Question about Refrigerators
French door frig model # pf22sbsbss
Where can i buy the magnet seal?
  • 2,427 Answers
A local hardware shop or dealer should have the seals, its a common thing..
Posted on Jul 22, 2008
What to do about LG french door refrigerator that does not keep food cold
I would suggest you check the seal and the hinge. This frig has a piece that folds in and out flush for the two doors to seal, you might check that as well.
Aug 11, 2014 | LG LRFD25850 French Door Refrigerator
French door style frig. model #PR22sbsbss Door does not close all the way by itself. it will sit just open enough to let cooled air out and hot air in but not activate the "open" beeper. i've...
the magnet seal arount the door needs to be replace, ypu can purchsase this and simply remove the old and and glue on the new one.
another quick fix method is to use a hax and staple type lock and screw the stape on the frodge and the hax on the door sor sfter you puch in the door simply staple it shut.
Jul 19, 2008 | GE Refrigerators
Every time the top frig door is closed the bottom freezer door opens sometimes only 10 or 15mm so that the alarm does not detonate. The reverse also happens, ie top door opens when the bottom door is...
There is an air duct that connects the fridge to the freezer. When the opposite door is closed air is trapped and forced out the other door pushing it open.
The door seals contain a magnetic strip that hold the door to the fridge, these magnetic strips have lost their strength, to test this use a shhet of paper. Open the door, place the sheet of paper across where the door closes, shut the door, then slide the paper out. If the paper comes out without any resistance then the door seal needs to be replaced.
Mar 31, 2011 | Fisher and Paykel E522BRXFD Stainless...
Need a frig gasket seal for LG LFD25870St - 36 inch french door frig
Go to or your local appliance parts store should be able to order it if it's still available.
You will need the model number and such
Mar 13, 2011 | Refrigerators
Side by side door not shutting properly
There are magnets inside the seal this is what keeps it closed. Either the seal is damaged or the magnets are worn out. They do wear out but usually not for at least 10 years depending on the usage.You can go to for a diagraam or illustration of your specific model. The parts also come with installation instructions.
Mar 31, 2010 | Kenmore 57029 Side by Side Refrigerator
Regarding GE french door model pfs221sbss, need
I would call your GE service company and give them the model number and serial number of your frig. They can look up which board fits your frig.
I hope this helps.
Feb 03, 2010 | GE PFS22SISSS Stainless Steel French Door...
Fridge Condensation
Check the seal of the rubber gasket, if there are improper seal of the magnet, pour hot water along it to soften the rubber. (be careful when handling hot water). When the rubber is soften, try to stretch it a little by pulling it. close the door and the magnet will keep the seal in place.
May 09, 2009 | LG LRFC25750 Refrigerator French Door
Freezer door won't stay shut
I have the exact same problem - very annoying. The only thing I found to work was to purchase one of those child safety locks. I bought the Kidco Appliance Fridge Lock S330 because it was the only one I could find that automatically relocks after you shut the door. Buy two (or more) at a time because the arm will eventually wear out and break (after several months depending on how often you use it). You can check out the product's details on eBay - that's where I purchased mine. Hope that helps.
Aug 27, 2008 | GE GTS22KBP Top Freezer Refrigerator
Ge profile refrigerator model #pf22sbsbss
You should consider buying one online.. I'm sure the manufacture of your refrigator has a web site. check ot out i'm sure they have the seals there or they can tell you where is the closest place to you to ship one from. But basically i believe that the seals are standered , the seal for any ref. your size should be the same.. check your local hardware and see if they got any.
Jul 19, 2008 | Refrigerators
Refrigerators Logo
41 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
