Hello, i have a RCA 311 decoder and it seems its blocked, i have inserted no less than 5 cards and nothing. Someone told me there was a master reset pressing a secuence of buttons on the remote control. Menu+4+x+y+x+guide (lots of numbers @ screen) and thats it. clean factory default decoder. Do you know the secuence? Thanks a lot.
TEUNGO UN EQUIPO MODELO 311 Y NO PUEDO ASER KE LEA LA TARJETA YO USO ATMEGA128 Y NO LOGRO ASER KE FUNCIONE POR LO CUAL LES PIDO AYUDA
ES NESESARIO KE EL EQUIPO NESESITA UN NUEVO SOFWAR PERO NO TENGO NI IDEA DE COMO ASER ESO
First of all, switch off the tab. Then check if the SD card is properly seated by removing and inserting it. Switch on the tab and check under Settings -> Storage if the option to unmount the SD card is enabled, but don't tap it. The way to the SD card properties may be slightly different on your tab. Then check if there is sufficient free space left. If this doesn't solve the problem, a master reset may be necessary. Just remember to backup contacts and calendar before doing a master reset! Contacts can be exported to a file on SD card. Applications from phone storage can be reinstalled from Google Play, under your "My Apps" menu.
Im not pretty much sure if your acer is like mine; ASPIRE V3****. It has an option here while i am pressing keyboard F6 key,, the display become blank, the display was shown back by pressing F6 again. Or your Acer system cannot properly detect the memory.. before you use the unit, remove & clean the connector surface of the memory card/s with soft cloth or tissue paper. THen insert the memory card on it's slot properly, Start up you ACer and wait for the good results. GOODLUCK!
Please always Remember, while doing Master Reset Nokia Asha 311 to factory default, the data will be loose, that's why we can do backup all data or important stuff at Nokia Asha 311. #Option 1, Hard Reset Nokia Asha 310 & 311 with menu setting:
Make sure the Nokia Asha 311 on and standby
Go to menu Setting, then choose restore factory setting > settings only
It will ask security code, input default security code of Nokia Asha 311 : 12345
#Option 2, Hard Reset Nokia Asha 310 & 311 with special code / master key / shortcut / secret key :
Try to type: *#7370# and it will ask the security code of Nokia Asha 311, press 12345
You also can try type: *#7380#
#Option 3, Soft Reset Nokia Asha 310 & 311 with special key code :
Please take attention, this option is for soft reset, so Nokia Asha 311 will not removing any important data and installed applications. How soft reset Nokia Asha 311 work: It will recopy or restore the default copy of .ini to Nokia Asha 311.
Hello, I hope that this has been resolved for you already, but if not, here are some quick and simple steps to run through! Just follow the link below to get this remote working. Steps 1-5 are to program the remote to the receiver to control channels, and 6 and on is to program the remote to the tv to control the volume. I hope this helps!!!!!!!
Take out the card and insert any other card, if it still says so then uneed to contact the service centre. Your phne will be repaired or if not possible then replaced free of cost as it is in warranty period.
RCA Authorized service tech looked at it. He determined that the DM Module need to be replaced. The part alone costs $550 + labor. Since the HDMI and component video inputs seem to work, he suggested buying a VCR DVD combo with HDMI output which would be far less than repairing the tv itself. I'n researching the possibility of purchasing the part myself.
Disconnect the lead from the flyback to the splitter. Place the flyback lead securely in a dry glass container and try to power up the set. If it doesnt shutdown the HV Block (splitter) is bad.
