Question about Sharp R-1480 Microwave Oven
Sharp R 1480
Heard loud pop and now the microwave will run but will not get hot.
  • AMBER CRUISE Jul 22, 2008
    TURN ON BUT DOES NOT HEAT .
  • Sharp Master
  • 9,098 Answers
This is usually a blown high voltage rectifier diode.
We have the service manual and have uploaded it to our site here.
We have critical safety & disassembly info (including a disassembly how-to video) at our site, linked here.
The best place to order Sharp parts is Tritronics.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 20, 2008
Trying to remove sharp r-1480, removed two bolts on top, don't know where the other bolts are holding unit in.
there are 2 scews behind grill piece that runs above the door and control panel. loosen and you'll be in business..
Aug 06, 2011 | Sharp R-1480 Microwave Oven
I heard a pretty loud pop on my Sharp R-1505 yesterday and the microwave stopped heating. Any ideas?
get rid of it your transformer blew out they are to costly to replace and potintialy dangerous to work on unless you are trained technican
Oct 08, 2009 | Sharp R-1505 Microwave Oven
Microwave popped and now does not heat
Okay, first we need to separate the situations. You were boiling water on the stove and had the range hood fan running to **** up the steam. Then you put something in the microwave to heat and you heard a pop and then zip-o.
The water on the stove has nothing to do with the situation, the fan you turn on is not part of the microwave, so it has nothing to do with the microwave.
The pop you heard and then the humming suggests the magnetron failed. You said you found a blow fuse and replaced it and still nothing, right? The magnetron is the most likely culprit...I would think it is safe to say that the magnetron shorted and drew enough current to blow the fuse.
Replace the magnetron and if that doesn't work, let me know here. Good Luck!
Sep 14, 2009 | Sharp R-1480 Microwave Oven
Loud pop and microwave doesn't heat anymore
I have a GE Profile Spacemaker model JVM3670WF001, purchased I think in 2003. Pop sound, no Heat. Light goes on, carousel goes around,
Repair or new microwave
Jun 03, 2009 | GE Profile Spacemaker Over-the-Range...
I was afraid to keep using the oven
Look to see if there may be a small piece of metal, or aluminum somewhere in the oven or in the food, also it may be the utensil you have the food in is not microwave safe.
The Microwave oven won't hurt you microwaves are about the size of a pencil.
Feb 10, 2009 | Sharp R-1480 Microwave Oven
SHARP MICROWAVE R-1611 MADE VERY LOUD POP NOISE. NOW IT WON'T HEAT
20 A fuse inside m/w is out. The problem could be with HV condenser, one of the door switches shorted, computer board, magnetron. Needs technician to take a look on it.
Dec 03, 2008 | Sharp R-1480 Microwave Oven
Sharp Microwave Model #1482
now!the microwave is cheaper in market! if you call repairman! he will ask equal to new microwave rate price! better think is buy new microwave! check the fuse in microwave! then you buy the new one!
Jul 06, 2008 | Sharp R-1480 Microwave Oven
Dead replaced fuse now makes loud noise
Yes that noise is causing your fuse to blow. Machine gun sound sounds like the High Voltage Capacitor or High voltage diode is bad. (Loud humming sound is usually a bad magnetron or bad power transformer). Most of these parts are inexpensive, except for the magnetron. But most of the repair bill is most likely going to be for labor.
Based on your model, it looks like an over the range microwave. And to fix any of these problems require the removal of the microwave from the wall. So its up to you if you want to deal with that hassle. But you also have to consider that you'll probably have a hard time trying to find a new microwave that will fit.
Mar 25, 2008 | Sharp R-1480 Microwave Oven
Sharp R-1480 Microwave Oven Logo
135 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
