Question about Refrigerators
Ge profile refrigerator model #pf22sbsbss
Where can i buy the magnet seal? i live in Hawaii on the island of Oahu.
  • barbaranorth Jul 19, 2008
    where can i buy the magnet seal? I live in Hawaii on the island of Oahu.
  • 2,427 Answers
You should consider buying one online.. I'm sure the manufacture of your refrigator has a web site. check ot out i'm sure they have the seals there or they can tell you where is the closest place to you to ship one from. But basically i believe that the seals are standered , the seal for any ref. your size should be the same.. check your local hardware and see if they got any.
Posted on Jul 19, 2008
  • Rishi Roshan Ali Jul 19, 2008
    give me the make and model of the product i will send you a link.
Ge profile artica refrigerator door will not close
clip on bottom of hinge is worn or broken had mine replaced. magnetic seals are not strong enough to hold the door closed on their own. Original problem was the magnets were too strong so the clip on the bottom hinge was added.
Sep 26, 2010 | GE Profile PSW26P Stainless Steel Side by...
Recently I have noticed that the seal on the refrigerator door is not very strong. I checked the seal for dirt and cracks and all looks fine. It is almost like the magnet is broken, but I know magnets do...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 09, 2010 | GE Profile 25.6 Cu. Ft. Side-by-Side...
WR55X10415 on GE None of the panel lights are on. no water no ice
Before you go too far lets check the wiring harness. Your model is a Profile or Artica and model number? I would not buy anything until I traced out the wiring. You may have plulled the pinplug at lower left hand of door near floor and behind kick plate. Sea Breeze
Mar 20, 2010 | GE Refrigerators
Fridgedair R134a ice maker water wont fill. Solenoids & valves are good & water supply lines good. Im works fine. So, where does the signal to the IM solenoid & valve originate from. I already...
Your icemaker send the voltage to the water valve as it cycles through its ice drop. Pull your icemaker out, and test the wiring it was plugged into for continuity to the water valve, usually you will only have one colored wire that has continuity. Your white wire is usually your nuetral and as long as both wires are ok, then replace your icemaker or your icemaker module if it has one. You have a very good parts house on Oahu called Reliable Parts, Take your icemaker in if you live on Oahu, or call them with your parts number if you are on the Big Island. I worked on Oahu for 15 years. Good Luck Appliance Specialists
Dec 14, 2009 | Frigidaire FRS3R5EMB Side by Side...
Freezer never cools consistently and compressor never goes off
I am posting this for the sake of curiosity. I want to know if it gets resolved.
Jun 18, 2009 | GE Profile PFS22SBSS Bottom Freezer French...
Freezer door wont seal and stay closed
Your pushing air from the fridge part over to the freezer door when you clos it,the only thing i can suggest is make sure that the seal (which is magnetic) is clean and not falling apart,inspect it all around the door,and when closing the door i would close it gently.
Hope this helped.Let me know by rating me or
for more help go to live chat.Thanks
Len West
Feb 25, 2009 | Amana ARSE66MB Side by Side Refrigerator
Refrigerator Door Lost Suction
I have a GE Profile Stainless Steel side by side. I also noticed that the refrigerator side door was not sealing like it had previously. There was no "suction" when opening. I started inspecting the gasket around the door to see if this needed replaced, as I had read that may be the problem from this forum. My particular model has the grill / vent at the bottom of the door, in the front, which just pops off. I found that down by the grill my model has magnets there that match up with magnets on the bottom of the doors. I inspected this and found a foreign object had attached itself to this magnet. I removed this object and waaahlaaah the door now has suction! I was relieved to find that I didn't need to replace the gasket. Worth a try. Hope this helps.
Aug 25, 2008 | GE Profile PSW26P Stainless Steel Side by...
French door frig model # pf22sbsbss
A local hardware shop or dealer should have the seals, its a common thing..
Jul 19, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
