Question about 2wire (1000-000057-000) Modem
Adding another computer to network
How do I add another computer (laptop) to my Gateway 2wireless . I have connected the modem to another computer.
Thanks
  • 4 Answers
You can have 4 PCs connecting to your 2 wire 2701hgv or 2700hgv wired or wirelessly. Make sure the DSL light and the internet light is green and lighted up
For wired connection, just plug in the RJ45 cable to the ethernet 1,2,3, or 4 and the other end of the RJ45 cable on your laptop LAN card or network adaptor
For wireless connectivity, SSID is 2wire followed by the last 3 digits of the SN(or serial number) and the WEP key is located at the bottom of the 2wire modem in between 2 bar codes in square brackets. If the WEP key and the SSID was changed before in the modem page, go to the modem page and see what is the latest SSID and WEP key using RJ45 cable connected
From Andy Thoo Wai Kiat, Singtel
Posted on Jul 23, 2008
Having trouble adding printer canon ir3300 thru ethnet connection. directly to laptop. This printer isn't on the current network. So, I'm not sure if I need to add it first. Can you please advise.
You will need to buy a "Crossover Ethernet Cable". A ordinary straight through ethernet cable will not work. When you connect the crossover cable the laptop will see it and assign an IP address as though it was on a network. You then need to create a standard IP Port. take a config printout and look for the ip address. Add a single digit one to the address and make that you std IP Port.
Install your network driver and it will look for the printer on your new network (your laptop and printer). providing it does then all should work ok.
Good luck.
Aug 22, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
Bigpond have sent me my 4 port Wi-Fi modem thompson TG782T Home Network Gateway, now I am sitting here trying to figure out just where everything goes!!! I received a cd rom however I can't get it to work,...
Telephone wall-plate <---- 4-strand telephone-cord ---> telephone-port in modem
AC power from wall-plate to modem.
LAN port #1 <--- Ethernet cable --> network-port on desktop/laptop computer #1.
LAN port #2 <--- Ethernet cable --> network-port on desktop/laptop computer #2.
LAN port #3 <--- Ethernet cable --> network-port on desktop/laptop computer #3.
LAN port #4 <--- Ethernet cable --> network-port on desktop/laptop computer #4.
Configure the router's wireless adapter:
* set a SSID
* set an encryption-level, e.g., 'WPA'
* set a network password
Use the SSID/password to configure your wireless devices (iPod Touch, iPad, XBOX 360, etc.)
Nov 26, 2010 | Gateway Computers & Internet
Lost my book
You may access the setup page of the router to get the network key. You will need to use a computer hardwired to the router. Check the ip address of the computer (control panel -> network connections-> right click Local Area Connection and select Status) and take note of the default gateway.
The default gateway is the ip address of the router.
On your browser's address bar, type the default gateway, usually it is 192.168.1.1. It will ask you for the username and password.
By default leave the username blank then the password is admin.
Once on the setup page, go to Wireless -> Wireless security. You will see the network key on this page.
I hope this helps!
Apr 19, 2010 | Linksys Wireless-G WRT54GS Router...
I have a laptop computer, and a wirless no internet
your internet gateway (the modem)if you have att you must turn on the the wireless inside your 17XXhg gateway modem if you don't then you have another system I gave you a example to clear your question if you need more help please repost with more information
Jan 14, 2010 | Computers & Internet
My laptop is having trouble connecting to any internet source whether its wireless or dsl.. how can i fix this
for fix this problem u need to go in control panel in that u go network and internet and in that go network and sharing centre u find there add a device to network and u can add wirless network and your connection will be start
Sep 29, 2009 | Dell Latitude D830 Laptop Computer PC...
How to monitor all traffic from PCs on ADSL wifi 2701hgv-w modem
to monitor all traffic from all computers your computer would have to run the internet connection(modem) and you would have to connect your router to that. that way all traffic would pass through your monitoring computer with watever software you use to do this. Pritty sure this is the case.
Feb 25, 2009 | 2wire (1000-000057-000) Modem
D-link di514
Try the DSL modem directly connected to the PC.No D-Link Router(powered off and disconnected). Verify that the PCcould surf/browse/connect to the Internet. Go to Start, Control Panel,Network Connections, right click Local Area Connection, Properties,scroll down to/highlight Internet Protocol (TCP/IP), Properties button.Get the IP Add, Subnet Mask, Default Gateway and DNS assigned to the PC(write this down. This will be your WAN/Internet IP settings). Then Disable DHCP of your modem if it has one. OK, close, save or whatever is applicable.
Disconnect the DSL modem from the PC. Connect D-Link Router to PC (wired/LAN) without the modem connected to the router.Go again to Start, Control Panel, Network Connections, right clickLocal Area Connection, Properties, scroll down to/highlight InternetProtocol(TCP/IP), Properties button. Tick "Use the following IPaddress". Enter this IP Add 192.168.0.10, Subnet Mask255.255.255.0,Default Gateway 192.168.0.1 and the DNS from what youhave written down earlier). This will be your LAN IP settings. OK,close, save or whatever is applicable.
Open a browser and log into the D-Link router (192.168.0.1, using "admin" as a username and no password). Do not run Wireless Network Setup Wizard. In WAN/Internet/Modem setting of router enable/check Static IP Add.Usethe IP numbers previously assigned to PC that you have written down asthe router's WAN/Internet/Modem IP settings. OK, close, save orwhatever is applicable. Reboot router. Connect DSL modem to router.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Aug 04, 2008 | D-Link DI 514 Wireless Router (DI-514)
My toshiba computer does not work with my wireless internet
what brand of wireless modem you have, what os are you using?did you switch on the wireless in your laptop? sometimes we overlook the most simple things, it happens to me..
ok, you have to configure your laptop to connect to your wireless modem, how? just connect first your laptop with wire to the wireless modem, does it work? if it does work you can take the default gateway ip add from your pc by typing IPCONFIG on the command prompt , then type it in your internet explorer address bar.
example default gateway..... 192.168.1.254
and supply the username and password, you can now configure your wireless connection wep/wpa configuration.
Apr 01, 2008 | Computers & Internet
Verizon Westell 327G wireless connection problem
the best thing to do so that you can isolate the problem is to connect your computer first to the gateway using the ethernet cable. make sure first that connectivity is not an issue if you're using a wired connection. once that's done, try accessing the modem, 192.168.1.1 is the address for your westell. all this is while you're connected with a cable. it will be very hard to fix this issue if you're not wired connected able. check the ip address of your computer. it should start with 192.168.1.xx, any other ip address it will mean your computer is not connected to the modem. if it's a 192 ip address, check the ip add in your modem, it be a routable ip add. for example if you're isp provider is verizon, more often the ip address should start with a 71 to a 74. most likely it will be because you can go online using a wired connection. next thing you should check is your wireless settings in your modem. find out your connection type with you isp. if you have a dhcp or open pppoe, turning off and turning on again your modem will fix things, almost always. if you have a pppoe connection, you have to make sure you have the right username and password. after this, check the properties of your wireless connection by clicking on properties in the wireless network icon, check if you need a WEP key if its secured. sometimes changes in the properties of your wireless network is the problem. if this still doesn't work, there might be a defect with your modem, better call tech support for that. you might need to replace the modem. if you're still under warranty do it now because if not, you will have to buy a new modem if it's found that you have a defective modem.
Mar 08, 2008 | Gateway WESTELL INC. A99-327W11-00...
Networking with Motorola SBG 900 Gateway
No, you don't need a router... that gateway supports up to 253 devices on your private network segment. That being said, you only have one ethernet port, so if your desktops have LAN cards rather than wireless, you'll need a hub to split off enough ports. If you add a router, it'll give you a whole new level of complexity. A gateway is a router/modem combo. It converts the Cable Internet signal from your ISP to ethernet and isolates all of the computers behind it into your own private network. A hub is basically an ethernet splitter... it won't isolate a new network segment, it'll just add more ports. Get a hub, they are cheaper and won't add a new level of complexity.
Sep 09, 2007 | Cisco (1841) Router (cisco1841)
2wire (1000-000057-000) Modem Logo
925 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
noti13
Level 1 Expert
William Dehn
William Dehn
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
