Question about HP DeskJet 932c InkJet Printer
932C Constant blinking ink light
I have a HP 932C that the ink light is constantly blinking. With the lid shut, the carriage is jerking every 10 second just away from the left. With the door open it lands on the 2nd indicator from the left which indicates there is a problem with the black print cartridge. I tried to replace print cartridge with new and it continues to blink and ****. What now? Thanks!
  • 2 more comments
  • Anonymous Oct 23, 2008
    Exact same issue.
  • Anonymous Mar 22, 2009
    I have the same problem!
  • dourobob May 04, 2009
    932C - ink light flashes - I took out both cartridges (recently refilled at Island Ink Jet counter) - work on initial printing - sat for a few days - ink light falshes - removed carts and reinstalled - print is OK - sat for one day - light flashes again.
    What is happening here??
    Help!
  • Anonymous May 22, 2009
    Ink light blinks continuously. I changed cartridge?????
Problem here is the orange light blinking- has ink in the cartridge- stopped printing in the middle of the page
Posted on Sep 19, 2008
Our hp deskjet 932C printer is leaking ink. What
You could carefully clean this as follows:
put the printer on some newspaper to avoid further spills.
Turn on the printer, then open the lid to allow the carriage to move to the center.
Now unplug the printer, then gently move the carriage to the left and out of the way.
You should now have limited access to the spittoon area.
You can clean this area by carefully scooping out the ***** of ink with a plastic spoon. (Be careful not to drop ink sludge on your printer, desk, carpet or clothing.)
Once most of the ink has been removed then use a crumpled paper towel to soak up the ink in the bottom of the service station.
It may take several rounds of this to clean up the service station.
It is not necessary to completely clean the service station, just get the majority of the ink out.
Once this has been completed you could turn the printer up and clean the bottom area of the printer. Do not tip up the printer before the service station has been cleaned or you are likely to create a mess....
hp printer ink cartridge
May 09, 2010 | HP DeskJet 932c InkJet Printer
Replace ink cart and amber light still blinks
Usually if the Amber light is blinking with a new cartridge, that cartridge has bad electronics.
Try replacing the cartridge with another or the old one, if the light goes out it was just a bad cartridge.
Sep 10, 2009 | HP DeskJet 932c InkJet Printer
I thought I was out of black ink, so I replaced the #45 black ink cartridge in my DeskJet 932C printer and it still won't print in black ink.
check the printhead especially the black partition and see if the nostril on the printhead are not damage. does the ink lid blinking if yes clean or replaced the cartridge
Aug 30, 2009 | HP DeskJet 932c InkJet Printer
Ink cartridge light is blinking without need. and won't print
try to unplug the power cord let it set for about 5 to 10 min then plug it back in and turn the printer on should work fine then
Jul 23, 2009 | HP DeskJet 932c InkJet Printer
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
Failure to print
Here's what we did: Lifted the lid and turned off printer. Then turned on again. Unplugged power cable from back of printer, moved the carriage toward the middle of the printer. Took out cartridges and closed the lid. Plugged the power cord back in. Reinstalled the cartridges. After the alignment page it worked fine. These instructions are paraphrased from HP website troubleshooting. I don't have any idea why any of it worked, but it did and I'm grateful.
J
Aug 29, 2008 | HP DeskJet 932c InkJet Printer
Grinding noise on startup
Problem The Resume light continues to blink after the paper jam is cleared.
OR
The carriage is stuck or making a grinding noise. Solution 1. Lift the top cover to the printer. 2. Turn the printer off and then on again. 3. Unplug the power cable from the back of the printer when the grinding noise starts. 4. Move the carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct). 5. Take out the cartridges and close the top cover. Turn the printer back on! 6. Reconnect the power cord. 7. Open the top cover, reinstall the cartridges, and then close the top cover
Dec 07, 2007 | HP DeskJet 932c InkJet Printer
Help
I suggest you to try below solutions.
solution 1:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&cc=us&lc=en&dlc=en&product=61236&dlc=en&lang=en
Please perform the steps that are mentioned in the web page as appropriate.
Solution 2: Cleaning ink cartridges
http://h10025.www1.hp.com/ewfrf/wc/genericDocument?docname=bpd06920&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
I hope that this should resolve the issue.
Oct 13, 2007 | HP DeskJet 932c InkJet Printer
HP DeskJet 932c InkJet Printer Logo
953 people viewed this question
Ben Johnson
