Question about Boating
Kawasaki 750sts jet ski won't start - electrical. Took jet sk out today. It was running fine, then push start button and nothing at all happens. It is not the battery.
  • 4 more comments
  • Anonymous Sep 03, 2008
    same problem
  • Anonymous Sep 08, 2008
    put new coil in and starts some times whats wrong
  • dode542 Sep 08, 2008
    ran kwasaki jet ski for ten minutes ran fine bogged under power but would idle and the finally died and then would not start new gas new plugs same results.
  • Anonymous Apr 14, 2009
    nothing at the console works grounded power wire from solenid to starter if i touch straight to batt straight to starter it turns over
  • jonesm12 May 11, 2009
    Runs fine, then after turning it off for a few minutes, nothing. The gauges are displaying until you hit the starter button. Then they go out until you release the button. In the mean time, the starter button gets no response from the jet ski. No clicking, no nothing other than the dash gauges disappearing while the starter button is being pushed.
  • jflynn01 May 26, 2009
    Starts for a couple times, then nothing. Has a Fresh battery. Sometimes it "clicks" but mostly there is no response from the starter. Sometimes I can jiggle the wires and it starts again. Then after I turn it off, it wont restart. I put on new cables battery and starter. Maybe a new starter switch?
Have you replaced the starter relay.
Posted on Jul 08, 2009
Jet ski troubleshooting
kawasaki ultra 260's are only cooled by lake or sea water so if the water supply gets blocked then it will overheat ! did it definatly overheat or just loose power because the superchargers do sieze up due to damp air or the pully bearing , also the dipsticks on them sometimes shear off and lock the cogs ! does the engine still run up on a hose pipe ? also has the ski been left a long time not used without fogging the valves in the head ? this is my job so get back to me ( 30 yrs ) ..
Dec 28, 2013 | kawasaki 2010 Jet Ski Ultra 260X
Won't start
Fuses in the electrical box?
Jul 18, 2013 | Yamaha 2006 WaveRunner FX Base
My Yamaha Jet Ski 750, turned over Bro.. my Jet Ski, Yamaha 750, turned over and after that.. I pulled out of the water took the spark plugs out, put DW40 in the cylinders and nothing happened.. the e
sounds like you hydro locked it and possibly blew out a reed in your engine intake or worse, you may have bent a crank rod. But before you go tearing it apart make sure all the water is out of motor and theres none in the fuel tank then put in a new set of plugs and see what happens,
Mar 18, 2013 | Water Sport
My 1991 Kawasaki JS440 jet ski won't start and it
You might want to post this question in a different section. This is the computer games section.
Aug 23, 2012 | Video Game Consoles & Games
Pressing the start button but nothing happends everything looks good as far as running wise guy before me said it had a bad relay then he replaced it and it worked fine. now it wont start again and idk if...
Open the electronics box and check that the starter button wires are plugged in. Unplug them and check the starter button for continuity when you push it. At this time you can also jump the starter solenoid and see if it has failed again. Also see if the fuse is blown . It is probably just a loose wire.
May 18, 2010 | Encore Software Kawasaki Jet Ski...
Jet Ski Will not start when cold
If the teeter/totter needles are gummy or covered with moisture corrosion it could be the reason the machine is so hard to start. When storing the jet ski's syphon all the gas out and burn it in your car or truck. Even if you stabilize it it wont be good fuel in the spring. Your plastic tank will not rust so remove the fuel. You may be able to clean them up by running a tank of Chevron Techron through them. Before riding we charge are batteries and start are jet ski's on the trailer/lift before dropping in the lake. This saves the battery. It takes more juice to start the boat in the water.
May 25, 2009 | Encore Software Kawasaki Jet Ski...
Kawasaki 550sx won't start
souds as if the starter is faulty. Use a volt meter to check voltage at the starter while holding the start button. If you get a battery voltage reading, then the starter is shot.
Mar 22, 2009 | Sport & Outdoor - Others
Boating Logo
2,101 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
