Question about Motorola Mobility S9 Headphones
Motorola S9 Volume control doesn;t work
  • 4 more comments
  • sujitsbandiv Jul 30, 2008
    My Motorola s9 up volume works but the down volume button does not fix any firmware to be updated or so.
  • rainmaker28 Dec 27, 2008
    volume buttons not working
  • Anonymous Feb 03, 2009
    Only the - volume button works - not he +
  • Anonymous Feb 07, 2009
    up volume quit working? can this be fixed or do I need to buy another one. 2nd head set this happened to
  • Anonymous Mar 17, 2009
    volume button stopped working
  • Anonymous Mar 31, 2014
    right speaker volume low
I heard that volume work with nokia and moto sets only ... which set are u using?
Posted on Aug 15, 2008
The volume control on my Motorokr S9-HD bluetooth headset no longer works to increase the volume. The headset was replaced once already by Motorola but is now (just) out of warranty. Motorola was very...
Motorola Headset S9 Control Keys Prob.
Hi
i am using motorola S9 for last one year.
I had the same problem of controls keys which i have corrected of my own.
Most of the sites i read say's this problem is due to the moisture.
Let me tell its not because of moisture.
Below steps will help you guys hopefully if its only the keys control problem.
Take the headset,The control keys are placed near the ear plugs within a area
which is different from the other part.
now what u have to do is just take some sharp thing or your nails enough and
move it around the control keys area (edges) and peel off the rubber layer
carefully.Please note its very soft rubber so be careful not tear it off else it
will be spoiled completely.
After u remove this layer u wll find layer of plastic attached to the rubber
whichh u took out and the same kind on the base. you will fin ther will be
small vertical lines and center one dot on the peeled out rubber and on base
horizontal 2-3 thin lines at the edges and dot at the centre.
actually thes are the contacts which acts as a switch if u observe it would have
been covered with the rubber kind of gum used to stick thes layers.
Just clean these (only)contacts area with piece of cloth and use some rubber kind
of glue (Do not use Feviquik it will spoil the strips completely) at edges and put
it back ,b4 fixing it gum u can test it by just keeping it and check if the keys
are working then fix every thing as it was b4 and stick the peeled out rubber panel
with the same type of glue.
there u are ur problem is solved enjoy the best music experirnce with your S9.
If u have any problem or Queries please post it i wll try to answer as soon as
possible.
if u want a video for this i wll b up loading it soon and post d link.
Dec 14, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
S9 headphones don't work in mp3 mode
its not problem with youe head phones. check the volume settings in MP3 player insde the phone.
Dec 25, 2007 | Motorola Mobility MOTOKRZR K1 Cellular...
Cant connect wireless motorola s9 to my laptop
I've got a driver from lenovo and it worked great controls work fine and u can answer your phone, music pauses and resumes after u hung up sound a+ driver is called: 7zbv14ww
Apr 20, 2010 | Motorola Mobility MOTOROKR S9 Wireless...
My volume is too low and the volume control
increase the volume on your phone or computer
Oct 22, 2009 | Motorola Mobility S9 Headphones
S9 doesn't play music
does your laptop have a2dp bluetooth profile
this profile is needed to play music
Sep 15, 2009 | Motorola Mobility S9 Headphones
S9 malfunctioning
does the other buttons work play pause
if not then your phone most likely does not have
Audio Video Remote Control bluetooth Profile (AVRCP)
Aug 12, 2009 | Motorola Mobility S9 Headphones
Need to know how to adjust volume on bluetooth
by pressig the volume button up and down
on the handset press the volume buttons
any thing else idont know
Mar 25, 2009 | Motorola Mobility H350 Wireless Headset
M-S9 controls (Track up/down and pause) work fine. Volume up/down and mute will beep when pushed, but there is no audio ever. Using Microsoft Media Player on laptop. Computer see's the S9 and reports its...
Returned the motorola back to the store and got another brand. Did the full install (add Bluetooth) Had same problems.
My solution Was to go into Control Panel select speakers. Make the bluetooth speaker default. Check its properties (Level). and test (tones should play through headset).
Now restart your application (Media Player)
I'm running Vista 64
I hope the resolves Motorola s-9 problem (It is a much nicer headset)
Mar 21, 2009 | Motorola Mobility S9 Headphones
Motorola S9
Whenever I workout, I sweat from head to toe, and have the same issue, track changing on their own, volume adjusts to minimum by its self. Once this occurs, you can't "re-adjust" the volume, (until they dry out). Other controls don't seem to work either, (pause, forward / reverse tracks). Bottom line, if you workout, if you are like 99% of humans, you will sweat, and if you do, the same thing will happen. I am on my 2nd pair, about to be on my 3rd. Sadly, Motorola was way off when they said these were sweat and water resistant!
Jan 16, 2008 | Radio Communications
Motorola Mobility S9 Headphones Logo
1,372 people viewed this question
Top Motorola Mobility Audio Players & Recorders Experts
David Payne
David Payne
Andrew Taylor
Andrew Taylor
Unlockingcom
Are you a Motorola Mobility Audio Player and Recorder Expert? Answer questions, earn points and help others
