Technics SL-L92 directdrive automatic turntable (needle fixed in lid)
After a move, the turntable lights up, but will not spin when i press on
  • galleriesole Jul 23, 2008
    how do i open it up?
  • jasmado May 02, 2009
    I have a Technics SL B20 (after looking inside, determined it's direct drive). Before opening, the power light would come on and I would hear what sounded like the motor working--no spin however. Checked inside and from the motherboard there's a cable that feeds to a "chip" (?) right next to the on/off switch. The chip is encased in this rectangular open box thing. What is this thing called? I'm speculating that the power from the motherboard is not being transferred to the turning mechanism through this chip, so the chip needs replacing. Am I on the right track??
  • 515 Answers
Not sure what could have happened here. Maybe a wire came loose - doubtful, but possible. You will have to open her up to see if there is anything unusual inside. Or, you'll need to take it to a service center for a diagnosis.
- Davis
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Posted on Jul 23, 2008
  • TERMiNAL OPTiC
    TERMiNAL OPTiC Jul 24, 2008
    If you have to ask how to open it up, then I don't suggest doing it. Generally, it entails, flipping your turntable upside down. You'll have to be careful when doing this. Remove the screws from the bottom, and that's it. However, it's not as simple as it seems. So, as I said... if you have to ask, then I DO NOT SUGGEST you do this.
When I push start button turntable doesn't rotate
Technics SL-QD33 doesn't turn - Vinyl Engine
www.vinylengine.com/turntable_forum/viewtopic.php?t=28381
Jun 3, 2010 - 15 posts - ‎3 authors
It powers up, lights come on but the platter won't spin. ... However when I press "start", nothing happens and the platter won't spin when ... the arm towards the record without pressing the "start" button. ... SL 7, SL-10... and / or any of the fully automatic Technics turntables using optical record detection......etc Marantz 6300 question...
Nov 21, 2009
Dual CS505 turntable won't auto-start
Aug 16, 2009
More results from www.vinylengine.com
Help!! My Turntable won't spin - AVS Forum ' Home Theater ...
www.avsforum.com/.../1316271-help-my-turntable-won-t-spin.html
18 posts - ‎7 authors
Dec 21, 2015 | Audio Players & Recorders
How can I get a manual on how to fix this item? The arm needs adjusting. Thanks P.S. its a Technics sl-dd33 turntable
Technics website may have one. The counter weight has a setscrew on it. Loosen it ans move the weight slightly forward until the needle just rests completely in the groove and stays there. Too much will cause excessive wear to the needle and the record.
Aug 08, 2015 | Audio Players & Recorders
Technics servo
Register (free) with Vinyl Engine and you can download the service manual.
http://www.vinylengine.com/library/technics/sl-b210.shtml
Jun 25, 2014 | Audio Players & Recorders
I've just set up my Technics SL D212 turntable after moving house. It keeps skidding across records. I've tried the usual adjustments and leveled the turntable. Any clues?
Please make 100% certain the needle is still in place... To test this *GENTLY* rub your fingertip over it and you should hear noise from the speakers when you do. If there is NO noise then there is likely no needle.
Did you put the protective device on the needle/arm for the move? Is it still on there?
Sorry Mate, that the only thing I've got to help....
Feb 20, 2012 | Technics Audio Players & Recorders
I had not used my turntable for about five years due to no needle. Found a needle and played two LPs, then on the third one, it just did not move or work at all. It lit up but just acted like it had no...
The low grinding noise could be the motor spinning with "no load" i.e the belt has snapped or fallen off due to being perished.
Lift the platter to refit the belt and or replace it if required.
Jul 23, 2010 | Technics SL-BD22 Turntable
The cartridge arm does not go back to the off position.
it's a "manual" turntable so this is normal. You would need to buy an "automatic" turntable to have the arm return back when done.
Apr 22, 2010 | Technics SL-1210 Turntable
I HAVE A TECHNICS TURNTABLE SL-QD35 THAT IS DIRECT DRIVE AUTOMATIC THAT IS SPINNING TO FAST.
i got my turntables repaired by these guys www.technmics1210repair.co.uk
i did they made my setup work like new so im going to spread the word.
give them a shot
Apr 03, 2010 | Technics SL-1200MK2 Turntable
Turntable wont spin
If everything seems ok with the power , there is usally a small microswitch that sends power to the motor when the tone arm is moved to the start of the record.
The switch might be bad or the lever that actuates it (connected to the tone arm) might be sticking. You may have to take the bottom cover off or remove the platter to see it.
Also make sure the belt is looped over the motor shaft. If the motor runs but the belt still doesnt turn, belt might be bad.
Mar 10, 2009 | Technics SL-BD22 Turntable
Technics sl 1210 will not start up
did you ever open the turntable. It sounds like the on/off switch is bad. Remove the platter and screws with a phillips screw driver and just make sure the connections are in place. make sure you disconnect the power first. let me know what happens afterwards.
May 24, 2008 | Technics SL-1210 Turntable
Technics SL-23 belt driven turntable (NOT SL-1210 but I had to enter something)
Howdy Ivy:
An Adobe PDF format service manual for the Technics SL-23 turntable can be downloaded from
http://www.servicemanuals.net/
for about $16.
Paul H.
May 03, 2008 | Technics SL-1210 Turntable
682 people viewed this question
 Grubhead
Grubhead
