Monitor I have developed a shade spot on my laptop display.
  • bhartek Jan 26, 2009
    Hi...My LCD is solid white with thich Black line in middle. Updated all drivers no use. Can anyone suggest if it is Screen or Inverter. Works fine one external PC.
    Genius:
  • 2,028 Answers
This is probably a dead pixel area and there may not be anything that can be done other than replacing the screen. This could also be a stale area in the liquid crystal. Try massaging the area firmly, just hard enough to make the screen change color, but not too hard as to make it turn black. If it's a stale area this should refresh it. If it's a dead area, then I'm afraid replacement is the only option.
Posted on Jul 19, 2008
Monitor looks like right half blue shade
Either your monitor or the video card inside the computer is going bad. To isolate the problem connect another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor displays ok that means your video card is ok, but your original monitor is bad. If the Borrowed monitor displays the same blue shade then your video card inside the computer is bad.
Jun 05, 2012 | Lenovo Computers & Internet
Toshiba satelite pro red spot on screen
Sounds like your screen is going bad or your video card is bad. Try plugging an external monitor to the laptop to isolate the problem. Borrow a monitor from a neighbor, friend, relative or co-worker and plug it into the laptop. if the borrowed monitor displays without the red spot then your original monitor is bad. If the borrowed monitor shows the red spot then your video card inside the computer is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
May 12, 2012 | Computers & Internet
Display Shutdown After Few Seconds To Few Minutes
Hook a spare monitor to the computer to rule out the video graphics card in the computer, and sub another video cord from the computer to the monitor if possible to check your LG monitor, If the display shuts down and power light changes colour or goes out it is a power supply board, one or more capacitors open causing the power to fail, sometimes the top developes a bulge making it easy to spot.
Apr 14, 2012 | LG L192WS LCD Monitor
Spots look like water damage. They are irregular and inky in appearance. Location of shading along upper right and lower left edge of screen.
If the spots look like ink, the display panel is broken. To fix this problem, you have to replace the display panel with a new one.
Jun 03, 2011 | Acer Aspire One PC Notebook
BLUE screen problem(monitor)
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but blue shaded screen, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 26, 2010 | SAMTRON 55V 15" CRT Monitor
Shaded areas on my X2gen 19 inch monitor do not Show up.
It sounds like the PC video color setting is at 16 instead of 24 or 32 bit color setup. You need to check the display properties setting on the PC (Right click on the desk top). Also try it on other PC and also check the VGA cable.
Apr 07, 2010 | X2Gen MG19MY 19" LCD Monitor
Toshiba Satellite L305-S5919 Dual Monitor Help!!
Make sure the second monitor is actually plugged in and switched on when you make the switch.
Mar 21, 2010 | Computers & Internet
The problem started with a dark spot in the bottom left corner. It grew so that it started to touch the "Start" of the Windows taskbar. The spot was too hot to keep my finger on it while the rest of the...
quote:"The spot was too hot to keep my finger on it while the rest of the screen was cool" You have a partial hardware failure on the lcd's internal circuitry (column and row drivers, stuff like that).
The short time it's working is about the overcurrent protection delay, it cutt's itself the Vcc, Vdd and control signals for limiting the fire hazard.
Oct 13, 2009 | Acer Aspire 1642WLMi Notebook
I usually dual monitor and have programs open on both. now that i am at home i do not have my second monitor only my laptop. when i go to open a certain program it opens on my "second monitor" that isnt...
You should go to the display properties on your laptop while at home and disable the dual monitor setting. You should then have all programs open on your laptop screen and not on the secondary monitor. If running XP, right click an open spot on desktop and select Properties. If running Vista, right click an open spot on desktop and select Personalize. Go to Display Settings, select the second monitor and uncheck "Extend the desktop onto this monitor". Hope this helps.
Apr 25, 2009 | Computers & Internet
LCD Display - Gray Shades/Lines
1ST OF ALL U SHOULD CHECK UR CPU WITH ANY OTHER MONIOR IF IT WORKS OK THEN BUY 256MB XFX 3GP CARD
Dec 14, 2007 | Gateway GeForce2 NV15, (64 MB) Graphic...
Computers & Internet Logo
78 people viewed this question
David Payne
David Payne
