so the arm can spin.Contact sears for a replacement its not difficult to replace.
Posted on Jul 19, 2008
  • 25 Answers
SOURCE: No flow to top spray arm
the tube feeding the top spray arm may be clogged. The top srpay arm seal may be defective as well.
Posted on Mar 26, 2008
  • 29 Answers
SOURCE: bottom spray arms will not turn
SOUNDS LIKE YOU MAY NEED A NEW SPRAY MOTOR.
Posted on Jan 28, 2009
  • 423 Answers
SOURCE: Maytag MBDF550Aww upper spray arm doesn't spin.
Cleaning the filter was the right thing to try.
Since you don't see cracks/breaks on the spray arm and it appears that it is spinning freely, I doubt that replacing the spray arm will fix your problem.
If your dishwasher is several years old, your problem is likely a failing pump motor, but before you swap that out, check that the impeller is not damaged. Good Luck!
Posted on Apr 01, 2009
sclarke7
  • 222 Answers
SOURCE: The spray arm on the bottom of my dishwasher does not spin.
clogged flowplate...... replace flowplate assy, you might try muratic acid first, it will clear alot of the common problems. be careful its poisonous to the max, when you have the flowplate assy off check entire are for foreign objects.
Posted on Aug 17, 2009
  • 464 Answers
SOURCE: Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Posted on Nov 08, 2009
How to fix the broken spray arm at bottom
Model #? if the spray arm broke off, inspect the place it attached to. you will likely have more cracks in the plastic than is obvious...
Jul 06, 2016 | Dishwashers
Upper arm spray fell off my Indesit dishwasher. How do I put it back on?
Usually, there is a small stainless steel sc rew with a knurled edge. It fixes through the central boss of the spray bar. You should find it in the bottom of the machine in the strainer, or hiding in the bottom somewhere.
Jun 09, 2016 | Indesit Dishwashers
Lower spray arm dislodged during wash cycle
Hello Megan Quintas,
I have had the bottoms of the Frigidaire DISHWASHER rotted out AND their center-shaft NEVER LOST IT'S vertical alignment...
So my personal opinion...
You are good once you replace your defective spray arm..
Put your model+make+spray+arm
or better yet the ORIGINAL PART NUMBER to get three estimates...
Good luck, happy hunting!!
- Some example parts houses:
Sears (priciest... but improving)
appliancepartspros.com
partsselect.com
Water Filters Lawn Garden Appliance Parts
Search Over 2 1 Million Appliance Parts
PartSelect Appliance Parts and Repair Help
May 12, 2016 | Frigidaire Dishwashers
Frigidaire gallery dishwasher not draining
Perhaps the screen in the bottom is clogged. Remove lower rack and lift off spray arm. Remove screen and clean then replace. Replace spray arm and rack. Always rinse food from plates, etc. before loading dishwasher. Not everyone does this in my house and I tell them not to be so lazy. For more serious issues try "RepairClinic" their site is really good.
Oct 15, 2014 | Dishwashers
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Frigidaire Dishwasher Professional Series runs loud now and the dishes aren't clean when it finishes its cycle.
Check the water supply line for kinks, check bottom strainer/drain inside to remove particles/trash blocking water from exiting to pump washer motor, be sure no items block rotation of washer heads. Good luck.
Feb 26, 2011 | Frigidaire Professional Series 24 in....
Bottom of my Bosch dishwasher not cleaning dishes, top tray OK have cleaned / taken apart
Carefully inspect the lower spray arm for a crack or separation.
Also inspect the holes in the spray arm that may be stopped up with debris.
Remove and clean the filter in the front center of the tub.
Set the spray arm at the 12 o'clock position and start the washer. After 30 seconds open the door and check the position of the spray arm. Do thi several times to confirm the spray arm is rotating.
Feb 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Apr 01, 2009 | Dishwashers
Water dispenser not spinning
Are both of the problems listed here on GE > 24 in. GSD500X Built-in Dishwashers?
The original problem could be a cracked spray arm (rather simple to fix).
It could be a sever blockage of the pump/motor or impeller that normally pushes the water up to the spray arms. Opening the bottom pump filter and removing all debris in the filter and underneath it is the next step.
If these solutions do not fix it, then the wash pump/motor have begun to fail and are not creating the water pressure needed to properly spin the spray arms.
Good Luck!
Oct 06, 2007 | GE 24 in. GSD500X Built-in Dishwasher
The arms of my dish washer won't move
First thing you want to do is make sure the spray arms themselves are o.k. The ports are not clogged and there are no cracks. Once you are satisfied this is not the problem, check the seal ring on between the lower spray arm and the spray arm support on the pump. See if it is out of position or damaged. Make sure the water level is not too low, should just come in contact with the bottom of the heating element. Next check your filters, look for garbage, plastics, anything that would clog it. Last would be the pump itself. Ron
Apr 18, 2006 | Maytag PDB3600A Built-in Dishwasher
Open Questions:
Dishwashers Logo
50 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
